Post deleted by Defbob [Re: 69CHARGERMD] #221579
02/14/09 08:54 AM
02/14/09 08:54 AM
Re: motor plates? How to locate them? [Re: 69CHARGERMD] #221580
02/14/09 09:03 AM
02/14/09 09:03 AM
west palm beach, florida
modelmakerinc Offline OP
There are several different reasons to use a motor plate. It is mostly considered something for "race"
In my case I have a slant six k-frame and want to install a 440 there are no conversion mounts so I do not have to find a V-8 k-frame, also even if a conversion mount is available the motor plate is less expensive
It takes the stress off the side of the block in high hp applications
It makes the removal of the engine easier in some respects
it can stiffen the front of the chassis if installed certain way.
the biggest down side is it moves the water pump forward 1/4-3/8 inch and makes the pulley alignment need adjustment
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: motor plates? How to locate them? #221581
02/14/09 09:29 AM
02/14/09 09:29 AM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
I would have the headers and oil pan in place when setting the engine and trans in the car. That will help determine the best engine location.
Re: motor plates? How to locate them? [Re: modelmakerinc] #221582
02/14/09 10:20 AM
02/14/09 10:20 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
The Mopar Chassis manual has a lot of this info in the Engine Swaps section.
Re: motor plates? How to locate them? [Re: 69CHARGERMD] #221583
02/14/09 10:26 AM
02/14/09 10:26 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Doug, the motor plate takes the torque off of the
motor mount area and moves it to the front where it
(the block) has more strength, also the plate has a
better lever arm. Its not all that hard to crack the
mount ears off of a block
Re: motor plates? How to locate them? [Re: modelmakerinc] #221584
02/14/09 05:51 PM
02/14/09 05:51 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I just had my bro-in-law machine the thickness of the plate off the water pump housing.That way your clearances to the radiator stay the same without using a spacer.
Gus
64 Plymouth Savoy
Dana 60
Re: motor plates? How to locate them? [Re: fourgearsavoy] #221585
02/14/09 06:59 PM
02/14/09 06:59 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I did what Gus did, had the water pump machined off the thickness [ 1/4' ] from the back of the pump housing. If you don't have a friend with a mill buy a crank spacer. On location of the engine , just buy a ANDYF plate as shown above from Mancini and it'll place your engine correctly on the frame rail and look good doing it.
