Indy Head to B1 #2214986
12/16/16 10:54 AM
12/16/16 10:54 AM
MD
JACK1440 Offline OP
JACK1440  Offline OP
MD
If I were to covert a motor I've been running a set of Indy heads on what needs to be done to switch to B1's? To my knowledge it has to do with valve size or spacing? So the pistons would have to be modified in the relief area?
Re: Indy Head to B1 [Re: JACK1440] #2214996
12/16/16 11:27 AM
12/16/16 11:27 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Valves are move to "on bore center" so pistons are either going to need replaced or worked on. You will need push rods, oil drain back lines along with the b1 stuff IE intake, rocker arms, valley pan ect
You might find your distributor wont fit also.
Joe
Without Data, you’re just another guy with an opinion.
Re: Indy Head to B1 [Re: JACK1440] #2215546
12/17/16 11:42 AM
12/17/16 11:42 AM
MD
JACK1440 Offline OP
JACK1440  Offline OP
MD
that's what I thought. Thanks for the info!
Re: Indy Head to B1 [Re: JACK1440] #2215549
12/17/16 11:49 AM
12/17/16 11:49 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Tom Hemphill in PA cut my Wiseco 440-1 pistons (4.50 bore stock 440 rod size) so I could run my B1 heads. I updated to a nitrous piston so they may be for sale.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Indy Head to B1 [Re: JACK1440] #2215560
12/17/16 12:14 PM
12/17/16 12:14 PM
MD
JACK1440 Offline OP
JACK1440  Offline OP
MD
The main reason I asked is I was starting to think I made a mistake on my new build by not having the pistons cut for B1's thinking you could have a piston that would accept both style heads. The motor is just about complete so I guess at this point hind sight is 20 / 20
Re: Indy Head to B1 [Re: JACK1440] #2215667
12/17/16 02:46 PM
12/17/16 02:46 PM
florida dade
cesar perez Offline
cesar perez  Offline
florida dade
need new pistons
Re: Indy Head to B1 [Re: pittsburghracer] #2218070
12/20/16 11:09 PM
12/20/16 11:09 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
any pics of the pistons ?
1.39 9.85 - 137 mph
Re: Indy Head to B1 [Re: Ari440] #2218116
12/21/16 12:08 AM
12/21/16 12:08 AM
PA.
"Little"John
"Little"John
PA.
I will try to take some pictures tomorrow.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
