1967 Barracuda Formula S 383 daily driver build
#2212910
12/12/16 11:58 PM
12/12/16 11:58 PM
Posts: 1,004 Central US
grancuda
Central US
Found a '67 Formula S 383 auto fastback car locally in my search for a '67-68 notch back driver. I wasn't really looking for a big block car but lucked into finding one. I have had a few late model '09 & '15 R/T Challengers & wanted to get back into a vintage daily driver again. The old stuff is just way more fun & every drive is an adventure. The barracuda has been off the road & in a shed since '85 & needs engine/tranny/gas tank, wiring, radiator, seats, wheels & brakes. It's very rust fee & has most it's original paint. The bumpers,header panel & front valance are all I need for the body but I am also missing the trunk trim. Brought it home Christmas eve almost a year ago & hope to have it in the road in the next month or so.
1967 Barracuda Formula S 383 1967 Chevy C10 Short Stepper 1980 Macho Power Wagon LWB 318 2021 Toyota Supra
Re: 1967 Barracuda Formula S 383 daily driver build
[Re: grancuda]
#2212943
12/13/16 01:01 AM
12/13/16 01:01 AM
grancuda
Central US
The car has some neat old speed parts, old '80s Autometer gauges, a Hurst roll control & some miscellaneous bits like Super Stock Springs, billet U-joint caps, adjustable pinion snubber & a 742 sure grip. I got a '65 383 long block with the car with the drivers front mounting boss. The crank looked good & turned @ 0.010/0.010 & cylinders cleaned up at 0.030. The 727 I got with the car went to Smothers Supercars to go thru it & he add a Transgo kit with the rebuild. The car did come with some new parts too, an Edelbrock Performer RPM, TTI shorty headers w/aluma-coating, Schumacher motor mount brackets w/isolators. Cleaned up the floor pans & got any loose scale & some adhesive from some aftermarket carpeting off. They are super clean & only the passenger front has a rust issue, it as 4 pinholes which will need nothing as soon as I get some POR on them. Luckily there are no extra bucket seat holes & the factory bracing is in place so it wasn't a bench seat car that was converted to buckets. Drivers front has some busted up spot w/metal below which I'm not really sure what happened there.
[Re: grancuda]
#2212954
12/13/16 01:18 AM
12/13/16 01:18 AM
grancuda
Central US
The 383 block got held up in the machine shop, took about 4 months. Got the block back mid April. Got all the parts to put it together & here are the specs: 383 with a steel crank Forged flat tops Edelbrock E-Street w/75cc chambers Calculates to 9.8:1 compression Comp Cams XE274H Holley 650 Street Avenger Edelbrock Performer RPM Mallory dual point 1 7/8" Hooker full length I decided to go with Headman B-body full length under chassis instead of the shorty headers but that proved to be a
[Re: grancuda]
#2212971
12/13/16 01:43 AM
12/13/16 01:43 AM
grancuda
Central US
After much searching & trying to decide going with $1000 factory manifolds or the shorty headers, I decided I wanted to get the most out of the motor & decided to cut it for fenderwells. I like the old '70s style & for me I think it will work out fine. I just will keep the replacement panels if I ever change my mind. Kind of felt bad cutting such a nice car.... Have a set of old Hooker 1 7/8" fenderwells to go on it. I cut them on top as small as I could & still make it work, never liked the gaping holes on the top side of the fenderwell. Check out how much undercoating is in the corner.
[Re: grancuda]
#2212983
12/13/16 02:04 AM
12/13/16 02:04 AM
grancuda
Central US
I had 14x8 cragars that came with the car but decided against the 14" rear wheels because I just couldn't find a tire tall enough to make my 4.10 gears work. I ended up with 15x8 Ansen (new style from American Racing) w/ 275/60R15 & 14x6 ET V w/155R14 up front for header clearance. [img] https://farm1.staticflickr.com/424/31483338651_b15e6097ef_z_d.jpg[img]
[Re: grancuda]
#2213773
12/14/16 08:41 AM
12/14/16 08:41 AM
Posts: 8,666 Buford, GA
I_bleed_MOPAR
Buford, GA
Nice work. Been thinking about finding something similar myself for a DD. Mallory dual point? Must be an older guy to even know what points are. Before I retired, lots of the younger techs didn't know what points and condenser were. If you haven't already done it, are you going to replace the heater core while all the interior is out? Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: I_bleed_MOPAR]
#2214202
12/15/16 01:33 AM
12/15/16 01:33 AM
grancuda
Central US
I like those fenderwell headers on there a lot! Great looking car Thanks, I always liked them but never really wanted them on this real 383 car. I was planning on them going on a '69 /6 Dart with a 440 we have with rusty inner fenders. Nice work. Been thinking about finding something similar myself for a DD. Mallory dual point? Must be an older guy to even know what points are. Before I retired, lots of the younger techs didn't know what points and condenser were. If you haven't already done it, are you going to replace the heater core while all the interior is out? The old, rough original paint cars make nice, stress free drivers. I'm 41, have had several points cars & several articles show there is no hp loss with points. I would rather have it simple than extra wiring & the latest electronics. I wasn't planning on worrying about the heater core till after it is driving. I don't think it will be too hard to pull it out down the road.
[Re: SGTFURY62]
#2214567
12/15/16 06:30 PM
12/15/16 06:30 PM
Posts: 2,155 Tucson, Arizona
clonestocker
Tucson, Arizona
I like those fenderwell headers on there a lot! Great looking car It couldn't hurt to build a heat shield for the master cylinder.
[img] [/img]
[Re: grancuda]
#2278661
03/30/17 12:47 AM
03/30/17 12:47 AM
grancuda
Central US
Got the old Autometer gauges that were in the car when I got all cleaned up & wired up. Ended up getting a replacement for the Coolant Temp since the mechanical one had the sender broke. The replacement one looks pretty decent with these old ones & isn't too far off. These were stacked on the console & I ended up kind putting them at an angle towards me. Looks better than just all flat. Not one of these actually matches, check out the 4 different bulb sockets...
[Re: grancuda]
#2278666
03/30/17 12:54 AM
03/30/17 12:54 AM
grancuda
Central US
Got the brakes done & bleed without too many initial leaks, with 23 connections throughout the car it was inevitable. Also got the headers put on for "good" with studs, cut between the tubes & filed the mating surface smooth. Found out the "good" Mr Gasket header gaskets had the end opening about 1/4" off. Got a cheap set of header gaskets & they match up perfectly. Still have to adapt my DEI starter heat shield to fit the bottom of the master cylinder to protect from heat. Got the correct '67 pie tin for the air cleaner. Now if I could find what I did with the battery tray i could get the battery in & get measured up for cables & such. The border collie thinks the car is comfortable & is sleeping even though I was running the grinder & banging things around plus it was about 45* in the garage.
[Re: clonestocker]
#2278684
03/30/17 01:11 AM
03/30/17 01:11 AM
grancuda
Central US
Been hitting it hard, got a Lokar transmission kickdown & it went on pretty good, much better than the stock 3 piece linkage. The transmission end of the cable is kind of close to the shifter linkage adjustment bolt. I am thinking about putting a set-screw in there to make sure it doesn't interfere. I like those fenderwell headers on there a lot! Great looking car It couldn't hurt to build a heat shield for the master cylinder. Need to get a taller throttle cable bracket but for now I added a piece of another bracket to make it reach a little closer & get it hooked up to the carb. Also got the starter heat shield adapted to protect the master cylinder.
