What pistons are in a steel crank post 71 440?
#2211379
12/10/16 06:29 PM
12/10/16 06:29 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
I know a lot is known and discussed on here so I am hoping someone has enough history to answer the question. I have seen a number of 440s in 72 cars that have the thin steel crank balancers so I assume steel cranks, figuring them to be left over engines from 71. I starting thinking today for some reason about what piston would be in them. Has anyone ever tore down enough of these to draw any conclusion, is there a date break to look for? The reason I ask is there is still a few in old boneyards in my area and I wonder if I should pick them up just because.
Thanks in advance, Kevin
Careful, your character's showing!
Re: What pistons are in a steel crank post 71 440?
[Re: mopar346]
#2211393
12/10/16 07:01 PM
12/10/16 07:01 PM
mopar346
Agreed, true compression rarely meets advertised compression. 10:1 motors from back in the day landed in the low 9 range more often than not and the 8:1 smoggers go low 7s from what I here. My thinking it that if they did have a flat tops they might make good piston donors for some of the low mileage smogger engines I have. I bored at work so I am thinking too much.
[Re: mopar346]
#2211450
12/10/16 08:33 PM
12/10/16 08:33 PM
RapidRobert
My thinking it that if they did have a flat tops they might make good piston donors for some of the low mileage smogger engines I have. I bored at work so I am thinking too much. Nah we cant relate to that at all!
[Re: mopar346]
#2211595
12/11/16 12:25 AM
12/11/16 12:25 AM
mopar346
I haven't found 440 to be scarce yet just some think they are made of gold even smoggers.
[Re: mopar346]
#2212072
12/11/16 08:55 PM
12/11/16 08:55 PM
Posts: 473 Fort Lauderdale, FL
Suregrip
Fort Lauderdale, FL
I just disassembled an H code 1972 440 today, it was cast in Sept 1971. It still has the standard pistons and stock bore. I know that since I have been running the engine in my 1971 Challenger since I rebuilt it in 1989. Back then I could not afford new pistons so I honed the block and used the old pistons and new rings. To bring up the compression I used 516 heads with bigger valves and some porting. This was before all the repo' parts came out, like aluminum heads. Anyway the pistons have a very slight dish to them, not that it really matters as I will finally replace them. According to the 440 Source website the latter blocks are the best blocks made, contrary to everything we used to think we knew...
Some people you just can't reach...
[Re: mopar346]
#2212086
12/11/16 09:23 PM
12/11/16 09:23 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
Could be that they have 500 late blocks to sell and no early ones. I know what they say goes against the mopar engine books.
Have a great day Iowan
"obsolete is neat"
[Re: mopar346]
#2212116
12/11/16 09:44 PM
12/11/16 09:44 PM
Posts: 8,233 fredericksburg,va
cudaman1969
fredericksburg,va
I haven't found 440 to be scarce yet just some think they are made of gold even smoggers. Guess it depends on where you live and how often the crusher comes around
[Re: mopar346]
#2212139
12/11/16 10:04 PM
12/11/16 10:04 PM
mopar346
Trust me I'm not necessarily giving any away either but I have let a number pass for $2-300, I do buy them at $100 though, just cant pass.
[Re: mopar346]
#2212578
12/12/16 04:16 PM
12/12/16 04:16 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
My all original 72 440 has cast flat tops that are way down in the hole. Somewhere around 1/8" below the deck. It's really sad.
7.5:1 is far more likely than the advertised 8.2:1.
[Re: feets]
#2212597
12/12/16 04:47 PM
12/12/16 04:47 PM
dogdays
440Source has exactly zero blocks to sell. Making a "sorta" accusation without checking the facts is just ignorant. If you want to see what the differences are between older and later blocks this will help: http://www.440source.com/blockinfo.htmIt has pictures, so everyone should be able to understand. Of all the things in the world to save, original 440 pistons would be close to the last, and I've been called a hoarder by my wife. If you were selling the aluminum it'd be a different story because they are just flat heavy. Like two pounds per piston heavy. There were millions of B engines produced. There were about 750,000 440s produced. There isn't a big pipeline with new 440 blocks tumbling out of the end. So if you are in a location in which you can pick and choose blocks in the $100 - $200 range, consider yourself lucky. What I am seeing is 413 MH engines for $750. 440 blocks if they are in good shape are advertised for $500. Anyway, Bah! Humbug! Scrooge
[Re: 451Mopar]
#2212622
12/12/16 05:30 PM
12/12/16 05:30 PM
Posts: 74,974 U.S.S.A.
JohnRR
U.S.S.A.
seems 440 builders are getting expensive around here, grab them if the price is right. My notes from the old Silv-o-lite catalog show the 72 and up 8:1 pistons have a compression height of 1.912" The 66-71, 9:1 pistons have a compression height of 1.970" The 66-71 HP, CH = 1.990"? (this still seems fairly low compression?) The TRW six-pack piston, CH = 2.061" 68-69 440 350HP, 375Hp and the 69 390hp 6pk engines used the same piston. I imagine that 66-67 is the same because they both have the same advertised compression ratio like 68-69 . 67 hp = 2.00" 68-70 hp = 2.03" This is more accurate of FACTORY pistons , the numbers at the top are not factory numbers ... not including 70-71 6 pack engines
[Re: mopar346]
#2212638
12/12/16 05:46 PM
12/12/16 05:46 PM
mopar346
My questions was more about if anyone had seen left over steel crack short blocks used in 72 cars or just steel cranks with the smogger pistons.
[Re: mopar346]
#2212646
12/12/16 05:59 PM
12/12/16 05:59 PM
JohnRR
U.S.S.A.
My questions was more about if anyone had seen left over steel crack short blocks used in 72 cars or just steel cranks with the smogger pistons. The answer to both questions would be YES , the cast crank was a midyear 73 thing in the 440.
[Re: JohnRR]
#2212703
12/12/16 07:28 PM
12/12/16 07:28 PM
cudaman1969
fredericksburg,va
My questions was more about if anyone had seen left over steel crack short blocks used in 72 cars or just steel cranks with the smogger pistons. The answer to both questions would be YES , the cast crank was a midyear 73 thing in the 440. I have two left with steel cranks, the third I used the crank, pistons and rods in a 76 hp block that had no ring grove, raced for years now going in a street car. I've seen more steel ones than cast.
[Re: mopar346]
#2212714
12/12/16 07:59 PM
12/12/16 07:59 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I haven't found 440 to be scarce yet just some think they are made of gold even smoggers. Around here any carbureted engines are scarce.
I have mechanical Aptitude. I can screw up anything.
[Re: JohnRR]
#2212717
12/12/16 08:07 PM
12/12/16 08:07 PM
mopar346
....the cast crank was a midyear 73 thing in the 440. I didn't realize the change over was that late, might be more available now that I know that.
[Re: mopar346]
#2212749
12/12/16 09:01 PM
12/12/16 09:01 PM
Posts: 298 mt. pleasant, PA
Diplomat440
mt. pleasant, PA
Every '72 440 I've had, had a steel crank and flat top pistons, no dish. All of em came out of c-bodies.
[Re: mopar346]
#2212988
12/13/16 02:13 AM
12/13/16 02:13 AM
Posts: 5,106 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
Have built a few 440s using the later casting and have had no problems. I found when I was running 440s that there were more early 440 motors around than later 440s maybe because the later motors were still being used in their original vehicles,while the early ones the vehicles were worn out both body and motor so they were cheap. The only problem I found was when you bought a later 440 it just did not have the good crank. You got more bang for you buck buying the early forged crank motor.
Pick up the 440s one day they will be next to impossible to find cheap. I still have 5 440s as spares and two are early and three are 72 and up.
1971 HEMI E BODY REGISTRY
[Re: JohnRR]
#2213119
12/13/16 08:08 AM
12/13/16 08:08 AM
Posts: 4,311 Prospect, PA
BSB67
Prospect, PA
seems 440 builders are getting expensive around here, grab them if the price is right. My notes from the old Silv-o-lite catalog show the 72 and up 8:1 pistons have a compression height of 1.912" The 66-71, 9:1 pistons have a compression height of 1.970" The 66-71 HP, CH = 1.990"? (this still seems fairly low compression?) The TRW six-pack piston, CH = 2.061" 68-69 440 350HP, 375Hp and the 69 390hp 6pk engines used the same piston. I imagine that 66-67 is the same because they both have the same advertised compression ratio like 68-69 . 67 hp = 2.00" 68-70 hp = 2.03" This is more accurate of FACTORY pistons , the numbers at the top are not factory numbers ... not including 70-71 6 pack engines I thought that was true for the 350 hp motors, but was not sure. And for some reason I was thinking that the 71 piston was 1.99, but I don't know where I got that. To the OPs question - I don't know. I doubt that it is a 2.00 or 1.99 piston, but not sure if there was something in between that and the 1.91 piston.
[Re: mopar346]
#2213207
12/13/16 11:09 AM
12/13/16 11:09 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
My questions was more about if anyone had seen left over steel crack short blocks used in 72 cars or just steel cranks with the smogger pistons. 440's went to cast cranks in mid-73. 72's had forged cranks. Guess that has already been stated.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: mopar346]
#2213333
12/13/16 03:01 PM
12/13/16 03:01 PM
cudaman1969
fredericksburg,va
NHRA piston guide, 69 440- .027 below deck 70 440. .051 below deck 71. 440 .051 72. 440 .123 below deck
67 440 .059 68 same as 69
[Re: cudaman1969]
#2213349
12/13/16 03:43 PM
12/13/16 03:43 PM
JohnRR
U.S.S.A.
67 440 .059 68 same as 69 NHRA specs are not ACTUAL FACTORY and should not be used as a guide for any spec that is Factory as delivered mopar related.
[Re: mopar346]
#2213358
12/13/16 04:00 PM
12/13/16 04:00 PM
mopar346
So my assumption that a steel crank engine in a 72 was a leftover 71 is incorrect so these 72 engines were built to 72 specs, I.E. dished pistons and not leftover engines built to 71 specs, I.E. flat tops. Pistons are cheap enough in the grand scheme of things I was just trying to cheap out and get extra blacks in the process. I think the NHRA guidelines help in the conversation from the simple fact that they show a significantly shorter piston which is based on a significantly short factory version of the piston.
Thanks for all the input folks.
[Re: JohnRR]
#2213360
12/13/16 04:02 PM
12/13/16 04:02 PM
cudaman1969
fredericksburg,va
67 440 .059 68 same as 69 NHRA specs are not ACTUAL FACTORY and should not be used as a guide for any spec that is Factory as delivered mopar related. So they just pulled those numbers out of the hat? Whitch one do you think is wrong? Just did the NHRA allowed pistons, 68-71 use same piston but show different ch? Should have checked what head gasket they allowed.
[Re: mopar346]
#2213400
12/13/16 05:06 PM
12/13/16 05:06 PM
feets
Senior Management
Senior Management
Irving, TX
So my assumption that a steel crank engine in a 72 was a leftover 71 is incorrect so these 72 engines were built to 72 specs, I.E. dished pistons and not leftover engines built to 71 specs, I.E. flat tops. Wrong again. The low compression 1972 engines have FLAT TOP pistons. They are just really short to give the low compression. Here's a screen shot from the video I made where I was removing a broken head bolt from my 1972 440. The bottom end is dead stock. This piston was at TDC and you can see how far down it is.
[Re: feets]
#2213405
12/13/16 05:18 PM
12/13/16 05:18 PM
feets
Senior Management
Senior Management
Irving, TX
Closer cropped shot. Best I can offer until I tear the engine down again.
[Re: mopar346]
#2213484
12/13/16 07:50 PM
12/13/16 07:50 PM
mopar346
Did all the earlier ones have valve reliefs or just 6 pack pistons? I think an earlier post said all had the same piston year to year. Feets clearly has no valve reliefs so that might be a tell tale sign of compression, I have always known/believed valve reliefs in a piston denoted "high compression" regardless (within reason of domestics) of the make.
[Re: mopar346]
#2213496
12/13/16 08:15 PM
12/13/16 08:15 PM
cudaman1969
fredericksburg,va
Did all the earlier ones have valve reliefs or just 6 pack pistons? I think an earlier post said all had the same piston year to year. Feets clearly has no valve reliefs so that might be a tell tale sign of compression, I have always known/believed valve reliefs in a piston denoted "high compression" regardless (within reason of domestics) of the make. RBs From 65 up 440-6 only, 64 down Max wedge. Same pistons year to year, no
[Re: cudaman1969]
#2213535
12/13/16 09:37 PM
12/13/16 09:37 PM
BSB67
Prospect, PA
67 440 .059 68 same as 69 Those numbers actually line up well with what I said, minus 1970.
[Re: cudaman1969]
#2213596
12/13/16 11:10 PM
12/13/16 11:10 PM
mopar346
I want to make sure I understand your information, so only 6 pack engines had pistons with valve reliefs from 65 up and only Max Wedge pistons had valve reliefs is 64 and older. And 440s did not use the same pistons from say 65-71. Thanks
[Re: mopar346]
#2213734
12/14/16 02:44 AM
12/14/16 02:44 AM
cudaman1969
fredericksburg,va
I want to make sure I understand your information, so only 6 pack engines had pistons with valve reliefs from 65 up and only Max Wedge pistons had valve reliefs is 64 and older. And 440s did not use the same pistons from say 65-71. Thanks One example, 67 had the closed chamber 915 head, so the piston was down in the cylinder more. In 68 the 906 open chamber came about and the piston was raised to keep same CR. I do have some 70 standard pistons I can check against the 68-69 ones I have too, just got to find them, hope I didn't toss them. I can also measure the ones still in the 72 block, if it will turn over, never had any 71s so no idea on those. 70-71 6 Pacs where the tallest CH in 440s and had valve reliefs. Also have a 74 with low pistons, six-pac rods and steel crank, internally balanced, came out of a motor home, got its own balancer too.
[Re: mopar346]
#2213784
12/14/16 10:24 AM
12/14/16 10:24 AM
mopar346
Don't go to any great trouble but it would be interesting to know. If you have a good set of standard bore 68-69/comparable pistons you want to get rid of PM me.
The reason for all these questions is I have a 76 RV engine with very low miles that I should be able to pop a set of good pistons in with some good heads and have another respectable engine ready to go.
Thank you
[Re: cudaman1969]
#2213882
12/14/16 02:39 PM
12/14/16 02:39 PM
JohnRR
U.S.S.A.
67 440 .059 68 same as 69 NHRA specs are not ACTUAL FACTORY and should not be used as a guide for any spec that is Factory as delivered mopar related. So they just pulled those numbers out of the hat? Whitch one do you think is wrong? Just did the NHRA allowed pistons, 68-71 use same piston but show different ch? Should have checked what head gasket they allowed. I don't know where they get them, Chrysler maybe ?? But I know that a 69 440 piston is not .027 in the hole , it's more like .050 in the hole. For some reason Chrysler piston spec is .020ish HIGHER than actual. Perfect example is a 68-69 383 HP, the factory piston on blueprint spec is .0025 in the hole ... CH is 1.932 ..., NHRA spec has the piston .021 ABOVE the deck. There isn't a 383 delivered from Chrysler with a piston that high above the deck surface. Also the NHRA spec for a 906 is 79.5cc chamber, ACTUAL is 90-92cc. Advertised compression ratio from Chrysler on the 383 is 10.0, actual is 9.2, built to the NHRA allowed spec of 79.5cc , +.021 deck and .070 max overbore yields close to 11.5 ...
[Re: mopar346]
#2213883
12/14/16 02:42 PM
12/14/16 02:42 PM
JohnRR
U.S.S.A.
Thanks for all the input folks. the only dished factory pistons I have seen in a Chrysler was a 73 360 and the 68-69 383 2bbl , I've never seen a dished piston in a 440.
[Re: BSB67]
#2213888
12/14/16 02:49 PM
12/14/16 02:49 PM
JohnRR
U.S.S.A.
67 440 .059 68 same as 69 Those numbers actually line up well with what I said, minus 1970. Common core math maybe 10.725 blueprint RB deck 6.768 rod 3.75/2 = 1.875 crank stroke 68-69 2.03 piston is .052 in the hole 66-67 2.00 piston is .082 in the hole I'm not sure what 70 is because NHRA spec is different for 70, which has 2 piston specs 440-4 and 440-6pk. The 440-6pk in 70 is the only piston spec where NHRA and factory actually match up, 71???
[Re: mopar346]
#2213909
12/14/16 03:38 PM
12/14/16 03:38 PM
cudaman1969
fredericksburg,va
Update, found three different pistons. First is 1.937 these I think are the 67 440. Next is the 70 at 1.99 next is a 72 HP set with the six-pac rods at 1.875, these are approximate numbers. Did find my earliest 440 block, cast date 7-2-65 About NHRA discrepancies on years deck heights, the 70 piston is the same as 68-69 so who knows where they come up with their figures. If I was running a 70 440-4 I would want the same compression as the 69 engine (need to look at the HP factor on both years, might rate it lower on 70). Sorry I don't have a full set of the 1.99 pistons, should be a lot available though. I would keep the low ones, sure nice pulling up to the reg. gas pump. That's what I ran in my 64 Plym and would run 7.55 all day.
[Re: JohnRR]
#2213916
12/14/16 03:47 PM
12/14/16 03:47 PM
cudaman1969
fredericksburg,va
U NHRA piston guide, 69 440- .027 below deck 70 440. .051 below deck 71. 440 .051 72. 440 .123 below deck
67 440 .059 68 same as 69 NHRA specs are not ACTUAL FACTORY and should not be used as a guide for any spec that is Factory as delivered mopar related. So they just pulled those numbers out of the hat? Whitch one do you think is wrong? Just did the NHRA allowed pistons, 68-71 use same piston but show different ch? Should have checked what head gasket they allowed. I don't know where they get them, Chrysler maybe ?? But I know that a 69 440 piston is not .027 in the hole , it's more like .050 in the hole. For some reason Chrysler piston spec is .020ish HIGHER than actual. Perfect example is a 68-69 383 HP, the factory piston on blueprint spec is .0025 in the hole ... CH is 1.932 ..., NHRA spec has the piston .021 ABOVE the deck. There isn't a 383 delivered from Chrysler with a piston that high above the deck surface. Also the NHRA spec for a 906 is 79.5cc chamber, ACTUAL is 90-92cc. Advertised compression ratio from Chrysler on the 383 is 10.0, actual is 9.2, built to the NHRA allowed spec of 79.5cc , +.021 deck and .070 max overbore yields close to 11.5 ... I'm thinking these numbers are what you can creep up on but not go over. In other words, what they will allow. The good and bad thing about the 69-383 height, good for compression,bad because the valve hits when using the spec 440 cam.
[Re: JohnRR]
#2213998
12/14/16 07:17 PM
12/14/16 07:17 PM
BSB67
Prospect, PA
67 440 .059 68 same as 69 Those numbers actually line up well with what I said, minus 1970. Common core math maybe 10.725 blueprint RB deck 6.768 rod 3.75/2 = 1.875 crank stroke 68-69 2.03 piston is .052 in the hole 66-67 2.00 piston is .082 in the hole I'm not sure what 70 is because NHRA spec is different for 70, which has 2 piston specs 440-4 and 440-6pk. The 44- 6pk in 70 is the only piston number where NHRA and factory actually match up, 71??? My math goes to the ratio of the piston depths or CD that were posted to the piston CH that I listed. I intentionally stayed away from the whole deck height discussion. But without that clarification, my comment was indeed unclear.
[Re: cudaman1969]
#2214001
12/14/16 07:26 PM
12/14/16 07:26 PM
BSB67
Prospect, PA
First is 1.937 these I think are the 67 440. I have my original set of 67s. They are 2.00 and some change. 2.003" I think. My 68-69 (have we decided if 70 is the same?) pistons are 2.034", I think. I need to go out measure again, and write these down, as it seems to come up a few times a year.
[Re: mopar346]
#2214010
12/14/16 07:47 PM
12/14/16 07:47 PM
feets
Senior Management
Senior Management
Irving, TX
Thank you There's the problem. Don't use old pistons. You can make plenty of power with low compression. Save your pennies until you can do a proper build.
[Re: feets]
#2214023
12/14/16 08:15 PM
12/14/16 08:15 PM
mopar346
Don't use old pistons. You can make plenty of power with low compression. Save your pennies until you can do a proper build. I wouldn't necessarily use unknown old pistons but I will use inspected old pistons in good shape. Pennies aren't a problem I keep them in the trunks of my AAR, GTS, RTs and several other cars for traction. As much as my cheap nature and a desire to build some things like we use to have to at 16, anyone can go to the Summit website and order pretty much any part of an engine or a car for that matter, it's more fun in my view to build something with minimal investment and in many cases used parts. I have built more than I can count, some blue printed in excess and some thrown together at the track on borrowed parts and a wing and a prayer.
[Re: cudaman1969]
#2214027
12/14/16 08:27 PM
12/14/16 08:27 PM
RapidRobert
I'm thinking these numbers are what you can creep up on but not go over. In other words, what they will allow. Agreed, that is my understanding of NHRA specs back when I knew some drag racers
[Re: BSB67]
#2214077
12/14/16 10:02 PM
12/14/16 10:02 PM
cudaman1969
fredericksburg,va
First is 1.937 these I think are the 67 440. I have my original set of 67s. They are 2.00 and some change. 2.003" I think. My 68-69 (have we decided if 70 is the same?) pistons are 2.034", I think. I need to go out measure again, and write these down, as it seems to come up a few times a year. Compression height is measured from the center of pin and my 70 standard pistons are under 2 inches and are the same as the TRW L2266 (69). All those measurements I did before are from the pin center.
[Re: cudaman1969]
#2214144
12/14/16 11:33 PM
12/14/16 11:33 PM
BSB67
Prospect, PA
First is 1.937 these I think are the 67 440. I have my original set of 67s. They are 2.00 and some change. 2.003" I think. My 68-69 (have we decided if 70 is the same?) pistons are 2.034", I think. I need to go out measure again, and write these down, as it seems to come up a few times a year. Compression height is measured from the center of pin and my 70 standard pistons are under 2 inches and are the same as the TRW L2266 (69). All those measurements I did before are from the pin center. Right, measured from the pin centerline. The actual original replacement piston for 68-69 is not the TRW L2266. That is what they will let you use today for NHRA and allowing block machining to the compression height. This is because this is the only piston available that is close, I suspect. The original 68-69 NHRA replacement piston was the the L2286 (I have these as well). These were discontinued in the late 1980s. I did just measure my 67 original piston, 2.002" although the mic, piston and pin were about 25°F.
[Re: mopar346]
#2214339
12/15/16 12:11 PM
12/15/16 12:11 PM
feets
Senior Management
Senior Management
Irving, TX
Don't use old pistons. You can make plenty of power with low compression. Save your pennies until you can do a proper build. I wouldn't necessarily use unknown old pistons but I will use inspected old pistons in good shape. Pennies aren't a problem I keep them in the trunks of my AAR, GTS, RTs and several other cars for traction. As much as my cheap nature and a desire to build some things like we use to have to at 16, anyone can go to the Summit website and order pretty much any part of an engine or a car for that matter, it's more fun in my view to build something with minimal investment and in many cases used parts. I have built more than I can count, some blue printed in excess and some thrown together at the track on borrowed parts and a wing and a prayer. The pennies comment was a generic thing. It wasn't intended as an insult to you personal finances. Pulling engines isn't much fun. Get the most value for your time. Do it once and do it right. I'd much rather drive my car with complete peace of mind than to have a set of used pistons in a half-assed engine build popping into my head. Proper pistons are relatively inexpensive and I'd rather spend my time doing something other than a second engine rebuild.
[Re: mopar346]
#2214357
12/15/16 12:37 PM
12/15/16 12:37 PM
mopar346
So far, and I know this is how to jynx yourself, I have been fortunate enough not to have to go back into any of my engines in a short length of time other than an intake gasket I cant seem to get right on the AAR for whatever reason. I drive my stuff all over the east coast so I'm either confidence in builds or ignorance is bliss as they say (I also carry AAA Premium and have friends in most state I travel in). People/racers/builders use used stuff all the time, I'm not necessarily making an argument for it I'm just saying you cant through the baby out with the bath water. I have opening up a many a engine to inspect it and came out with only new gaskets, some maybe just got rings, bearings and gaskets and I'm not alone in it. I believe you recently suffered a failure on an engine, my bet is you aren't gonna replace the pistons if they inspect good, so you are going to build/reassemble an engine with used pistons. As for pulling engines being fun, it's all fun to some and even though no one really enjoys doing anything on a car twice, I'm gonna tinker on something for several hours most any given day when I'm home so it don't bug me. I really have to but admittedly I've taken some chances that haven't worked out but rarely have I had a failure when I paid attention and truly inspected an item. It helps that I do it all myself and it will only cost me time if I miss my guess. I enjoy building junkyard cars as much if not more than full restoration, I only have $2000 in my 69 RT and drove it to PA and back last year with minimal drama, it's an absolute hoot to drive. I guess point it, old parts can be fine if thoroughly inspected and really present no more risk than a new part, at least the old part was made in America at a time when there was some thought given to quality.
[Re: cudaman1969]
#2214425
12/15/16 02:01 PM
12/15/16 02:01 PM
JohnRR
U.S.S.A.
Someone building an engine to compete in the class is going to build to the max allowed if they want to be competitive otherwise why bother. The 68-69 383HP road runner/superbee engine and the 375HP 440 Magnum used the exact same cam.
[Re: BSB67]
#2214430
12/15/16 02:04 PM
12/15/16 02:04 PM
JohnRR
U.S.S.A.
67 440 .059 68 same as 69 Those numbers actually line up well with what I said, minus 1970. Common core math maybe 10.725 blueprint RB deck 6.768 rod 3.75/2 = 1.875 crank stroke 68-69 2.03 piston is .052 in the hole 66-67 2.00 piston is .082 in the hole I'm not sure what 70 is because NHRA spec is different for 70, which has 2 piston specs 440-4 and 440-6pk. The 44- 6pk in 70 is the only piston number where NHRA and factory actually match up, 71??? My math goes to the ratio of the piston depths or CD that were posted to the piston CH that I listed. I intentionally stayed away from the whole deck height discussion. But without that clarification, my comment was indeed unclear. I used the deck height to drive home that NHRA spec and ACTUAL specs are not the same ... You had the actual piston CH , which are not available in the aftermarket currently , and haven't been for quite some time , if at all ...
[Re: cudaman1969]
#2214488
12/15/16 03:43 PM
12/15/16 03:43 PM
JohnRR
U.S.S.A.
"The 68-69 383HP road runner/superbee engine and the 375HP 440 Magnum used the exact same cam."
But, the stocker cam used in the 440, can't be used in the 69 383 because it hits the piston in the allowable blue print specs. So the cam has to be less duration, IF they let us notch the piston we could use the better 440 cam. How can the 440 cam be different if it's a same cam in both engines from the factory ??? Yes I know that duration is not a checked spec and the deeper in the hole piston of the 69 440 allows more duration with the same lift. I've said it before , and I'm sure I might have borrowed it from someone ... there is little that is STOCK in NHRA STOCK
[Re: JohnRR]
#2214667
12/15/16 09:06 PM
12/15/16 09:06 PM
cudaman1969
fredericksburg,va
But, the stocker cam used in the 440, can't be used in the 69 383 because it hits the piston in the allowable blue print specs. So the cam has to be less duration, IF they let us notch the piston we could use the better 440 cam. How can the 440 cam be different if it's a same cam in both engines from the factory ??? Yes I know that duration is not a checked spec and the deeper in the hole piston of the 69 440 allows more duration with the same lift. I've said it before , and I'm sure I might have borrowed it from someone ... there is little that is STOCK in NHRA STOCK Not sure what you're interpreting when reading what I write, I've only talked about NHRA stocker camshafts in NHRA Stock class cars, nothing about factory camshafts. These cams have stock lifts but ungodly duration ( the reason it hits in a 383) Did read today in the old DC book with Larry Shepard, the 69 383 was listed at .021 above deck the rest where below. This was probably given to NHRA for whatever reason back in the day. For STOCK class racing only.
[Re: mopar346]
#2215270
12/16/16 08:09 PM
12/16/16 08:09 PM
feets
Senior Management
Senior Management
Irving, TX
I believe you recently suffered a failure on an engine, my bet is you aren't gonna replace the pistons if they inspect good, so you are going to build/reassemble an engine with used pistons. My engine will be getting new pistons. I'll go completely through it to raise the compression and get the most out of it. I don't like combining used pistons in used bores they've never met. To me it seems similar to mixing used lifters on a used cam.
