Page 4 of 5 < 1 2 3 4 5 >
#2295910 - 04/29/17 12:15 AM Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc. [Re: RylisPro]
GoodysGotaCuda Offline
5.7L Hemi, 6spd
Loc: Texas
Originally Posted By RylisPro
Goody do you have the rubber boots for those heim joints?
Seals it RERS3. You need 10 for the Hotchkis kit
It helps to have them for longevity
Yep, I did boots on the tie rods, UCAs and strut rods. They are not the most fun to work with, but I can really see them helping improve the life of the joint. Road grime and brake dust is not good for much of anything.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - Build page -> https://www.facebook.com/GoodysGotaHemi<-
1976 Dodge Warlock - "Her Truck" - 360/727 2wd
2016 BMW X1, 2016 Subaru WRX
#2300953 - 05/07/17 10:08 PM Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc. [Re: GoodysGotaCuda]
5.7L Hemi, 6spd
Loc: Texas
Progress has been slow lately but I am spooling back up a little sprint on work for the next few weeks.
I managed to get a $250 set of Aeromotive fuel rails off of an Amazon price dip for $95. Unfortunately they come in a horrid anodized red, which would screw up my feng shui! I picked up some new injectors and treated the rails to a coat of gunmetal grey to help blend in a little better. Along with that, I have kicked off the fuel system by mocking up the TanksInc tank in the car. The JakeFab puck is close, but appears to fit under the floor.
I have some basic lines made up to the filter/regulator and will work on a rollover vent mount as well. The 6AN fuel line routes along the passenger rail [previous post] and witin the subframe connector. That was made possible by some very early planning when things went together, so far it seems to be just right.
I also finished up the installation of my Hotchkis rear sway bar, I needed to weld on the chassis mounts for it. I wanted to make sure my line routing accounted for all of those parts back there.
That's all for now!
#2301078 - 05/08/17 09:41 AM Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc. [Re: GoodysGotaCuda]
killermopar Offline
Loc: Spencer NY
It's nice to see it coming together for you.
#2302855 - 05/11/17 12:30 PM Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc. [Re: GoodysGotaCuda]
Bad340fish Offline
Loc: Tulsa OK
Looking great!
Your MS3 should be able to handle your fuel pump PWM. that you want to do. You will have to use a solid state relay for the pump obviously but there is settings to control your pump PWM. I have run into some fuel heating issues and I want to try it but I have not gotten around to it just yet.
68 Barracuda Formula S 340
#2303035 - 05/11/17 07:35 PM Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc. [Re: Bad340fish]
5.7L Hemi, 6spd
Loc: Texas
Originally Posted By Bad340fish
Looking great!
I would need an ISO 280 solid-state relay, which I am not sure exists. I will likely do PWM for the fuel pump at some point, actually, I initially planned to. For now, I am running behind enough that I have parked some of the non-essential tasks to get the car on the road. That's a project for a weekend after the car is running well.
#2303883 - 05/13/17 02:48 PM Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc. [Re: GoodysGotaCuda]
Bad340fish Offline
Loc: Tulsa OK
Once they make noise they do get easier to stay motivated. I am sure you know more about the relays than I do but at one time I was pointed to one for a reasonable cost that could(or is supposed to) do the job. If I come across that part I'll post it.
#2309607 - 05/23/17 06:52 AM Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc. [Re: GoodysGotaCuda]
5.7L Hemi, 6spd
Loc: Texas
I am creeping up on a fully wired and validated electrical system, which is a pretty big milestone for me. I can talk to the Megasquirt and load tunes, make changes and test some of the systems.
Hopefully these videos work:
Tach test
https://youtu.be/hgHusDZX7js
Coil test
https://youtu.be/lZwj3mgxLwQ
Injector test [all, sequential injection]
https://youtu.be/D2c9FWe1JZI
#2310102 - 05/23/17 10:10 PM Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc. [Re: GoodysGotaCuda]
Bad340fish Offline
Loc: Tulsa OK
The test modes on the MS are pretty awesome. I just discovered I had a bad coil(I run 8 LS coils) and the test mode was nice to help confirm where the actual problem was.
When the engine is running you can also deactivate injectors and coils to determine if things are working properly.
#2311730 - 05/26/17 06:06 PM Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc. [Re: Bad340fish]
5.7L Hemi, 6spd
Loc: Texas
I haven't seen the deactivate one before, that's pretty neat.
#2314403 - 05/31/17 10:18 PM Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc. [Re: GoodysGotaCuda]
5.7L Hemi, 6spd
Loc: Texas
First attempt to start it was successful!
Hopefully the video works
https://youtu.be/QSDveBUH5e8
#2314712 - 06/01/17 03:57 PM Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc. [Re: GoodysGotaCuda]
jpilone Offline
Loc: Boca Raton, Florida
Awesome! That's the best sound...
-Jarrod Pilone
'70 Plymouth RR Convertible with amazing custom paint(Tribute/Recreation/Whateveryouwannacallit)
My Project Thread
#2318572 - 06/09/17 04:29 PM Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc. [Re: GoodysGotaCuda]
gtx6970 Offline
Loc: Land of Booze and Horses
Wow, car has certainly come a long way.
I remember reading on this very board when you bought this car
#2319417 - 06/11/17 12:02 PM Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc. [Re: GoodysGotaCuda]
ric3xrt Offline
Loc: Sellersville Pa
Attention to detail is amazing, love this thread. great job.
Truth has no agenda, but those with an agenda don't always acknowledge truth
2003 Ram st
2004 Rumble Bee
2005 Ram GTX
Any info on these trucks is greatly appreciated
2005 Ram 1500 (drag truck in building
2014 1500 tradesman(shhhh, it's hiding a 7.0 short block under those eagle heads.
#2325992 - 06/23/17 11:56 PM Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc. [Re: ric3xrt]
5.7L Hemi, 6spd
Loc: Texas
This was certainly the first place I stopped when I bought the car in November of 2004. The car is in a far better state today than I could have ever imagined back then!
Thank you! I have exhibited some level of OCD symptoms throughout this process, hopefully for the better. I tend to worry about things most people never pay attention to. fan
The car was rolled out of the garage for the first time on its own wheels in three years. It seems like an eternity. I expect the back end to go back down like it should once I have a full 3" exhaust, seats, glass and a battery in the car, it's sitting a bit high for my liking.
My garage is getting air conditioning this weekend so that I can get this car finished this Summer!
#2327710 - 06/27/17 07:36 PM Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc. [Re: GoodysGotaCuda]
FrankenScamp Offline
Loc: Medford OR
bow punkrocka
Man, it's getting closer! Great job thus far. beer
#2329394 - 06/30/17 09:51 PM Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc. [Re: GoodysGotaCuda]
5.7L Hemi, 6spd
Loc: Texas
It's getting quite close to driving now!
Sorry for the early pictures in this thread being no longer valid. The forum won't seem to let me edit/fix the links, so I may have to restart this thread elsewhere wrench
#2330545 - 07/03/17 06:35 AM Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc. [Re: GoodysGotaCuda]
UCUDANT Offline
Troll Hunter
Loc: New Mexico
Congrat Mike, I bet you can't wait.
Maybe a moderator can help you update the invalid pics?
#2334395 - 07/09/17 09:21 PM Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc. [Re: GoodysGotaCuda]
5.7L Hemi, 6spd
Loc: Texas
I briefly pulled it out of the garage under it's own power today and let it get to full operating temp.
Lots of EFI tuning to do yet and I am working on getting everything else in the car asap.
#2335656 - 07/11/17 10:31 PM Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc. [Re: GoodysGotaCuda]
JDMopar Offline
Loc: Candler,NC / Myrtle Beach, SC
work Hmmmm......I'm gonna go out on a limb here, and bet your screen name on the young dads message board is GOODYSGOTACUTIE! biggrin up
#2339335 - 07/18/17 07:04 PM Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc. [Re: GoodysGotaCuda]
5.7L Hemi, 6spd
Loc: Texas
https://www.youtube.com/watch?v=Dn1dQ8Crz_o
I did a little driving yesterday, moving forward with it!
25,155 Registered Members
186,861 Topics
WIW steering wheels
by DusterKid
8 minutes 0 seconds ago
...and yes this is serious.....
by Soopernaut
27 minutes 2 seconds ago
69 Cuda A53 Ebay
by RMCHRGR
Today at 01:12 PM
Why would anyone do this to a challenger??
by Butterscotch71
Today at 01:07 PM
