Hoosier slicks compounds
#220735
02/10/09 10:04 PM
02/10/09 10:04 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Looking at getting a set of Hoosier 30x9 radial slicks. What is the difference between the CO6 and CO7 compounds?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Hoosier slicks compounds
[Re: Von]
#220738
02/11/09 01:02 PM
02/11/09 01:02 PM
Posts: 5,894 Florida
Locomotion
The lightweight 9" radials are only available in C06 compound and the standard weight 9" radials only in C07. Not sure why they use different compounds, but you save a couple of pounds with the lightweight versions. A 10" rim works well with them. Hoosier specs
