Paint mark identification #2206987
12/03/16 03:24 PM
12/03/16 03:24 PM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
What do these mean.
Re: Paint mark identification [Re: 70 buzz] #2206998
12/03/16 03:46 PM
12/03/16 03:46 PM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
Is that bottom picture an axle tube? I think that would be a stenciled date. My T/A was stenciled a date in that location.
Re: Paint mark identification [Re: Finoke] #2207030
12/03/16 04:50 PM
12/03/16 04:50 PM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
how would you read that as a date? I thought it would be a line identification for on a broadcast sheet as to what rear end went into what car
Re: Paint mark identification [Re: 70 buzz] #2207033
12/03/16 04:58 PM
12/03/16 04:58 PM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
I'm thinking most of it is missing. I will try later to find the pictures I had taken at the time. If I remember correctly white stenciled date. I found mine under a light coat of grease that covered the entire rear.
Re: Paint mark identification [Re: Finoke] #2207036
12/03/16 05:01 PM
12/03/16 05:01 PM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
Already found one. A car I used to own. March build 70 T/A. Fender tag states 324. Rear marked 320Z
Re: Paint mark identification [Re: Finoke] #2207037
12/03/16 05:05 PM
12/03/16 05:05 PM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
One more.... Never seen a rear that had original markings so nice under the grease.
Re: Paint mark identification [Re: 70 buzz] #2207130
12/03/16 08:35 PM
12/03/16 08:35 PM
Massachusetts
RAII4-speed Offline
RAII4-speed  Offline
Massachusetts
How did you remove the grease without removing the markings ?
Re: Paint mark identification [Re: RAII4-speed] #2207169
12/03/16 09:18 PM
12/03/16 09:18 PM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
I used a putty knife. Then I took the pictures and reapplied the markings after I restored the rear.
Re: Paint mark identification [Re: 70 buzz] #2207175
12/03/16 09:24 PM
12/03/16 09:24 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I think it means pizza smells good
