Page 3 of 3 < 1 2 3
#2440735 - 01/25/18 06:48 PM Re: 99 V10 engine noise...Bad cats?? [Re: chargers777]
dodgedon Offline
Loc: ND
Yes, It's a little loose. Was looking For a replacement and all I see is just the chain... I thought that was a no no? Didn't find any listings for a chain and gears set...
The rods are all showing brass and some are down to the metal on the bearing shells. None of them were spun. The mains look perfect. The first rod Journal has a small step on it and is too deep to fix, so I ordered a different crankshaft. I'm finding there is not much for parts available for these engines
67 Charger 383 auto
75 Dodge CNT 800 CAT Diesel
2012 Ram Crew cab 5.7 4x4
#2441410 - 01/27/18 07:27 AM Re: 99 V10 engine noise...Bad cats?? [Re: dodgedon]
redraptor Offline
Loc: Greenville, PA
Never really was. Hope you find what you're looking for.
Just another lesson learned....
#2442094 - 01/28/18 07:41 AM Re: 99 V10 engine noise...Bad cats?? [Re: dodgedon]
Guitar Jones Offline
Loc: in a cattle trailer down by th...
There are things that interchange with the magnum small block but I don't know exactly what. Timing chain and gears may be one such thing.
I never learned to count my blessings, I choose instead to live inside my disasters.
The Scamp is sold, now just two old trucks and one new one.
'74 W200 Crew Cab 360, NP435, D44, D60 and NP205 divorced transfer case. Magnum 5.2 MPI and NV4500 coming soon.
2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi!
#2442095 - 01/28/18 07:46 AM Re: 99 V10 engine noise...Bad cats?? [Re: dodgedon]
A quick cross reference on rock auto shows they both use the same chain so an aftermarket set for a small block should work for you.
#2442244 - 01/28/18 12:03 PM Re: 99 V10 engine noise...Bad cats?? [Re: Guitar Jones]
dodgedon Offline
Loc: ND
The magnum set won't work. The chain may be the same but the upper sprocket has the ring cast on it for the cam sensor. What I have found is that you can buy the chain, and the lower sprocket separately from Napa, but not the upper sprocket. I did find a timing "set" listed for this from Auto zone #73153. Not for sure that they can even order it still... Or who even makes it. Anyone have any opinion on the quality of their parts?
67 Charger 383 auto
#2443267 - 01/30/18 01:38 AM Re: 99 V10 engine noise...Bad cats?? [Re: dodgedon]
SNK-EYZ Offline
Loc: Lost in Space
Autozone's website says that they're available.
https://www.autozone.com/internal-engine...odel=&year=
They even list them on Ebay with two different number and prices.
https://www.ebay.com/itm/Engine-Timing-S...qGq&vxp=mtr
https://www.ebay.com/itm/Engine-Timing-S...kS1&vxp=mtr
#2446437 - 02/04/18 04:45 PM Re: 99 V10 engine noise...Bad cats?? [Re: dodgedon]
dodgedon Offline
Loc: ND
Problem solved... I did order that timing set from Auto Zone. It said Made in the USA on the package but not sure by who. It looked good and was almost identical to the original. Dropped in the new crank and bearings and ran it yesterday and drove it to town today. It hums like a V-10 with no funny rattling noise between shifts. The engine had a little lifter noise on start up before too and that is also gone now. I know now that the engine oil was bleeding down from the loose rods when it sat.
After all these years of wondering what it was, I'm happy to be done with it.
67 Charger 383 auto
#2446484 - 02/04/18 05:49 PM Re: 99 V10 engine noise...Bad cats?? [Re: dodgedon]
Glad to hear you got it fixed and glad you updated your thread. Too many people don't do that.
#2446642 - 02/04/18 10:56 PM Re: 99 V10 engine noise...Bad cats?? [Re: dodgedon]
sportfury70 Offline
Loc: Cleveland Ohio
You replaced crank in chassis? How difficult was that?
#2446706 - 02/05/18 01:53 AM Re: 99 V10 engine noise...Bad cats?? [Re: sportfury70]
dodgedon Offline
Loc: ND
No, I pulled the pan in chassis but when i realized what was wrong I ended up pulling the motor out.
67 Charger 383 auto
#2447914 - 02/07/18 07:39 AM Re: 99 V10 engine noise...Bad cats?? [Re: dodgedon]
SNK-EYZ Offline
Loc: Lost in Space
Glad to hear that you got it figured out and it's now fixed. up
#2449030 - 02/09/18 08:21 AM Re: 99 V10 engine noise...Bad cats?? [Re: dodgedon]
J_BODY Offline
Loc: aZLiViN
....and make sure you use GOOD plug wires and route them correctly. We used to see crossfire hammer rod bearings out of these things.
Page 3 of 3 < 1 2 3
25,743 Registered Members
193,026 Topics
Jegs/Summit Codes back out
by DusterKid
4 minutes 46 seconds ago
Airtemp Infringing
by scatcity
37 minutes 9 seconds ago
413 valve size
by als499
38 minutes 32 seconds ago
Who sells A-Body Rear Leaf Spring Rebuild Kits?
by vinnyd76
Today at 09:58 AM
