Hydraulic brake assist system #2202883
11/26/16 04:30 PM
11/26/16 04:30 PM
Colorado
Bob J Offline OP
Bob J  Offline OP
Colorado
I'm working on a 68 Mopar big block for SCCA AutoX Cam class and want to know what folks think of hydraulic brake assist or keep it manual. I have Wilwood brakes front and in the rear. I have never used this type of system and need some input. If any one is running the system did you piece it together or did you buy a kit?
Kit
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS
68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam
65 Chrysler 300 Convert. project
57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son
2003 Dodge Dakota R/T "DEAD"
Re: Hydraulic brake assist system [Re: Bob J] #2203564
11/27/16 10:32 PM
11/27/16 10:32 PM
IN
ahy Offline
ahy  Offline
IN
As general comment, with the Wilwood calipers, I think you will need strong assist. They have smaller than OE piston area and need plenty of line pressure like the Cobra style calipers I run on an E. It would be hard to get a manual bake setup to work well. It is hard even with the large area of the factory single piston calipers.
I upgraded to a double 8" booster and 15/16" master to get enough line pressure for full braking wihh my Cobra setup. I am considering "some day" upgrade to hydroboost for the more compact installation and additional line pressure capability.
Re: Hydraulic brake assist system [Re: Bob J] #2203577
11/27/16 10:53 PM
11/27/16 10:53 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
We will see how mine works out. I bought 12.88" 6piston Wilwood fronts and 12.2" 4 piston rears. Wilwood recommended a 7/8" master with my manual brake setup. I want to keep manual as long as I can for the pedal feel.
What master do you have now?
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Hydraulic brake assist system [Re: GoodysGotaCuda] #2203712
11/28/16 01:57 AM
11/28/16 01:57 AM
Colorado
Bob J Offline OP
Bob J  Offline OP
Colorado
The plastic reservoir the Chrysler Type 1 1/16 piston.
Re: Hydraulic brake assist system [Re: Bob J] #2204094
11/28/16 10:52 PM
11/28/16 10:52 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Hydroboost is a love it or hate it feature, when set up right many like the extra braking pressure it creates while others are happy with manual brakes. Its an expensive experiment that I am planning on doing when I get my care farther along. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Hydraulic brake assist system [Re: Bob J] #2204238
11/29/16 02:43 AM
11/29/16 02:43 AM
Coronado, CA
go-fish Offline
go-fish  Offline
Coronado, CA
I have a HydraTech kit. http://www.hydratechbraking.com/
He sold me a kit minus master which I sourced at a parts store. It was a 1 1/8" 1980's Dodge D-100 or D-150 I believe.
From my understanding it is a gamble getting a junkyard unit but you can get a rebuilt one from multiple sources, maybe Rock Auto? You can get the master locally too. The master on Hydra Tech's site is #MC8144 http://www.hydratechbraking.com/mastercylinders.html
70 'cuda: ProCharged 408, Tremec 5 speed, S60,triangulated 4 link, Hydroboost and Wilwoods
Re: Hydraulic brake assist system [Re: Bob J] #2204335
11/29/16 11:31 AM
11/29/16 11:31 AM
CJD AUTOMOTIVE Offline
You have no pedal "feel" with a hydroboost. It will be next to impossible to modulate the pedal on the threshold of lockup. Do your calcs right, piston area for MC bore, pedal ratio, and you'll have phenomenal manual brakes.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: Hydraulic brake assist system [Re: CJD AUTOMOTIVE] #2204355
11/29/16 12:02 PM
11/29/16 12:02 PM
Colorado
Bob J Offline OP
Bob J  Offline OP
Colorado
This is the information that I was looking for. It looks like I need to start with manual brakes and I can see how it goes. I can look at the pads that have more bite also but.
Re: Hydraulic brake assist system [Re: Bob J] #2204452
11/29/16 02:48 PM
11/29/16 02:48 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I sent Wilwood what brakes I was buying along with details on the car. Intended use, tire diameter, weight, estimated weight distribution, pedal ratio, etc and they provided me with a recommended manual master. We will see how it works out.
2020 RAM 1500
Re: Hydraulic brake assist system [Re: Bob J] #2204473
11/29/16 03:17 PM
11/29/16 03:17 PM
Coronado, CA
go-fish Offline
go-fish  Offline
Coronado, CA
I feel like
Re: Hydraulic brake assist system [Re: Bob J] #2204474
11/29/16 03:19 PM
11/29/16 03:19 PM
Coronado, CA
go-fish Offline
go-fish  Offline
Coronado, CA
Where I need to be headed
Re: Hydraulic brake assist system [Re: CJD AUTOMOTIVE] #2217848
12/20/16 04:26 PM
12/20/16 04:26 PM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
Now there is some misinformation! This feel is really dependent upon the correct caliper piston diameters. I love this unit and have used on 2 cars that see the track regularly.
Re: Hydraulic brake assist system [Re: Bob J] #2218048
12/20/16 10:42 PM
12/20/16 10:42 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
This could help you a lot with manual brake sizing.
http://www.jakelatham.com/radical/info/brake_calculators.shtml
Without knowing your piston sizes or the pedal ratio, I don't really know where you'll end up. It really depends on how much stopping force you want for the pedal force, but I am guessing you'd end up with a 7/8" master cylinder.
Using just general rules of thumb, I would start with 1g decel at 100 lb pedal force.
I ran my car with my plan of 6.25:1 aftermarket pedals, the cobra braking system, .45 pad mu, and 100 lb pedal force for 1g decel and ended up with a 3/4 bore master cylinder and about the same pedal travel as my current 11.75" cordoba brake system with a 15/16 master cylinder...which is mostly likable, but the pedal force for a good amount of decel is still quite high.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Hydraulic brake assist system [Re: BergmanAutoCraft] #2218090
12/20/16 11:35 PM
12/20/16 11:35 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
Yes, totally agree. On track regularly and it provides the best of both worlds for being aggressive at the track and cruising on the street. It will definitely let you know if if your pistion diameter balance is off, but all the more reason to get it right.
1968 Pro-Touring Dodge Charger
*2011 Optima Ultimate Street Car Challenge Invitee
http://www.popularhotrodding.com/features/1203phr_1968_dodge_charger/index.html
