ARP Main Stud Torqu Spec? #220279
02/10/09 04:21 PM
02/10/09 04:21 PM
Thigh-Gap Junction
@#$%&*! Offline OP
New user name, Same old jerk!
@#$%&*!  Offline OP
Thigh-Gap Junction
What torque spec is used for these? I can't seem to find my notes on that or the box they came in last year. I sent a message to ARP and the reply was 100ft-lbs with moly and 130 with oil but that sounds high to me. Factory spec is 85. Engine is a B with BCR aluminum caps.
Re: ARP Main Stud Torqu Spec? [Re: @#$%&*!] #220280
02/10/09 05:17 PM
02/10/09 05:17 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
that's what they call for but i would also like to know if that's the way they were tightened when it was align bored/honed
Re: ARP Main Stud Torqu Spec? [Re: @#$%&*!] #220281
02/10/09 05:21 PM
02/10/09 05:21 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
7/16 ARP Main Studs are suppose to 90lbs according to the sheet that came with my studs. Is that the size you have?
Re: ARP Main Stud Torqu Spec? [Re: Defbob] #220282
02/10/09 05:43 PM
02/10/09 05:43 PM
jamesc Offline
jamesc  Offline
main studs are 1/2" and above
Re: ARP Main Stud Torqu Spec? [Re: jamesc] #220283
02/10/09 05:44 PM
02/10/09 05:44 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
your right, the head studs are 7/16
Re: ARP Main Stud Torqu Spec? [Re: @#$%&*!] #220284
02/10/09 05:48 PM
02/10/09 05:48 PM
Thigh-Gap Junction
@#$%&*! Offline OP
@#$%&*!  Offline OP
Thigh-Gap Junction
First, thanks to everyone who responded. Even thought I searched for quite a while yesterday, I found my paperwork today. The machinist who installed the cap/girdle setup said 90 w/ARP moly so that's what I'll use unless someone can convince me 100 would be better. I don't think another 10ft-lb would distort the bore but what do I know, I haven't done any testing.
Re: ARP Main Stud Torqu Spec? [Re: @#$%&*!] #220285
02/11/09 12:16 AM
02/11/09 12:16 AM
Wichita,KS
Blakcharger440 Offline
Wichita,KS
My ARP sheet says 90lbs with moly also. It also says to install the studs into the block by hand tightening them.
Re: ARP Main Stud Torqu Spec? [Re: @#$%&*!] #220286
02/11/09 03:11 PM
02/11/09 03:11 PM
NC
440Jim Offline
440Jim  Offline
NC
I am running the BB Mopar ARP main studs with aluminum caps in my B engine. They were machined, and I torqued them during assembly to 90 ft-lbs with ARP moly lube. The machinist actually stamped that on the block.
Re: ARP Main Stud Torqu Spec? [Re: 440Jim] #220287
02/11/09 03:20 PM
02/11/09 03:20 PM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
I don't want to steal this thread but does anybody know what it is on a small block with ARP studs? These are billet steel caps, middle are splayed.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: ARP Main Stud Torqu Spec? [Re: Blakcharger440] #220288
02/11/09 03:45 PM
02/11/09 03:45 PM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
I don't know if I got an 'old' box or a new one but the ARP main stud kit I just installed had an instruction sheet that said 100 ftlbs with ARP lube or 130 ftlbs with 30wt oil (big block) .
Re: ARP Main Stud Torqu Spec? [Re: @#$%&*!] #220289
02/11/09 03:47 PM
02/11/09 03:47 PM
NC
chris3 Offline
chris3  Offline
NC
The torque of the ARP studs appears to be a mystery. I have the studs in both mains and heads on a small block. I also could not get what I felt was solid answers. I contacted ARP and discussed the various torques with there Technical Rep. The torque of 90 foot pounds is using their special lube. This product reduces the friction between the nut, threads on the stud and the block; therefore, less effort for the required clamping force. Using engine oil they recommend the higher torque meaning you have to put more effort to achieve the same clamping force. I don't know that this will clear up every question but I torque mine to what I was told and we shall see.
