which intake for 500cid wedge and shaker hood?
#2202484
11/25/16 06:16 PM
11/25/16 06:16 PM
Posts: 1,794 BC Canada
ogopogo
BC Canada
Which is the best aftermarket rb intake to use on a cuda with factory shaker? im tired of messing around with my 6bbl and want to try a single 4. I will likely use my fiteck setup as well......engine is 505cid with ported eddy heads roller cam stock compression
Re: which intake for 500cid wedge and shaker hood?
[Re: Lee446]
#2202545
11/25/16 08:08 PM
11/25/16 08:08 PM
ogopogo
BC Canada
[Re: frank]
#2204485
11/29/16 03:41 PM
11/29/16 03:41 PM
Posts: 9,870 Weddington, N.C.
Streetwize
Weddington, N.C.
for 500" a PORTED Street Dominator. Worth at least .10-.15 over an unported one.
The Indy 440-2D is another good choice, but the lower plenum needs some radius work in the runners to get it to flow with the upper. The Performer RPM is a great manifold, but too tall unless you run a drop base air cleaner.
The MP 337 is listed as a Max Wedge but the head mating port size as delivered is really about 1/2 way between a standard 906 size port and a true Max Wedge...probably could make it work and it's a nice flowing manifold.
[Re: ogopogo]
#2204539
11/29/16 04:48 PM
11/29/16 04:48 PM
crabman173
crabman173
I have used the SD with air grabber on a 1970--worked out well--It acts like a governor on a well done 500 CI though--easy 570 and up HP any way you do it though and that will make most folks smile SD is easily available and works way better than you would think by looking at it and..pretty cheap
[Re: ogopogo]
#2204808
11/29/16 11:24 PM
11/29/16 11:24 PM
Posts: 11,996 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I had an Indy intake and Dominator carb under my Shaker. Dropped the K about 5/8", fabbed a drop base into the Shaker base, and eventually made a new air cleaner lid out of fiberglass that almost touched the inside of the Shaker bubble.
With those mods, you could run 'most any intake you want. And set the Shaker bubble height in the hood the way it should be rather than just accept the way it ends up.
Master, again and still
