Re: tricks to reduce drag on stock a-body discs? [Re: dirtybee] #220070
02/11/09 04:24 PM
02/11/09 04:24 PM
organ
maximum entropy Offline
Happy Birthday maximum entropy  Offline
organ
you also may want to try rebuilding your calipers. old seals can cause alot of drag when they lose their elasticity, which is what minimizes drag. made a huge difference on mine!
Re: tricks to reduce drag on stock a-body discs? [Re: Paul_Fancsali] #220071
02/11/09 05:27 PM
02/11/09 05:27 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
My 4 piston disc brakes feel like unadjusted drums bet you have a piston or hanging up
the OP does not have a 4 piston setup , single piston slider and the slider is casting on casting .
Re: tricks to reduce drag on stock a-body discs? [Re: JohnRR] #220072
02/11/09 06:57 PM
02/11/09 06:57 PM
Toronto, Canada
dirtybee Offline OP
dirtybee  Offline OP
Toronto, Canada
that's right single piston sliders and it's still fairly new but maybe it warrents a check on the seals and i wonder if smoothing down and lubing the casting to casting contact again would help some. anyways thank again all for the input.
Re: tricks to reduce drag on stock a-body discs? [Re: dirtybee] #220073
02/12/09 10:42 AM
02/12/09 10:42 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
maybe you should try to find a set of the pin type caliper adaptors and switch calipers so you can try the spring trick ? the problem with lubing the sliders is you don't want the lube getting on the brakes .
