Help me on - Nitrous Tuning #219849
02/10/09 11:13 AM
02/10/09 11:13 AM
Sao Paulo, Brazil
dart_73_br Offline OP
Sao Paulo, Brazil
Hi guys.. I wish you could help me defining some things in my Nitrous project.
Engine setup:
- 318 SB
- 2.02/1.60 ported J heads
- KB forged pistons (~11 CR)
- Scat H-Beam connection rods
- ARP main and Head studs
- 1.6 roller rockers
- Comp Cams XE284H cam 240/246 @.050
- Edelbrock Torker 2 with injector bungs
- EFI Megasquirt with 8 injectors
- Innovate LM-1 wideband O2 sensor
- 3.73 gears + ladder bars
The engine will run on ethanol. Wishing to make 400~450 hp + a 200~250 shot.
Iīve got a NOS 8 fogger Sportsman nitrous kit but also has a plate.
Questions:
1 - Should I use fogger or the plate ? I know the plate will have an easier installation... but foggers will distribute better the nitrous;
2 - Run the nitrous on ethanol or gasoline !? My engine will run on ethanol;
3 - How to tune the engine on nitrous. I will start with a 100hp shot. Then increase to 150hp, then 200hp. As I have a wideband sensor I think it will be easier. What I think itīs to tune the engine without the nitrous, then pull the shot and see the wideband logs. If the engine got rich, lean the mixture, if got lean enrich it. Is it right !? My EFI also can retard the timing. I think I should retard 2š every 50hp shot right !?
Could you give me more tips !?
BR,
Fernando
Re: Teach me on - Nitrous Tuning [Re: dart_73_br] #219850
02/10/09 05:12 PM
02/10/09 05:12 PM
UK
602heavy Offline
602heavy  Offline
UK
Tune the motor on the plugs , nothing else comes close , drop to a colder plug & tune from there.
Re: Teach me on - Nitrous Tuning [Re: 602heavy] #219851
02/10/09 06:04 PM
02/10/09 06:04 PM
Sao Paulo, Brazil
Sao Paulo, Brazil
From the plugs... I have a wideband O2 sensor...
Re: Teach me on - Nitrous Tuning [Re: dart_73_br] #219852
02/10/09 06:22 PM
02/10/09 06:22 PM
UK
602heavy Offline
602heavy  Offline
UK
You wanna tune that way fine , stock up with some spare parts.
Re: Teach me on - Nitrous Tuning [Re: 602heavy] #219853
02/11/09 01:26 PM
02/11/09 01:26 PM
Sao Paulo, Brazil
Sao Paulo, Brazil
No more opinions !?
Re: Teach me on - Nitrous Tuning [Re: dart_73_br] #219854
02/11/09 02:42 PM
02/11/09 02:42 PM
Colorado
506RR Offline
506RR  Offline
Colorado
Contact Monte Smith here on the board. He is the nitrous guru! He will be able to give you some baseline tunes, and help you with the tuning process.
Re: Teach me on - Nitrous Tuning [Re: 506RR] #219855
02/12/09 05:44 PM
02/12/09 05:44 PM
Sao Paulo, Brazil
Sao Paulo, Brazil
Yeah, I have contacted Monte but got no answer until now.
Come on... no more nitrous tuners or.... this is like that little secrets that people donīt want to tell ?
Re: Teach me on - Nitrous Tuning [Re: dart_73_br] #219856
02/14/09 04:48 AM
02/14/09 04:48 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Been out of town, but will try and post some info later.
Monte
