Page 6 of 12 1 2 4 5 6 7 8 11 12
Re: 340sb with 5 speed conversion? [Re: Clair_Davis] #33013
05/28/08 06:01 PM
05/28/08 06:01 PM
Germany, Northcoast
Buschi340 Offline OP
Germany, Northcoast
maybe this is better. They circle is near a hole which was plugged with a rubber. I routed my starter cable thru this...
Re: 340sb with 5 speed conversion? [Re: Buschi340] #33014
05/29/08 08:18 AM
05/29/08 08:18 AM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
Ah yes, that's the plug. On the original MT cars, a small rubber boot goes over the hole and the clutch pedal rod goes through there to the torque shaft (z-bar). If you can get the MC lined up with that hole, it should be nearly ideal. I need to look at another Dakota to see if the angle makes sense. I hope that the pushrod on the MC is long enough to reach the clutch pedal. I also hope that the clutch pedal provides enough stroke to activate the slave properly, but not so much that we need to put a stop on the pedal...
Clair
Re: 340sb with 5 speed conversion? [Re: Buschi340] #33015
05/29/08 03:28 PM
05/29/08 03:28 PM
Spokane, WA
48Heap Offline
48Heap  Offline
Spokane, WA
back to the process.
Built a custom tranny x member.
Very nice. I see a lot of similarities, but I like your's better.
15 Chrysler 200S 3.6
15 Challenger R/T 6M STP
74 Duster 360 -> original 4 speed car
a.k.a. DionR
Re: 340sb with 5 speed conversion? [Re: 48Heap] #33016
05/29/08 05:47 PM
05/29/08 05:47 PM
Germany, Northcoast
Germany, Northcoast
Thanks a lot!
both is not a problem, requires just a new bolt on the pedal for the M/C rod.
I'm more concerned about the space in the engine bay. I don't want to cut the fender. But if I have to... Maybe I can turn the m/c a bit in 1 o'clock position....
Will try Sunday, tomorrow I receive my probshaft with the Toyota Yoke.
Re: 340sb with 5 speed conversion? [Re: Buschi340] #33017
05/29/08 11:20 PM
05/29/08 11:20 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
Maybe a 2nd Gen Viper MC from McLeod?? Looks like it needs a couple details, but it's straight - and Mopar-ish...
Clair
Re: 340sb with 5 speed conversion? [Re: Clair_Davis] #33018
05/30/08 06:18 PM
05/30/08 06:18 PM
Germany, Northcoast
Germany, Northcoast
m/c is in (but not connected yet). There was a "little" denting requiered.
the m/c rod is in deed to short, Clair. But I'm gonna fix this tommorrow.
Re: 340sb with 5 speed conversion? [Re: Buschi340] #33019
05/30/08 06:18 PM
05/30/08 06:18 PM
Germany, Northcoast
Germany, Northcoast
another... maybe a stupid question but how do you bleed this???
Re: 340sb with 5 speed conversion? [Re: Buschi340] #33020
05/30/08 10:48 PM
05/30/08 10:48 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
I don't know what you can do - if anything - to bleed that master/slave. Looks like a nice install, though. Very factory looking, nice and clean. I need to go out to the salvage yard again and see if I can find a decent mock-up part for my swap. I'm curious to see how you handle the extra length on the push rod.
Clair
Re: 340sb with 5 speed conversion? [Re: Clair_Davis] #33021
05/31/08 12:35 AM
05/31/08 12:35 AM
Spokane, WA
48Heap Offline
48Heap  Offline
Spokane, WA
My bet is it is self bleeding, just pump it until it works.
But that's just my guess.
a.k.a. DionR
Re: 340sb with 5 speed conversion? [Re: 48Heap] #33022
05/31/08 05:55 AM
05/31/08 05:55 AM
Germany, Northcoast
Germany, Northcoast
hm, and how do you change the fluid? There is no outlet...
Re: 340sb with 5 speed conversion? [Re: Clair_Davis] #33023
05/31/08 05:58 AM
05/31/08 05:58 AM
Germany, Northcoast
Germany, Northcoast
Clair, I'm welding a bracket on the Pedal today with a new mountig point for the pushrod. I'll show it to you when done...
Re: 340sb with 5 speed conversion? [Re: Buschi340] #33024
05/31/08 11:20 AM
05/31/08 11:20 AM
Germany, Northcoast
Germany, Northcoast
it is very important to find the right angle to make sure that the pushrod goes the whole way ... as pivot I used a M10 Bolt, welded in..
Re: 340sb with 5 speed conversion? [Re: Buschi340] #33025
06/02/08 06:01 PM
06/02/08 06:01 PM
Germany, Northcoast
Germany, Northcoast
aaah, server is up again so I can continue with spamming pics...
Pedal Assy is in again.
Re: 340sb with 5 speed conversion? [Re: Buschi340] #33026
06/02/08 06:02 PM
06/02/08 06:02 PM
Germany, Northcoast
Germany, Northcoast
another one...
Re: 340sb with 5 speed conversion? [Re: Buschi340] #33027
06/02/08 06:09 PM
06/02/08 06:09 PM
Germany, Northcoast
Germany, Northcoast
ok, I had a little time while waiting for clutch parts so I took care of the shifter. I had an old Hurst stick which I welded on the cutted Toyo stick.
Re: 340sb with 5 speed conversion? [Re: Buschi340] #33028
06/02/08 06:12 PM
06/02/08 06:12 PM
Germany, Northcoast
Germany, Northcoast
first pic is in second gear. Pretty close to the bench, huh?
This one is in first gear...
Re: 340sb with 5 speed conversion? [Re: Buschi340] #33029
06/02/08 06:15 PM
06/02/08 06:15 PM
Germany, Northcoast
Germany, Northcoast
ok, this one shold be the last (for today). It is the driveshaft. The slipyoke, joint and front part of the shaft is stock Toyota. Welded on the Dodge Shaft....
Re: 340sb with 5 speed conversion? [Re: Buschi340] #33030
06/02/08 11:07 PM
06/02/08 11:07 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
Looks just about perfect to me - as long as the shifter isn't hitting the seat or the dash, it's doing well. The shifter throw appears to be nice and short, as you'd suspect from a modern transmission.
Nice work, Michael!
Clair
Re: 340sb with 5 speed conversion? [Re: Clair_Davis] #33031
06/26/08 07:34 PM
06/26/08 07:34 PM
Germany, Northcoast
Germany, Northcoast
The only way to get rid of air in the system is a complete diassembly...
Re: 340sb with 5 speed conversion? [Re: Buschi340] #33032
06/26/08 07:43 PM
06/26/08 07:43 PM
Germany, Northcoast
Germany, Northcoast
thats how it looks now. Clutch is in, Tranny is bolted on so far. I have to check the hydraulic now...
