Re: Disc brakes on Duster 340's
[Re: Three40]
#2195226
11/12/16 04:04 PM
11/12/16 04:04 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
I had 2 '72 340 Dusters, both had drum.
The '72 window sticker has a high serial number. It's possible (pure speculation) that late in the '72 production run there were more disc spindles in stock than drum. Maybe Chrysler was trying to use up the extra disc spindles by making them std on the late production '72 340 models. Both spindles were not needed for '73 production as the drum and disc spindles were different along with the upper A-arm.
edit; RAII, you not doing yourself any favors with your sig line.
[Re: Cab_Burge]
#2195232
11/12/16 04:15 PM
11/12/16 04:15 PM
Posts: 222 Massachusetts
RAII4-speed
Massachusetts
Let see, your asking about this on this forum on the internet, why Just trying to get the correct answers ... That simple. Barry Washington --- Your thoughts and remarks are not welcome on my posts. Thanks in advance.
[Re: formula_s]
#2195233
11/12/16 04:16 PM
11/12/16 04:16 PM
RAII4-speed
Massachusetts
Why the hardon for Barry? I would never dishonor him on a public forum .... I also do not want his opinion ..... If you must know, PM me... Barry Washington --- Your thoughts and remarks are not welcome on my posts. Thanks in advance.
[Re: B5 Bee]
#2195236
11/12/16 04:19 PM
11/12/16 04:19 PM
RAII4-speed
Massachusetts
edit; RAII, you not doing yourself any favors with your sig line. I am looking for concrete answers .... As far as my sig line , PM me I will explain.... Barry Washington --- Your thoughts and remarks are not welcome on my posts. Thanks in advance.
[Re: Three40]
#2195245
11/12/16 04:43 PM
11/12/16 04:43 PM
Posts: 17,507 Las Vegas, NV
6bblgt
Las Vegas, NV
the 1972 dealer code book shows power brakes & disc brakes to be OPTIONAL on Duster 340 but, it must have been confusing enough for someone to write "optional" on the copy I have I have a b'cast sheet for a 11/24/71 - SPD, US spec. HAMTRAMCK Duster 340 - it is coded "B11" - drum brakes here's a copy of a window sticker for a 12/12/71 - SPD, US spec. HAMTRAMCK Duster 340 - it states "power disc brakes" - STANDARD IMO questions were probably raised why the disc brakes were no longer STANDARD & a change was made during the 1972 Duster 340 model year late-November or early-December (based on the few pieces of info in this thread)
[Re: RAII4-speed]
#2195248
11/12/16 04:53 PM
11/12/16 04:53 PM
6bblgt
Las Vegas, NV
OK so here are 2 window stickers from 1972 Dusters .. the first window sticker is a reproduction with errors part of the "problem" adding to the confusion
[Re: 6bblgt]
#2195249
11/12/16 04:53 PM
11/12/16 04:53 PM
RAII4-speed
Massachusetts
the 1972 dealer code book shows power brakes & disc brakes to be OPTIONAL on Duster 340 but, it must have been confusing enough for someone to write "optional" on the copy I have I have a b'cast sheet for a 11/24/71 - SPD, US spec. HAMTRAMCK Duster 340 - it is coded "B11" - drum brakes here's a copy of a window sticker for a 12/12/71 - SPD, US spec. HAMTRAMCK Duster 340 - it states "power disc brakes" - STANDARD IMO questions were probably raised why the disc brakes were no longer STANDARD & a change was made during the 1972 Duster 340 model year late-November or early-December (based on the few pieces of info in this thread THANK YOU 6BBLGT .... I had assumed exactly what you have shown but I was looking for a explanation .... SO, It now seems that a 1972 Duster could have come WITH or WITHOUT disc brakes as Standard equipment... Barry Washington --- Your thoughts and remarks are not welcome on my posts. Thanks in advance.
[Re: 6bblgt]
#2195251
11/12/16 04:54 PM
11/12/16 04:54 PM
RAII4-speed
Massachusetts
OK so here are 2 window stickers from 1972 Dusters .. the first window sticker is a reproduction with errors part of the "problem" adding to the confusion AND I found that on this Site .... Barry Washington --- Your thoughts and remarks are not welcome on my posts. Thanks in advance.
[Re: RAII4-speed]
#2195257
11/12/16 05:05 PM
11/12/16 05:05 PM
Posts: 2 Ca
branded
Ca
