Re: Project VIP to drag week 2017
[Re: jyrki]
#2368780
09/11/17 12:41 PM
09/11/17 12:41 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
It's easy to sit here and "Monday morning quarterback" this situation...... But what came to my mind was that perhaps this is a by-product of whatever the previous valvetrain issue that was causing the retainer and lock problems(unless new valves have been installed since that all happened).
[Re: jyrki]
#2368798
09/11/17 01:36 PM
09/11/17 01:36 PM
Posts: 2,255 IL
furious70
IL
it's a turbo big block, but I've lost track of what this incarnation is. It's been turbo'ed for close to a decade I think.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: jyrki]
#2368846
09/11/17 03:00 PM
09/11/17 03:00 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Really glad to hear the car is back together. I think it is a brewer head combo, and when I heard he broke a valve.... well it didn't seem likely he would get it back into one piece.
[Re: jyrki]
#2369211
09/12/17 02:31 AM
09/12/17 02:31 AM
Posts: 2,932 Finalnd, Perkele
jyrki
Finalnd, Perkele
Thanks all! Even though we have had some bad luck, we have also had good. For example, we went to Cordova on saturday and broke it there. Had we come there on sunday, we would not have had time to repair the problem. I do not know what is the reason, maybe just old parts? But, I had spare parts and with the support of a local Layne machine shop we could get the job done. The other turbo was also hurt because some particles run through it, and it's temporarily fixed now, just turning the turbine down in a lathe. Therefore, we weren't hoping for much since we only are running with about 1.5 turbo now. So, the result was a pleasent surprise, especially bcause we had nelected tightening the throttel cable support; the throttle was only 75% up to 5.5 seconds after which it started to slip and was zero at the traps. We had and have our share of problems moving to gateway, the fan quit working and we were overheating. So, took some time to get there to the hotel, also some electrical and leak problems. They can be fixed, but it takes time and we have a lot of else to do.But most likely we will be able to make it to gateway in the morning!
Plynouth VIP '67 TT IC EFI
[Re: jyrki]
#2369232
09/12/17 04:16 AM
09/12/17 04:16 AM
Posts: 214 Hamburg / Germany
Den300
Hamburg / Germany
Jyrki, hope you all have enough Lapin Kulta and dont fall asleep behind the wheel ;-) You guys doing an awesome Job and I love to see your fat landyacht running!
Cheers Dennis
Hamburg/Germany
69 Chrysler 300 446cui Dual Quad 12.64 @ 110.7
[Re: Roughbird72]
#2369337
09/12/17 12:21 PM
09/12/17 12:21 PM
Posts: 4,665 Wichita
GY3
Wichita
Good luck! Following you on Facebook!
[Re: jyrki]
#2369353
09/12/17 12:49 PM
09/12/17 12:49 PM
fast68plymouth
So. Burlington, Vt.
The 8.08 looked awesome from that big barge!!!
Hopefully the worst of it is behind you.
[Re: jyrki]
#2369358
09/12/17 12:53 PM
09/12/17 12:53 PM
Posts: 2,255 IL
furious70
IL
and you definitely got love from the tower commentating the live feed!
[Re: jyrki]
#2370066
09/13/17 02:21 PM
09/13/17 02:21 PM
fast68plymouth
So. Burlington, Vt.
Sucks for you guys...... But you gained some fans for sure. Impressive effort from you guys right from the start.
