Re: Project VIP to drag week 2017
[Re: jyrki]
#2325140
06/22/17 10:52 AM
06/22/17 10:52 AM
Posts: 2,254 IL
furious70
IL
I'm still very much looking forward to seeing the car!
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: jyrki]
#2330590
07/03/17 11:43 AM
07/03/17 11:43 AM
Posts: 2,932 Finalnd, Perkele
jyrki
Finalnd, Perkele
Last weekend was our last possibility to do some testing before the car must go in to the ship. Not much to tell..., problems. The valvelocks are trying to pull through the retainers. Have never run in to this kind of problem before. Anyway, we managed to run two 8.5's which at this point is satisfying. I think I'll still change the cam now in there to a custom one designed for turbo use and longevity, it just may be so that the smallish comp cams street roller costs us power. Never the less, the container comes on friday, leaves on monday and then it's too late to be sorry... Here is one video of a little less than 1/8 mile test run. https://www.youtube.com/watch?v=QNXD7wLb8YI
Plynouth VIP '67 TT IC EFI
[Re: jyrki]
#2330653
07/03/17 01:09 PM
07/03/17 01:09 PM
Posts: 7,475 Minnesota
Hemi_Joel
Minnesota
Last weekend was our last possibility to do some testing before the car must go in to the ship. Not much to tell..., problems. The valvelocks are trying to pull through the retainers. Have never run in to this kind of problem before. Anyway, we managed to run two 8.5's which at this point is satisfying. I think I'll still change the cam now in there to a custom one designed for turbo use and longevity, it just may be so that the smallish comp cams street roller costs us power. Never the less, the container comes on friday, leaves on monday and then it's too late to be sorry... Here is one video of a little less than 1/8 mile test run. https://www.youtube.com/watch?v=QNXD7wLb8YI Good luck! Is it possible that the valve train issue could be caused by coil bind?
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: jyrki]
#2330671
07/03/17 01:31 PM
07/03/17 01:31 PM
jyrki
Finalnd, Perkele
It's not a coil bind, There is more room with the current cam than with the old one when the problem arose, just left the inner spring out for about 260 lbs seat pressure. The cam card says 140 lbs, so there should have been plenty for it. Unless you have to take the boost in to account somehow..., but previously for the last ten years or so we have not had such problems.
[Re: jyrki]
#2330678
07/03/17 01:48 PM
07/03/17 01:48 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
10degree retainers with 7degree locks? Seen that one before.
[Re: jyrki]
#2330808
07/03/17 06:21 PM
07/03/17 06:21 PM
jyrki
Finalnd, Perkele
The locks are/were correct for the retainers.
[Re: jyrki]
#2331176
07/04/17 04:20 AM
07/04/17 04:20 AM
Posts: 6,558 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
It's not a coil bind, There is more room with the current cam than with the old one when the problem arose, just left the inner spring out for about 260 lbs seat pressure. The cam card says 140 lbs, so there should have been plenty for it. Unless you have to take the boost in to account somehow..., but previously for the last ten years or so we have not had such problems. Isn't there a problem sometimes with spring surge if you are too far away from coil bind? I think a spring designed to run as a dual configuration might also do weird things at speed if you removed the inner. If it's doing that it might explain why it's eating retainers. Kevin
[Re: jyrki]
#2331205
07/04/17 09:28 AM
07/04/17 09:28 AM
Posts: 8,018 Tulsa OK
Bad340fish
Tulsa OK
Thats true, while your spring pressure might be right for your camshaft it could still be the wrong spring for the job. I have done Drag week 5 times, valve train is one of the number one reasons for failures on the road, I would make a call to one of the spring companies and have some new springs waiting for you to install when you get to the U.S.
68 Barracuda Formula S 340
[Re: jyrki]
#2360982
08/28/17 02:32 AM
08/28/17 02:32 AM
jyrki
Finalnd, Perkele
Small, short update. The car is now in SC, and the custom duties should be done today. We will leave on thursday, fly to Atlanta and drive to SC. We have a trailer there that we can use, it needs some fixing first... We don't have a puller for the trailer, and have no idea of where to rent one. Once we get that fixed we'll drive to Illinois where we can use a shop and make some changes to the car. We have a new converter from PTC that we are going to try, and Scott Brown has made us a new cam and the valvetrain parts to support it. Then, on wednesday if the car is ready, we should have a chance to test at Gateway with the Rocket brand fuel. If all goes well we should be ready for the Drag Week in time!
[Re: jyrki]
#2360988
08/28/17 02:45 AM
08/28/17 02:45 AM
Hemi_Joel
Minnesota
You've come a long ways and overcome a lot of hardships. Good luck to you on completing drag week. I'll see you there!
[Re: jyrki]
#2360997
08/28/17 03:25 AM
08/28/17 03:25 AM
jyrki
Finalnd, Perkele
...and to continue the list we don't have yet, but would like to; a small compressor, aggregate and a small welder. Don't know if they can be rented or do we have to buy them.
[Re: jyrki]
#2361139
08/28/17 01:51 PM
08/28/17 01:51 PM
Triple Threat
Renton Washington
...and to continue the list we don't have yet, but would like to; a small compressor, aggregate and a small welder. Don't know if they can be rented or do we have to buy them. You're likely better off to buy them and sell them when you're done. Rental fees add up quickly.
[Re: jyrki]
#2361172
08/28/17 02:55 PM
08/28/17 02:55 PM
Posts: 2,254 IL
furious70
IL
where in IL will you be working on the car, down by gateway I imagine?
[Re: jyrki]
#2361256
08/28/17 06:19 PM
08/28/17 06:19 PM
Posts: 14,491 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I'm looking forward to watching you guys run on the live feeds!!
I hope your adventure on Drag Week goes well!!
[Re: jyrki]
#2365682
09/05/17 10:53 AM
09/05/17 10:53 AM
jyrki
Finalnd, Perkele
A small update, we flew over last thursday, then after fixing the trailer pulled the car from south carolina to Jerseyville Illinois. While running down the highway on sunday, we saw that there was a drag racing going on and stopped at I 57 dragstrip to eat and meet people, it was a pleasure! Then we arrived to family Teppens farm and started to work on the car in their gorgeous garage. Worked until 3.30 AM and then started the trip to Indianapolis where we spent the mo day watching US nationals. Now on our way back to continue working on the car. The cam, valvetrain and converter has been changed but there is still acessories etc to put together. Then change the fluids and it should be ready to start. We have a minor problem with the driving tires..., seems that I ordered 16" tire and 15" wheels. We have to try figure that out, maybe it would be easier to find tall 15" tires than to find 16" wheels with 2" backspacing. Still don't have the aggregate, and have to still buy some basic tools for the trip, but otherwise about everything is there, except the hitch and the u-haul trailer. If all goes well we'll should be testing at Gateway drag strip on wednesday. Finlands biggest tabloid is following our trip and we try to make them about 3 minute broadcast everyday (if we have time to edit one), here is the latest. http://www.is.fi/autot/art-2000005352845.html
[Re: jyrki]
#2365708
09/05/17 11:44 AM
09/05/17 11:44 AM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
Awesome, looking forward to checking out the car next week!
A new iron curtain drawn across the 49th parallel
[Re: jyrki]
#2365738
09/05/17 12:43 PM
09/05/17 12:43 PM
Posts: 667 IL
Dart451
IL
