A Quick Question On Main Studs . #219003
02/09/09 05:42 PM
02/09/09 05:42 PM
Renton, Wa.
Classof70Chally Offline OP
super gas
super gas
Renton, Wa.
I am beginning to assemble my short block (446) and had a quick question on my main studs. I will be using the ARP lube on the stud nuts but what, if anything, should be used on the stud threads into the block? Thanks.
Re: A Quick Question On Main Studs . [Re: Classof70Chally] #219004
02/09/09 06:16 PM
02/09/09 06:16 PM
organ
maximum entropy Offline
Happy Birthday maximum entropy  Offline
organ
maybe some oil to prevent corrosion? that's all i ever do. i've used eau de 40. just a little. don't wanna hydro lock the stud.
Re: A Quick Question On Main Studs . [Re: maximum entropy] #219005
02/09/09 07:01 PM
02/09/09 07:01 PM
Renton, Wa.
super gas
super gas
Renton, Wa.
All the instructions say is you can use Loctite if you want the stud install to be 'permanent'. I think I'll just use a bit of motor oil. I'm doing this now BTW so if anyone else wants to chime in feel free to do so.
Re: A Quick Question On Main Studs . [Re: Classof70Chally] #219006
02/09/09 07:38 PM
02/09/09 07:38 PM
organ
organ
loctite can cause problems if it cures without a load on the stud. i don't think it's recommended. maybe one of the "heavies" could chime in?
Re: A Quick Question On Main Studs . [Re: Classof70Chally] #219007
02/09/09 07:42 PM
02/09/09 07:42 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
oil them and thread them in by hand. make sure to check the center cap and thrust. sometimes you need to enlarge the hole in the center cap to allow the cap to move to align the cap properly.
Re: A Quick Question On Main Studs . [Re: jamesc] #219008
02/09/09 08:57 PM
02/09/09 08:57 PM
Renton, Wa.
super gas
super gas
Renton, Wa.
Yep. That's what I ended up doing. Thanks for the reminder on the thrust clearance. I assume the value given in the manual will do ? Just checked the end play on #3 bearing. The book says .002 to .007 and I've got a tight .005 so I guess that part's good to go.
Re: A Quick Question On Main Studs . [Re: Classof70Chally] #219009
02/10/09 12:33 AM
02/10/09 12:33 AM
Renton, Wa.
super gas
super gas
Renton, Wa.
BTTP
Re: A Quick Question On Main Studs . [Re: Classof70Chally] #219010
02/10/09 12:44 AM
02/10/09 12:44 AM
I use oil and finger tight only on all the studs I use in Mopar motors. Not so on the other brands of motors that need thread sealer on the studs to prevent water leakage
