Anyone running a steeeing quickener? #2189387
11/04/16 01:00 PM
11/04/16 01:00 PM
Texas
GoodysGotaCuda Offline OP
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I talked with Hotchkis at SEMA and they mentioned that they were using a steering quickener on the yellow Challenger. Is anyone aware of one that would be the least drama to install in an Ebody with a Borgeson box?
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Anyone running a steeeing quickener? [Re: GoodysGotaCuda] #2189433
11/04/16 01:56 PM
11/04/16 01:56 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have seen circle track cars with them. The one I saw was installed on the inline with the steering shaft. I am not sure where you would squeeze one on a real car.
68 Barracuda Formula S 340
Re: Anyone running a steeeing quickener? [Re: GoodysGotaCuda] #2189790
11/05/16 12:16 AM
11/05/16 12:16 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
I think Tom might have one in his AMX.
Re: Anyone running a steeeing quickener? [Re: GoodysGotaCuda] #2189878
11/05/16 04:53 AM
11/05/16 04:53 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I have under dash pics of it.
Re: Anyone running a steeeing quickener? [Re: GoodysGotaCuda] #2189937
11/05/16 11:26 AM
11/05/16 11:26 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
why would you? I have fast ratio arms with a boregson box and its just under 2 turns lock to lock
Re: Anyone running a steeeing quickener? [Re: GoodysGotaCuda] #2190053
11/05/16 02:27 PM
11/05/16 02:27 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Because fast ratio arms aren't compatible with every combination of headers and if you start moving the engine around, it complicates things even further.
Plus they are a lot less expensive.
Re: Anyone running a steeeing quickener? [Re: GoodysGotaCuda] #2190141
11/05/16 05:15 PM
11/05/16 05:15 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Steering quickeners aren't small either
Soem dimensions and options to look at
http://www.speedwaymotors.com/Shop/Steering-Shaft-U-Joints-and-Couplers-Steering-Quickeners/12.html
Don't be the exception.
Re: Anyone running a steeeing quickener? [Re: autoxcuda] #2190186
11/05/16 06:24 PM
11/05/16 06:24 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I'd love to see them, can you post pictures? Or email? Goodysgotacuda @ yahoo.com
2020 RAM 1500
Re: Anyone running a steeeing quickener? [Re: dangina] #2190187
11/05/16 06:27 PM
11/05/16 06:27 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Once I get my front end together I can evaluate how it one would work with the 3G Hemi headers.
2020 RAM 1500
Re: Anyone running a steeeing quickener? [Re: GoodysGotaCuda] #2190210
11/05/16 07:12 PM
11/05/16 07:12 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Re: Anyone running a steeeing quickener? [Re: OzHemi] #2190329
11/05/16 10:07 PM
11/05/16 10:07 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Hmm...this looks up my alley. work
Thanks!
2020 RAM 1500
Re: Anyone running a steeeing quickener? [Re: dangina] #2191646
11/07/16 06:07 PM
11/07/16 06:07 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
DANGINA -- in regards to your statement: "I have fast ratio arms with a boregson box and its just under 2 turns lock to lock"... How many turns lock-to-lock is it WITHOUT the longer fast ratio arms? In other words, by ADDING the longer fast-ratio arms, do the tires simply HIT the frame rails more quickly, thereby, CAUSING the reduced turns, lock-to-lock of "... just under 2..."?
Re: Anyone running a steeeing quickener? [Re: Mopar Mitch] #2203707
11/28/16 01:47 AM
11/28/16 01:47 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
We shall see how this works out.
2020 RAM 1500
