Anyone made their own hydro booster kit?
#218783
02/09/09 02:02 PM
02/09/09 02:02 PM
Posts: 1,523 Oakley CA
69charger440_6pa
Oakley CA
I have wanted to add a hydro-boost brake booster for some time now, but I really dont want to pay the 700-900 for a kit. Has anyone done their own? You can pick up rebuilt boosters for about $120 and possibly just have to fab up a braket or to.
So has anyone done this?
1969 Charger R/T under construction 2014 Ram 3500 Cummins 2006 Corvette Z06 2015 Corvette Z06 2014 BMW M5
Re: Anyone made their own hydro booster kit?
[Re: 69charger440_6pa]
#218786
02/10/09 12:58 AM
02/10/09 12:58 AM
Posts: 10,115 A Red State
SNK-EYZ
A Red State
There's a guy I work with that's talking about going to a Hydro-Boost setup on his 81 Trans Am. Although it's a GM, he's saying the hydro-boost off of a late model Ram (diesel) is the right part number for the conversion.
I'll see what other info he can tell me and post it.
[Re: SNK-EYZ]
#218787
02/10/09 03:14 AM
02/10/09 03:14 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
are vehicles coming from the factory with hydroboost now?
after converting my dakota from power to manual brakes, I think an appropriately sized master cylinder on a manual set-up is perfect. never before have I had the feedback I needed on just how much brake effort I am giving. with pwoer brakes, you can't feel the system at all, no matter how hard your stopping, the pedal isn't harder to press. on a manual system, the harder you want tostop, the more the pedal will "push back" for you, which allows you to really feel just how much pressure you're putting on the brakes
**Photobucket sucks**
[Re: 70Cuda383]
#218788
02/10/09 05:39 AM
02/10/09 05:39 AM
Posts: 5,888 Athens, Greece
Pyper70
Athens, Greece
Forgive my age on the subject...
What is a hydro-boost?
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: 70Cuda383]
#218790
02/10/09 11:28 AM
02/10/09 11:28 AM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
'88 and up Chevy C3500's have hydraboost, gas or diesel.
Alot of thier other SUV's and what not do too. My '02 1500HD has it and I've seen it on a '04 Tahoe as well..
[Re: PAINT IT BLACK]
#218793
02/10/09 12:26 PM
02/10/09 12:26 PM
Posts: 1,949 land of 10,000______'s
BDS871Cuda
Go the easy way and put in the electric pump. The Saturn Vue has a small and quiet pump all the way back to 2002. Junk yard might even have them for less than 1/2 of $350.
Snap your neck, mega G-force launch, is all I want!
[Re: FuryUs]
#218796
02/10/09 04:05 PM
02/10/09 04:05 PM
Pyper70
Athens, Greece
So you can't really use this hydro-boost on a vehicle that has a Vacuum booster because the cam is really lopey, runs 2 canisters AND had vacuum headlights.....right?
[Re: OzHemi]
#218798
02/10/09 04:23 PM
02/10/09 04:23 PM
Pyper70
Athens, Greece
I guess I need to see some pictures, schematics, and installation components/procedures better educate myself on this
[Re: Pyper70]
#218799
02/10/09 04:26 PM
02/10/09 04:26 PM
OzHemi
Garden Grove, CA
Next time you are in Torrance, you can check out my truck.
Basically, power steering pump to hydroboost, hydroboost to steering box. return line from each back to power steering pump. hydroboost mounts to firewall same as a brake booster would basically.
[Re: Pyper70]
#218801
02/10/09 05:07 PM
02/10/09 05:07 PM
Posts: 1,024 In the twisties
RokketRide
super gas
super gas
In the twisties
[Re: BergmanAutoCraft]
#218802
02/11/09 12:09 AM
02/11/09 12:09 AM
Posts: 7,647 Houston Texas
PAINT IT BLACK
Got a CHIP on my shoulder
Houston Texas
The old Cadillac pump that Steve is referring to was used by Volvo as well, but has not been available for years. The newer aftermarket pumps are much louder, and do not seem to have the same vacuum ability.
If you have 4 wheel disc, chances are you will need higher line pressures, which hydroboost was designed for. It is silent, and uses the power steering pump to generate pressure to operate the unit.
I should have given credit where it was due. Peter turned me on to that Caddy pump. My problem with that one is that I didn't mount it with insulators and it vibrated loudly. So I just bought the SSBC pump and used it. I sold the Caddy pump for what I bought it for on ebay for $65. I'm sure it would have worked fine, though the SSBC kit is more attractive if you care about that. The ssbc is VERY quiet btw. I am getting 24" of vacuum before it cuts off I think, so there is NO problem with functionality.
I haven't done the rear disk swap on my car yet, so I can't attest to the effectiveness there yet. I'll know this summer.
After some thought, I think I will still go with hydro boost myself on the next build just to do something different... plus I am swapping from manual brakes, so there really isn't that much of a price difference between the two. The biggest benefit to hydro would be the space saving aspect. I am running a crappy red top Optima so I can fit my electric pump on my battery tray since I didn't want to drill holes in my car (the tray is a repop and I can remove it to have it repainted if I go another direction in the future). With the hydro boost, its up on the firewall, out of the way...
I don't think you can lose either way.
