Re: Engine vacume question
[Re: emarine01]
#218702
02/09/09 01:19 PM
02/09/09 01:19 PM
Posts: 43,097 Bend,OR USA
Cab_Burge
My solid roller cam is 260@.050 on the intake and 266@ .050 on the exhaust ground on a 108 LSA installed at 106 ILC. The motor has around 6.0 inches at 800 rpm idle in gear, 8 inches at 1000 rpm out of gear. I use a 4.5 power valve in the carb
[Re: Cab_Burge]
#218703
02/09/09 01:37 PM
02/09/09 01:37 PM
Posts: 3,695 nc
emarine01
nc
My solid roller cam is [Email]260@.050[/Email] on the intake and 266@ .050 on the exhaust ground on a 108 LSA installed at 106 ILC. The motor has around 6.0 inches at 800 rpm idle in gear, 8 inches at 1000 rpm out of gear. I use a 4.5 power valve in the carb
Looks like you have more cubes than me , Is it better to go down in power valve vac or block it off & jet up?
