Re: Ring gap ?
[Re: ccdave]
#218344
02/09/09 01:09 PM
02/09/09 01:09 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Whose rings? If std Speed Pro's 1/16th or stock type moly that are file to fit I use .004/1" of bore for top and .005 for 2nd. So it ends up with .018 top, .022 second.
Re: Ring gap ?
[Re: ccdave]
#218347
02/09/09 11:57 PM
02/09/09 11:57 PM
Posts: 486 IL
knyech1
IL
See what ross says on their website for your application. That's what I did when I gapped my rings with KB pistons. They have all kinds of different gapping options for different applications and combinations there and I wouldn't think that ross would be any different.
knyech1-
'71 Sassy Grass Demon 340/904. Pump gas, 1.61 60ft, 7.439 1/8 @ 95mph, 11.824 1/4 @ 111mph
"Not too bad for a pump gas 340, full of used parts and hillbilly ported stock heads." - V.B.
'03 2500 5.9L HO 6-spd on 35's. 395hp/755ft-lb at tires.
Re: Ring gap ?
[Re: knyech1]
#218348
02/10/09 12:05 AM
02/10/09 12:05 AM
Posts: 4,673 On the parachute mount
n20mstr
WOW if you are running NA...NO nitrous why would you gap the second larger??? I am shooting 3-400 of nitrous and my current short block is gapped less on the second, not larger. Im freshening the short block now and im going to gap them the same. I have never heard of gapping it so large on the second when running NA. The reason for that is that if fuel gets trapped in the lands it has somewhere to go and avoid lifting the ring lands. IF this is a typical street strip combo, id follow the instrustions with the rings and gap them as per...
....BAD A$$ STREET CAR.....
Re: Ring gap ?
[Re: dthemi]
#218350
02/10/09 12:20 AM
02/10/09 12:20 AM
Posts: 43,118 Bend,OR USA
Cab_Burge
dthemi, I removed all the second rings from my first NHRA Hemi stocker motor half way thru the season. the car didn't go any faster or quicker but the car smoked from then on until I rering the motor. That was with a set of file to fit Speed Pro moly low tension oil ring set that Speed Pro furnish us thru thier racer program. The next set of rings was a Total Seal set that they recommended installing the total seal ring on the top, they now want the two piece ring installed in the second ring location. I don't use or recommend the Total Seal ring combinations anymore due to no increase in power or performance. Lots of tricks and rumors out there, some work and some don't
Re: Ring gap ?
[Re: dthemi]
#218351
02/10/09 12:51 AM
02/10/09 12:51 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Darren, I'm sure you have checked the ring gap on a engine after its been dyno'd, what king of increase did you see after(we will say 10-15 pulls)
