Re: Rustproof Brake lines?
[Re: tdmoparguy]
#2183312
10/26/16 10:06 PM
10/26/16 10:06 PM
Posts: 5,754 ohio
ruderunner
ohio
Yes, various OE manufacturer have. The big problem is at the fittings, there's no viable way to make the flares without breaking the coating.
I prefer CuNi line but they are strictly bend your own currently.
CuNi is dot approved (mil spec in many cases) has been used by Volvo since at least the 80's (and still looks factory new) is easy to work with.
If you don't mind roll your own and don't need a steel appearance, this is the cats meow!
Angry white pureblood male
[Re: tdmoparguy]
#2183320
10/26/16 10:15 PM
10/26/16 10:15 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Well, if he's considering the line int he link then he's obviously thinking of rolling his own.
CuNi is probably the best choice overall.
[Re: tdmoparguy]
#2183678
10/27/16 11:52 AM
10/27/16 11:52 AM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
The old style flaring tools will tater the finish. Like my Blue Point unit I bought in the 70's. The newer units, like the Eastwood, don't harm the finish. My boss has one of those. Got to try it out on some of the tubing you get from NAPA that has a coating and it came out [censored]. Something I need for my own stash plus you can get it for AN 37*.
Carl Kessel
[Re: tdmoparguy]
#2186509
10/31/16 10:06 AM
10/31/16 10:06 AM
Supercuda
About to go away
About to go away
up yours
You do realize your link is not prebent brake lines, they are bend it your self ones.
