window mechanism spring #2180652
10/23/16 01:21 AM
10/23/16 01:21 AM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
I've been cleaning up all the door mechanisms and tracks. Everything was going fine until just now. I pulled one of the mechanisms out of the EvapoRust and the large spring is broken. It was still intact when it went in the dip. It's still hanging on by a thread but I expect it to be in two pieces by morning.
What can I do? Can I replace the spring without having to disassemble the mechanism? Can I even get a replacement spring? Or, do I have to buy a different mechanism?
Dumb question, could the spring be welded? The break is towards the end.
The mechanisms are in really good shape...the springs were just super rusty. This is on a 68 Dart convertible if it matters. THanks
Re: window mechanism spring [Re: burdar] #2180665
10/23/16 01:38 AM
10/23/16 01:38 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
A used mechanism shouldn't run you more than $30.. Welding the spring is out - they just break in a different spot close to the weld. Replacing the spring probably isn't worth the hassle - just buy another mechanism.
Re: window mechanism spring [Re: burdar] #2180771
10/23/16 11:44 AM
10/23/16 11:44 AM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Be very careful around that spring.. ALOT of power in it and it could hurt someone or take off a finger..
Clamp it in a large vise, pry it off and THROW IT AWAY.....
Re: window mechanism spring [Re: burdar] #2180801
10/23/16 01:03 PM
10/23/16 01:03 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
This morning I threw the mechanism out in the lawn and smacked the spring with a 2x4 from 10' away and it broke. It's going in the trash.
Re: window mechanism spring [Re: burdar] #2180907
10/23/16 04:55 PM
10/23/16 04:55 PM
md
mopars4ever Offline
mopars4ever  Offline
md
spring
Re: window mechanism spring [Re: burdar] #2180918
10/23/16 05:19 PM
10/23/16 05:19 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
Evaporust did the same to one of mine. It blew up. which meant the rust was bad enough to buy 2 new regulators....
YO..waited for a 30% deal...
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: window mechanism spring [Re: burdar] #2180960
10/23/16 07:01 PM
10/23/16 07:01 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
welding will ruin the spring. Just buy a new spring
Re: window mechanism spring [Re: burdar] #2180996
10/23/16 08:27 PM
10/23/16 08:27 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Use large channel lock pliers and they go off and on easily.
That spring would have worked for years if you left the rust on it.
Re: window mechanism spring [Re: burdar] #2181027
10/23/16 09:02 PM
10/23/16 09:02 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
laugh2 Well, now I know. Who would have thought I should have put a rusty part back on the car.
I've got a replacement spring coming. It seems like it needs to have a full revolution of tension before it can be hooked over the tab. I think I've figured out a safe way to install it. I'll update this once it's on.
Re: window mechanism spring [Re: burdar] #2181061
10/23/16 09:41 PM
10/23/16 09:41 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
didn't know you could get new springs.... grrr..
oh well...
Re: window mechanism spring [Re: burdar] #2181213
10/24/16 01:37 AM
10/24/16 01:37 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Yes I know we like to clean it all up. These springs have a lot of tension, the large pliers work good with a 18" lever. Makes it safe. Also for trunk lid torsion rods.
Like putting on brake springs with the wrong tools is dangerous, and the right tools it is a piece of cake.
Re: window mechanism spring [Re: burdar] #2181258
10/24/16 09:16 AM
10/24/16 09:16 AM
London, England
Gavin Offline
Gavin  Offline
London, England
My experience with those (Challenger) is that it was a bear to get off for a start. Despite taking care (clearly not enough...) it flew off at speed and hit the floor and over to my car 8 feet away - could easily have hurt me or chipped the car, broke a window etc.....care is required.
Once cleaned I tried to reinstall and no matter what I did I could not get the required one revolution+ on the spring. I tried channel locks and a bunch of other stuff. It eventually bent the spring tang due to the force required to try and reinstall. Maybe Challenger springs are stronger due to the large window.
I actually ended up buying another complete regulator because even if I got the spring back on I did NOT want that bent back tang breaking off and releasing that energy inside my door.
Lesson learned! Be careful!
Re: window mechanism spring [Re: burdar] #2181304
10/24/16 11:25 AM
10/24/16 11:25 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The spring in the package does not look like it will take a full turn before binding !!
Re: window mechanism spring [Re: burdar] #2181319
10/24/16 11:47 AM
10/24/16 11:47 AM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
The last "tooth" at both ends of the mechanism are square. This prevents the crank gear from being turned off of the piece. I ground the square ends to a point and was able to spin the gear completely off. The piece with the gear on it will now spin all the way around to the opposite side.
All I should have to do is clamp the "gear" section in the vise and install the spring with no tension. Then I can use the other half of the mechanism as a lever....spin the assembly around until the gear grabs the teeth on the other side. That should be it. I shouldn't have to use any pliers or bend the tab that holds the spring.
Once it's back together, I could put a couple spot welds on the end "teeth" so the gear can't be spun off.
Re: window mechanism spring [Re: burdar] #2181612
10/24/16 06:18 PM
10/24/16 06:18 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I tried grinding that off too and it wouldn`t spin off, something was stopping it. I even removed the gear and it still would stop and not come off. Maybe I ground off the wrong end. shruggy
Re: window mechanism spring [Re: burdar] #2181619
10/24/16 06:32 PM
10/24/16 06:32 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
Or the mechanisms are a little different. You can spin mine around all day long after removing the cam style stop. As long as the springs are the same, I should be good to go. I'll post pictures later.
Re: window mechanism spring [Re: burdar] #2183288
10/26/16 09:48 PM
10/26/16 09:48 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
The replacement spring arrived today. It wasn't a perfect match to the original one. I was able to install it easily but will probably keep an eye out for the correct size. The replacement spring was a little smaller so I wasn't able to preload it as much as the original one. Here's how I did it if anyone is interested.
The first picture shows the square tooth at the end of the mechanism next to the one I ground the corner off of. This lets the gear spin off of the teeth. The second picture shows the gear section off of the teeth. You can spin this section all the way around until it touches the teeth on the opposite side...if you remove the "stop" that bolts to the mechanism. The last picture shows the new spring installed.
