[u][b]Can You Identify My Driveshaft(s)?[/b][/u] #217282
02/07/09 09:54 PM
02/07/09 09:54 PM
Winthrop Harbor, IL
63MaxWedge Offline OP
Winthrop Harbor, IL
My '63 Belvedere has a 2-piece driveshaft with no center bearing. I've been trying to identify what it is, what vehicle it came from.
A large tubular shaft connects to the trans yoke, and runs about 3/4 the way back to the rear. At that point, the splined nose of a short, smaller dia. shaft slides into the forward one. This short shaft attaches normally to the pinion yoke.
What is this? Is it good, bad, correct/wrong for the car, etc. I'd appreciate anything you can tell me.
Bruce
Re: [u][b]Can You Identify My Driveshaft(s)?[/b][/u] [Re: 63MaxWedge] #217283
02/07/09 10:44 PM
02/07/09 10:44 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
it sounds like some type of trunyon conversion that was put in backwards,the sliding part usually goes in the tranny ,at leest on the ones ive seen and used.
Re: [u][b]Can You Identify My Driveshaft(s)?[/b][/u] [Re: 63MaxWedge] #217284
02/08/09 10:05 AM
02/08/09 10:05 AM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
DO you have conventional U joints on the front and rear of the shaft?
A 63 Belvedere should have the ball and trunion joint on the transmission end of the shaft. This is a good joint but a bit troublesome to work with, and find replacements, many have been swapped out to later U joints. Of course that requires a different transmission, with a slip yoke tailshaft. Some people have been able to eliminate the trunion joint by using Dodge truck driveshaft parts. I am going to guess thats whats in your car.
Ball and trunion pic:
Re: [u][b]Can You Identify My Driveshaft(s)?[/b][/u] [Re: NTOLERANCE] #217285
02/08/09 10:13 AM
02/08/09 10:13 AM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Here is a what a conversion jint looks like:
Another moparts member had that shaft custom made, but the dodge truck parts look similiar.
