Re: Push-Loc Hose on trans lines
[Re: rebel]
#216957
02/07/09 10:13 PM
02/07/09 10:13 PM
Posts: 976 Woodstock , Georgia
Mopar_racer_99
Woodstock , Georgia
We are running the aeroquip black push lock fittings with glide with brake and had no problems in 3 years. I have been told if you use the blue hose you need to use the locking rings as the heat stretchs the blue hose. John
8.72 @ 154.6 ,68 Charger 578ci 440-1s, 3000# w/drvr, 2150 den/alt NA
[Re: Mopar_racer_99]
#216959
02/08/09 12:25 AM
02/08/09 12:25 AM
Posts: 951 Temperance, MI
prochargedhemi
Temperance, MI
i have been running the blue hose for 4 years with 0 issues. and pushloc fittings
[Re: prochargedhemi]
#216960
02/08/09 04:18 PM
02/08/09 04:18 PM
Posts: 2,179 California, USA
blairboy3
California, USA
aeroquip blue hose (350psi rated I believe... have to go out & look @ the stuff on the wall) & aeroquip push-loc fittings on all my fuel & tranny lines. No problems in 3 years.
1968 Plymouth Fury III 4-Door: 12.79 @ 115, 60'- 1.93 (Hey... it's a Cruise ship... what do you expect?!) Famoso Raceway, 02/08
[Re: turbocolt2.4L]
#216962
02/08/09 05:25 PM
02/08/09 05:25 PM
Posts: 833 MN
hemidup
MN
We've used Push loc's in the past. We also use a crimp on style hose clamp with them to be on the safe side. No problems.
Jerry Williams.
[Re: blairboy3]
#216963
02/08/09 06:34 PM
02/08/09 06:34 PM
Posts: 5,875 communist bloc of new jersey
jamesc
at what temperature?
for the difference in price i'll stick with the braided line and have peace of mind.
[Re: jamesc]
#216964
02/08/09 06:46 PM
02/08/09 06:46 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I have the blue push lock on my trans cooler and my remote oil filter we will see how it does but it is much nicer to work with than the braided stainless as long as I have no problems with it I will never use braided stainless again.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: jamesc]
#216966
02/08/09 10:02 PM
02/08/09 10:02 PM
Posts: 8,165 Left Coast
BobR
Left Coast
imho i would not use push loc hose for this application...blow one off at speed and it won't look like such a good deal
Absolutely, positively. There is no way I would use pushlock here. NO WAY!
