4150 intake hacking #2162122
09/26/16 04:31 PM
09/26/16 04:31 PM
Charleston
sixpackgut Offline OP
Drag Week Mod Champion
Charleston
Hacking on my intake. Hope it helps
Re: 4150 intake hacking [Re: sixpackgut] #2162189
09/26/16 06:03 PM
09/26/16 06:03 PM
Renton Washington
Triple Threat Offline
Renton Washington
Did you weigh it first?
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: 4150 intake hacking [Re: sixpackgut] #2162481
09/27/16 12:31 AM
09/27/16 12:31 AM
Charleston
Charleston
No wish ai did
Re: 4150 intake hacking [Re: sixpackgut] #2162507
09/27/16 01:38 AM
09/27/16 01:38 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
God bless ya!!
Looks like you're going right to town on it.
Porting manifolds is something I've just never been able to warm up to.
Re: 4150 intake hacking [Re: fast68plymouth] #2163074
09/27/16 08:04 PM
09/27/16 08:04 PM
Charleston
Charleston
Originally Posted By fast68plymouth
God bless ya!!
I do a 2 hr port on LS vic jr intakes. Its good for 15hp and its easy money for $100. I would do them all day long if I could
Re: 4150 intake hacking [Re: sixpackgut] #2163097
09/27/16 08:40 PM
09/27/16 08:40 PM
Renton Washington
Renton Washington
For 15 hp you should charge more than $100.
Find some power and I'll send you mine in a month.
-Dustin
Re: 4150 intake hacking [Re: sixpackgut] #2163153
09/27/16 10:04 PM
09/27/16 10:04 PM
So. Burlington, Vt.
So. Burlington, Vt.
I'll do minor port matching and a little plenum clean up....... That's not really "porting".
What you're doing on the gen 3 intake looks like more than I'd want to get into........ Even for myself.
Re: 4150 intake hacking [Re: sixpackgut] #2163197
09/27/16 10:44 PM
09/27/16 10:44 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
You need to do this! Picked up on my motor and yours is 26" bigger. I bet you pick up over that adapter and small plenum.
Re: 4150 intake hacking [Re: STEFF] #2163305
09/28/16 12:29 AM
09/28/16 12:29 AM
Charleston
Charleston
Ya, when I saw your it was unreal.
Re: 4150 intake hacking [Re: sixpackgut] #2163816
09/28/16 06:34 PM
09/28/16 06:34 PM
an8sec70cuda Offline
I bet it works good! I've had to jet mine up a couple sizes so far after Ray ported my Gen 2 hemi manifold.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 4150 intake hacking [Re: sixpackgut] #2164275
09/29/16 12:16 PM
09/29/16 12:16 PM
Indy
496 A-body Offline
496 A-body  Offline
Indy
Have you been running that intake "as cast" or did you have it port matched?
Re: 4150 intake hacking [Re: 496 A-body] #2164296
09/29/16 12:35 PM
09/29/16 12:35 PM
Charleston
Charleston
I had port matched it and did some plenum work before I put it on. If you have an intake then you know the port size where it meets the head is pretty small. I just weighed the aluminum that has come out this time and Im at 10 oz on the second go around
Re: 4150 intake hacking [Re: sixpackgut] #2164312
09/29/16 12:56 PM
09/29/16 12:56 PM
Indy
496 A-body Offline
496 A-body  Offline
Indy
I have a short 4500 intake, I machined the cloverleaf out to add plenum volume. I plan to send it to you to work it over when I get the chance to start focusing on my projects again.
