Re: engine siezed, any thoughts on why
[Re: RapidRobert]
#2160879
09/24/16 02:49 PM
09/24/16 02:49 PM
Posts: 43,007 Bend,OR USA
Cab_Burge
Sounds like some trash got washed into a bearing, maybe a main or rod Let us know what you find out
[Re: RapidRobert]
#2160903
09/24/16 03:33 PM
09/24/16 03:33 PM
Posts: 4,309 Prospect, PA
BSB67
Prospect, PA
he's a busy guy but he will get back to me when he opens it up. I was not involved in the build but his OCD matches mine (& then some!). he said the shop assured him that P/V collision was not possible with his dimentions (lift/piston amt in the hole). he said the ring gapping was the norm & bearings iirc between 2-3 tho plastigauged. all the final prep we did was standard procedure AFAIK but I feel bad like maybe I missed something. well I guess it is somewhat conjecture for now but I will post how it turns out Hmmmm. I would not consider someone OCD if he relies on the shop for PV clearances and his use of plastigauge for checking bearing clearances........
[Re: RapidRobert]
#2161017
09/24/16 08:03 PM
09/24/16 08:03 PM
Posts: 14,479 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
We're any of these sand or bead blasted? Intake manifold Valve covers Oil pan Timing cover
I ask because I've seen this done on many occasions, and when the post blasting cleaning procedure isn't 100%, you often end up with a situation like what was described.
[Re: fast68plymouth]
#2161048
09/24/16 09:18 PM
09/24/16 09:18 PM
Challenger 1
Cincinnati, Ohio
I ask because I've seen this done on many occasions, and when the post blasting cleaning procedure isn't 100%, you often end up with a situation like what was described. The only thing I glass bead blast in a engine is iron rods and crank to be able to check for cracks and that's it. Definitely never aluminum anything, especially not a intake manifold. I learned this on my own the hard way when I was about 19-20 years old and did my own 340 rebuild and used my bosses bead blaster cabinet. Now I use a steam pressure washer to prep my rebuilds. Sounds like it spun a bearing...
[Re: Sxrxrnr]
#2161201
09/25/16 03:29 AM
09/25/16 03:29 AM
RapidRobert
I heard a very slight what sounded like a metallic contact of some sort & it starting to slow down (both at the same time) & I looked over at the tach cuz I thought I had let up on the throttle & I started to throttle it back up & it died. all this took place in about 2 seconds from start to finish & I was thinking later I shoulda killed it on that first contact however slight I heard but it died in about the time it would have taken me to reach the kill switch cuz I was not sure where exactly the switch was (he fired it up/I twisted the dist/pointed the light/kept the throttle open/checked for leaks). EDIT SXR I reread your post & there was the one slight contact rather than a continual interference (if that helps)
[Re: 62maxwgn]
#2161275
09/25/16 11:33 AM
09/25/16 11:33 AM
Posts: 10,666 North Dakota
6PakBee
North Dakota
Once the engine cooled to ambient, is it still locked up? My thought would be insufficient piston/wall clearance. I've been involved in a case with a tight bearing. The bearing wiped but didn't lock the engine up.
