Re: When setting lash what do you guys use
[Re: earthmover]
#2157514
09/19/16 04:41 PM
09/19/16 04:41 PM
Posts: 14,479 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Remote starter switch hooked to the starter relay
[Re: fast68plymouth]
#2157519
09/19/16 04:45 PM
09/19/16 04:45 PM
Posts: 11,678 W. Kentucky
justinp61
W. Kentucky
Remote starter switch hooked to the starter relay ^^This^^ Mine has 6' or so cord on it.
#2157527
09/19/16 04:50 PM
09/19/16 04:50 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I use a remote button.. I just clip it on the relay.. it has about 3' long wires so I move it around side to side... I use the open/closed method so its pretty easy.. I do one cyl at a time working from front to back... I thought about mounting a button but I have enough crap in the way already
[Re: earthmover]
#2157584
09/19/16 06:01 PM
09/19/16 06:01 PM
Posts: 11,894 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Remote starter switch hooked to the starter relay Set the intake valve lash when the exhaust valve is beginning to open. Set the exhaust valve lash when the intake valve is about halfway down on the closing side.
Master, again and still
[Re: earthmover]
#2157610
09/19/16 06:39 PM
09/19/16 06:39 PM
Posts: 8,005 Tulsa OK
Bad340fish
Tulsa OK
I put a bump button on the firewall, unreal how much time it saves.
68 Barracuda Formula S 340 87 "Chrysler" Conquest
