Rough running untill fully warm
#2149035
09/06/16 07:03 PM
09/06/16 07:03 PM
Posts: 401 Norway
General 68
Norway
440, 915 heads, Lunati voodoo 302 hyd. cam, Edelbrock 800 Thunder AVS, Torker 2, FBO ignition, 2" headers, manual trans: Starts easy and idles ok also after choke is fully open but driveability is not good untill engine is fully warmed like after 10 minutes or more of driving. Car needs lots of attention to clutch- and accelerator pedal use to function ok without lugging or bogging down at rpm,s below 2000. Going idle to wot before it is fully warmed will make a huge bog - It completely dies. Acc pump set for longest stroke and a huge .043 squirter still makes this happend. A/F meter reads low 14's at idle and cruise, 13,5 loaded and around 12,5 at wot. Best idle micture setting with the screws out about 1,5 turns. Prior to installing the a/f meter I had bigger jets in the carb but it acted the same when not fully warm. Even when warm it feels like it is on the edge of running too lean and might sometimes bog some when floored. All sympthoms tells me it is to lean but the a/f meter don't... and it has been calibrated. Am I overlooking something? Thinking lifter preload, pcv valve or other not obvious things that can make for thermic problems? Also need to mention that I can not tune away a small lean surge going slowly from cruise to heavier load. Tried different springs and jettings to no vail. Works best with purple spring. What do you suggest?
Re: Rough running untill fully warm
[Re: General 68]
#2149060
09/06/16 07:43 PM
09/06/16 07:43 PM
Posts: 2,094 central texas
krautrock
central texas
that's the way both of my cars are too, no choke. carbs. they are lean until it warms up, they will idle but it's a little slow, then the idle comes around as they warm up. off idle transition is lean so it's a little tricky, if i try to really give them a stab of the throttle then they do the lean backfire or stumble/stall.
to drive them when cold they like to have the rpms around 1500-2000 rpm or so, once they get some heat in them i let the trans shift into third and let the rpms drop...
[Re: General 68]
#2149181
09/06/16 10:05 PM
09/06/16 10:05 PM
Posts: 5,788 Hamilton, Ontario Canada
Magnum
It is the intake manifold that must be warm. You can fully warm up the intake and with the short block, oil and even water cold. It will not bog.
I find big port intakes are the worst offenders. You either need to choke the carburetor which Im not recommending or switch to fuel injection.
This is not the solution you are asking for but I think throttling up a cold engine is bad news.
[Re: General 68]
#2149195
09/06/16 10:19 PM
09/06/16 10:19 PM
krautrock
central texas
In some grade yes but this is bad and the driveability is on the edge until it reaches 180-190 F. that sounds annoying, mine are auto cars with holleys. so yes maybe the manual trans and the edelbrocks are just more finicky. or maybe you are the edge of too lean fully warm and that is making the cold driving even worse...
[Re: General 68]
#2149346
09/07/16 01:41 AM
09/07/16 01:41 AM
RapidRobert
can you borrow another carb to quickly elim or confirm it as the culprit? I would put some thin superformance gaskets on either side of the metal valley pan (vac leak). what is your timing & ported or manifold. there is definitily an issue that I wouldn't be comfortable with
[Re: General 68]
#2149394
09/07/16 05:36 AM
09/07/16 05:36 AM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
What are outside temperatures when experiencing your concerns. If 70 degree 'F', engine start and initial performance will be dramatically different than at 5 degree 'F'. I will leave it to you to do the Celsius conversions.
The intake that you are running unlikely will ever give you decent cold weather performance or economy given its lack of crossover exhaust porting to quickly warm it up,,,and is unlikely to ever warm sufficiently for optimum economy.
In warmer weather you should not even need a choke to start the engine. The fact that you indicate that it is closed when starting the engine suggests that your poor performance is occurring in very cold weather. Hence the need for a rapidly warming up intake, which you do not have.
In warmer weather, intake manifold warming even without crossover or heat riser will be quite rapid,,,even with a single plane intake.
Your other option is to leave the choke closed for an extended period of time until engine finally warms up,,,,just not a good option,,,poor performance and economy and rapidly polluted oil and a likely more quickly rusted out exhaust system if you use for a lot of shorter trips.
[Re: General 68]
#2150024
09/07/16 11:24 PM
09/07/16 11:24 PM
Posts: 10,527 Freeport IL USA
poorboy
Freeport IL USA
The intake manifold is your biggest issue. Between 40 and 60 is about the worst temp range to adjust a carbed motor. its too cold without a choke, and its too warm for the choke to stay on long enough to get past the lean stumble. Opening up the exhaust crossover in the intake would probably solve most of your problem.
Short of changing the intake, or setting up the choke more rich, the only other option is to introduce warmer air into the intake. A few ways to do that, off the top of my head: 1, If you running an open air filter, get one that is closed for your winter driving. Restricting the amount of cold air available to the carb will help your lean condition. 2 Pull warm air off the exhaust and run it through the thermostat controlled snorkel on the closed air filter housing, if you have a dual snorkel housing, one heated snorkel should be enough to do the job. This will require a vacuum source for the thermostatic air door to open and close, and a tube attached to the header/exhaust manifold duct-ed to the snorkel. 3, If your running a heater core with functioning heat, you can pull a heater hose close to the carb to warm up the carb. 4, Another thought is that maybe you can run a copper tube filled with engine coolant between the bottom of the intake and the valley pan to warm up the intake. This could be controlled to shut off once the engine reaches operating temp.
#1 & #2 are better options. Gene
[Re: General 68]
#2150062
09/08/16 12:04 AM
09/08/16 12:04 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The factory didn't use an electric choke like the Thunder uses. So part of the problem is that it has no idea what the engine temp is.
I ran an Edelbrock Performer on my 64 300, but I used a manual choke. Pull it out, drive till it warmed up and pushed it in. Ran fine in all weather, even below freezing. On my 413 you'd know when it needed pushed in because it would bog with the choke on and it warmed up. Open element air filter (no warm air), stock intake (with exhaust crossover).
Tuning to an AF ratio is not best. Tuning to what the engine wants is best, you can note the AF ratio if you want, but if it needs more fuel, then it needs more fuel. Especially when running an unheated intake that doesn't help fuel atomization.
[Re: General 68]
#2150567
09/08/16 07:42 PM
09/08/16 07:42 PM
Posts: 401 Norway
General 68
Norway
Actually I wrote something wrong - the Torker 2 HAS heat crossover ports. But on my engine a heat crossover blocking valley pan was used. I guess it is a good idea to open up the heat crossover! With the issues I have it might be worth the hazzle.
[Re: General 68]
#2150591
09/08/16 08:07 PM
09/08/16 08:07 PM
Supercuda
About to go away
About to go away
up yours
Well, it couldn't hurt and could be a cheap fix.
edit - I see you have headers, not too sure how well it'll function with headers. But you can try.
[Re: Supercuda]
#2150861
09/09/16 06:43 AM
09/09/16 06:43 AM
Posts: 401 Norway
General 68
Norway
I see. Experience with this anyone? How is the head cross over port shaped/constructed? Is it just a channel through the head? Then it won't lead much heat up to the manifold but maybe enough to cut the warm-up time some?
[Re: General 68]
#2151472
09/10/16 03:34 AM
09/10/16 03:34 AM
poorboy
Freeport IL USA
Yes, the crossover is a rectangle shape at the intake manifold edge of the heads (below that curved hollow at the center of the head) and intake, but changes shape as it passes through the head to the exhaust ports, and also changes shape as it passes through the intake manifold itself.
When the weighted and spring loaded flapper valve (heat riser valve) on one exhaust manifold (I believe its the right manifold, its been a few years) closes, it sends the exhaust back through the port on the head, under the pendulum on the intake, through the port on other head, and into the exhaust. If the flapper valve doesn't close, or isn't there, the exhaust heat drifts up (heat rises) to the intake. Over time (generally 8-10 years), the carbon from the exhaust plugs up the ports under the intake and at the intake manifold end of the heads. That carbon needs to be dug (chiseled) out of the ports.
As long as the ports are clean, there should be enough heat passing into the intake to help the cold running condition for several years. Gene
[Re: poorboy]
#2151481
09/10/16 05:21 AM
09/10/16 05:21 AM
Posts: 401 Norway
General 68
Norway
Good reading Poorboy. How does the exhaust enter the crossover - I know where it comes out of the head an into the intake but how is it routed from the combustion chamber and into this channel? Part of the reason why I ask this is that I know my crossover ports are carbon plugged and need to be cleaned out. Never bothered to do this as this function not was going to be used.
[Re: poorboy]
#2151482
09/10/16 05:29 AM
09/10/16 05:29 AM
Sxrxrnr
Northern Calyfornua
Op has stated that his installed valley cover pan has the close the cross over option. It was suggested very early on in this thread that his intake may not have this port,,,,blocking with the valley pan will give indentical results,,,,a cold or very slow to warm up intake.
Again I repeat, this is not recommended for a normal street driven engine. The lack of early and adequate heat to his intake manifold as oft repeated in this thread is a leading candidate for the erratic running issues that he had described.
The factory installed these ports for a good reason. Not anticipating they might be disabled by some tuner with a better idea.
[Re: General 68]
#2151742
09/10/16 05:47 PM
09/10/16 05:47 PM
Supercuda
About to go away
About to go away
up yours
The center port in the head ties into the exhaust port, the flapper in the manifold routes exhaust from that side, thru the intake to the other side till it warms up and the flapper opens. With headers the flapper is moot since headers do not generally have them.
A vacuum and a screwdriver is all you need to clean those ports out.
I, personally, have never seen it plug up and I've been fooling with Mopars for 30+ years. Some say it happens, I wonder why?
[Re: General 68]
#2151797
09/10/16 08:07 PM
09/10/16 08:07 PM
Supercuda
About to go away
About to go away
up yours
In the head, just one port if I recall correctly, I haven't played with a big block in 20 years. However, in the stock application the passenger side manifold, with the flapper in the outlet port directs all 4 cylinders exhaust thru the intake.
I can't find a good drawing of how it works.
[Re: Sxrxrnr]
#2151902
09/10/16 10:51 PM
09/10/16 10:51 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
The factory installed these ports for a good reason. Not anticipating they might be disabled by some tuner with a better idea. what about all the aftermarket heads that have no crossover? my 526 has RPM heads, and a holley 1000cfm hp carb, with no choke housing. no issues with cold start/warm up.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: General 68]
#2152044
09/11/16 01:20 AM
09/11/16 01:20 AM
Posts: 3,871 Oregon
hooziewhatsit
Robert: Forgot to answer one of your Q's: I run 20 degrees initial on manifold vacuum. Distributor is set up for that and if I remember right it will idle at 28 degrees. It will instant drop to 20 when opened up. Total is 35-36 all in by 2.500 rpm. Your distributor is hooked up to manifold vacuum, and not ported, correct? What is your vacuum in drive? At what vacuum does the vacuum advance start advancing? If vacuum in drive is below where the vac advance engages, you will have issues, particularly when cold. If that's the case, you'll need to use a hex key in the nipple of the vacuum can to lower the point that it engages, to prevent that overlap. Easiest way to test this is with a mity-vac and timing light, or just take the distributor cap off and watch for it to move.
[Re: Spaceman Spiff]
#2152131
09/11/16 06:09 AM
09/11/16 06:09 AM
Posts: 401 Norway
General 68
Norway
Yes what about that? Supercuda: Norway yes! Hoozie: Running manifold vacuum - not ported. No vacuum reading in drive as it is a manual. Idles at 12hg vacuum. Not sure at which vacuum the advance kicks in but should be well under 12 hg as it is all in at idle.
[Re: General 68]
#2152134
09/11/16 06:31 AM
09/11/16 06:31 AM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
Edelbrock carbs and open/single plane Torker-intakes don't always like to play well together. Try installing a 1", or better, a 2" spacer under the carb and see how the engine likes that. (But make sure the spacer has 4 holes, not the 'open' type.) The spacer mostlikely will improve the engine's vacuum-'signal' to the carb and it in turn, will react much better and quicker to changes in the throttle.
[Re: General 68]
#2152186
09/11/16 10:45 AM
09/11/16 10:45 AM
Posts: 5,443 Indiana
YO7_A66
Indiana
General 68: If you are running the FBO manifold distributor like I do, I know mine specifies a minimum of 12" vacuum per Don. I tested mine and my timing at idle stays solid down to 11.5", then below that the timing drops off. You might be right on the edge unless Don did something different with your setup.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: General 68]
#2152193
09/11/16 10:57 AM
09/11/16 10:57 AM
Supercuda
About to go away
About to go away
up yours
Ok, running manifold vacuum is one of the problems.
As you open the throttle manifold vacuum drops and timing backs off causing a similar problem to what you are seeing.
As a test run ported and see if that helps.
[Re: General 68]
#2152505
09/11/16 07:15 PM
09/11/16 07:15 PM
Posts: 3,871 Oregon
hooziewhatsit
Yep, that low of vacuum at idle is most likely the problem. Mine idles at 17", and sits at 14" in drive. Vac advance doesn't drop out until 10".
Like supercuda says, I bet you're right on the edge of advance. As soon as you put some load on it, the advance goes away and your idle drops. This would be exacerbated when it's cold.
[Re: General 68]
#2153092
09/12/16 03:15 PM
09/12/16 03:15 PM
Posts: 401 Norway
General 68
Norway
BINGO! (I think). Plugged the vacuum advance and it acted better on the choke. No sure how well it drives after that as it was still touchy during warm up but needed more trottle opening from the idle screw (ofcourse, after losing 8 degrees vacuum advance) and readjusting the idle mixture. Runs super when warm. Had already put back the bigger jets. Needs some more testing but all in all it is a lot better. I was debating the manifold vacuum with Don a couple of years ago but didn't get any love. Can't wait to see how it drives at next cold start! Thanks a bunch all!!
