Re: How much are my small headers killing my performance
[Re: cudaman1969]
#2150735
09/08/16 11:28 PM
09/08/16 11:28 PM
Posts: 501 CEDAR RAPIDS
Plymouth340
CEDAR RAPIDS
I'll throw this out there, not sure if it means much. Read about a test some engine builder did on a small block Chevy, on the dyno, with the results of dinging headers, if it lost power. They went so far as to almost flatten them completely and saw no power loss, maybe 4 or 5 hp tops, they where dumbfounded? You might see a change in a poorly designed set over a top of the line set, but not the gains you're looking for, IMO That could be true. But what was the horsepower level of that motor? I would think this 900 horsepower motor turning 8,700 rpm it would make a bit of difference. I would be skeptical of it being 900 hp unless I was there when they dynoed it. Did he say what mph the other car was going? The header banging was a u-tube video. I dought they could fake it. 153 mph @ 3280lbs this motor is legit it has the best of everything on it
[Re: slantzilla]
#2150801
09/09/16 01:06 AM
09/09/16 01:06 AM
Plymouth340
CEDAR RAPIDS
Are you runing the same converter, trans gearing, and rear gear he did? no,no,no all I'm wondering is if these 1 7/8 headers I'm using are killing my performance and if it would be worth the work to make the larger step headers work !!!
[Re: Plymouth340]
#2150868
09/09/16 08:51 AM
09/09/16 08:51 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
It would, at least be worth the effort to try them. That much power, with the rpm needed, might be cause for concern with a 1 7/8" tube. The longer the tube, the more the restriction. Works just like resistance in wiring. Smaller tubes, in general, give more torque. Bigger tubes are for mid to high rpm use. You have to watch your fuel curve through mid range with big tubes.
[image][/image]
[Re: Plymouth340]
#2150966
09/09/16 12:38 PM
09/09/16 12:38 PM
Posts: 14,491 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
153 mph @ 3280lbs this motor is legit it has the best of everything on it The moroso chart shows that to be pretty much right on 900hp.
[Re: sgcuda]
#2151083
09/09/16 03:01 PM
09/09/16 03:01 PM
Plymouth340
CEDAR RAPIDS
It would, at least be worth the effort to try them. That much power, with the rpm needed, might be cause for concern with a 1 7/8" tube. The longer the tube, the more the restriction. Works just like resistance in wiring. Smaller tubes, in general, give more torque. Bigger tubes are for mid to high rpm use. You have to watch your fuel curve through mid range with big tubes. Yes I think it will be worth the effort. I've never built headers before but to make these fit shouldn't be that bad I have a tube chassis car there's lots of room. And my time is free
[Re: fast68plymouth]
#2151086
09/09/16 03:03 PM
09/09/16 03:03 PM
Plymouth340
CEDAR RAPIDS
153 mph @ 3280lbs this motor is legit it has the best of everything on it The moroso chart shows that to be pretty much right on 900hp. Yes the power is there. Just seems like something's holding this motor back. I've tried a lot of things and nothing really seems to make much difference so this is my next step
[Re: Plymouth340]
#2151216
09/09/16 06:54 PM
09/09/16 06:54 PM
Posts: 20,158 Park Forest, IL
slantzilla
Park Forest, IL
It will be interesting to see if your headers are killing 150 horse.
[Re: Alchemi]
#2151799
09/10/16 08:10 PM
09/10/16 08:10 PM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
All that header beat up test did was prove that the wrong headers were on the motor to start with.... You need to watch the follow up video. TL/DR answer, no they were the best size.
#2151875
09/10/16 10:07 PM
09/10/16 10:07 PM
BradH
At seasons end...... Might be worth a trip to the dyno and see just how much difference in power there is between the headers......before going through the effort of fitting them to the car. x2 Not only would you find out what the other headers are worth, it could provide more data to help with converter setup.
[Re: Plymouth340]
#2152381
09/11/16 02:56 PM
09/11/16 02:56 PM
Posts: 30,989 Oregon
AndyF
I did a header test on my 470 engine between 2" dyno headers and 1 3/4 stepped to 1 7/8 dyno headers. At 6800 rpm the 2" headers were 10 ft-lbs better.
[Re: Plymouth340]
#2152422
09/11/16 04:05 PM
09/11/16 04:05 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Damn, I'm not so upset with having 1.75 TTI's on my 420 G3 anymore.
Mopar to the bone!!!
[Re: pittsburghracer]
#2542525
08/28/18 02:58 PM
08/28/18 02:58 PM
Plymouth340
CEDAR RAPIDS
From everything I've read and heard about this engine combo I would lean towards the converter not being the right stall. That seems to be the biggest issues Well I finally put in a 7 inch converter and it picked up all most 2 tenths..9.07 @ 149 in 4000 da air..that was the ticket and I haven't tried leaving at higher rpm yet or a little more jet
[Re: justinp61]
#2542663
08/28/18 07:05 PM
08/28/18 07:05 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Your not gonna see a 100hp difference from the set you have on the car to the ones that were on it.. I was running a W-9 with step headers (1 7/8-2-2 1/8.. if your conv stalls at 7000 it is real close I stalled at 5600 and it was a bit low.. I shifted at 8200 rpm.. it didnt make any more power when shifted at higher rpms.. I went up to 9400 and dint do a damn thing
[Re: Plymouth340]
#2542989
08/29/18 01:03 PM
08/29/18 01:03 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
From everything I've read and heard about this engine combo I would lean towards the converter not being the right stall. That seems to be the biggest issues Well I finally put in a 7 inch converter and it picked up all most 2 tenths..9.07 @ 149 in 4000 da air..that was the ticket and I haven't tried leaving at higher rpm yet or a little more jet What carb(s) are you running............
[Re: Plymouth340]
#2543006
08/29/18 01:41 PM
08/29/18 01:41 PM
Posts: 19,355 Las Vegas
Al_Alguire
Las Vegas
FWIW the smallblock in the heads up car made over 1000 with a set of 1 7/8" 20 long primary headers on the dyno. Headers on the car are 1 7/8 to 2 to 2 /18". Car ran 8.0's last year at 2800.
