Re: Carter AVS vs Holley 3310 vs Thermoquad -carb issues
[Re: cudaman1969]
#2147804
09/05/16 04:31 AM
09/05/16 04:31 AM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
I run that same carb on my 71 BEE - 383 Magnum - Put the smaller AVS 6125 s up in the attic
Perfect - Carb is Awesome
I also blocked off the HIC
Made my own flat metering rod covers - Edelbrock doesn't sell them when I asked
104 Primaries 107 Secondaries
68-47 Metering Rods Blue Edelbrock Metering Rod Springs , had to replace factory springs
The 4640 is for AC cars and I would look at the hot idle compensator for leaks (cork gasket) or block it like bee 71 said. Is your car AC? If not look for 4618 carb, they have different air adjusters. Check the rods to see if they are free moving and down when running, might not be seeing vacuum to pull down (restriction) Like I said, the HIC is blocked off. The metering rods move freely, and are down at idle.
[Re: RapidRobert]
#2147846
09/05/16 10:28 AM
09/05/16 10:28 AM
Posts: 3,916 usa
lewtot184
usa
I would highly suggest not opening anything up (drilling). we gotta find/fix the root cause first. do you have any experience with changing idle feed/jets in any carbs?
[Re: 69L78Nova]
#2147934
09/05/16 01:02 PM
09/05/16 01:02 PM
Posts: 8,233 fredericksburg,va
cudaman1969
fredericksburg,va
The 4640 is for AC cars and I would look at the hot idle compensator for leaks (cork gasket) or block it like bee 71 said. Is your car AC? If not look for 4618 carb, they have different air adjusters. Check the rods to see if they are free moving and down when running, might not be seeing vacuum to pull down (restriction) Like I said, the HIC is blocked off. The metering rods move freely, and are down at idle. The holly must be duel feed? Square bowl will fit with stock coil bracket, and I wouldn't put the tq on with an adapter. So find a 440 tq intake, less hassle since all the linkage and choke hooks up factory.
[Re: RapidRobert]
#2148018
09/05/16 02:51 PM
09/05/16 02:51 PM
Posts: 25,728 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I would highly suggest not opening anything up (drilling). we gotta find/fix the root cause first. The root cause is the design. These are emissions carbs intended to run lean and they do; drivability problems were well known when the cars were brand new and today's gas exacerbates the original problem.
[Re: John_Kunkel]
#2148079
09/05/16 04:27 PM
09/05/16 04:27 PM
RapidRobert
yes it is an emissions era carb & is lean & tweaking the innards does work excellent to fine tune em spot on but it can & will run at least on the idling circuit fine for the most part without em (& OP has a mild cam). there is another problem going on that needs to be fixed (something is severley damaged/leaking etc). I cant see fine tuning the innards with drilling fixing what is damaged. Like the one guy posted & my exp with em, they are fine but can be made better. if drilling mods fix this carb I'll be the first to admit I was wrong!
[Re: 69L78Nova]
#2148930
09/06/16 04:48 PM
09/06/16 04:48 PM
Posts: 14,491 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I'm with Lew and John on this one...... Drill 'em out.
[Re: John_Kunkel]
#2148969
09/06/16 05:35 PM
09/06/16 05:35 PM
cudaman1969
fredericksburg,va
I would highly suggest not opening anything up (drilling). we gotta find/fix the root cause first. The root cause is the design. These are emissions carbs intended to run lean and they do; drivability problems were well known when the cars were brand new and today's gas exacerbates the original problem. Emission carb, in 1969?
[Re: cudaman1969]
#2149067
09/06/16 07:52 PM
09/06/16 07:52 PM
John_Kunkel
Rio Linda, CA
You bet. All factory AVS's (Mopar started using them in '68) are emission carbs.
[Re: 62maxwgn]
#2149945
09/07/16 10:08 PM
09/07/16 10:08 PM
Posts: 792 Earth
Rob C
Earth
Not if the TQ is set up right !! AGREED! Finding a good TQ is one thing. Getting parts to tune it is the other trick. Once you have a good TQ carb tuned in, there really quite an excellent carb. IMO, perfect for a street strip application. A Holley is the easy way out. And I wouldn't blame a sole for going to one.
[Re: Rob C]
#2149954
09/07/16 10:20 PM
09/07/16 10:20 PM
cudaman1969
fredericksburg,va
Not if the TQ is set up right !! AGREED! Finding a good TQ is one thing. Getting parts to tune it is the other trick. Once you have a good TQ carb tuned in, there really quite an excellent carb. IMO, perfect for a street strip application. A Holley is the easy way out. And I wouldn't blame a sole for going to one. The TQ a least has the right Chrysler linkage, not a bandaid adapter.
[Re: 69L78Nova]
#2149996
09/07/16 10:57 PM
09/07/16 10:57 PM
RapidRobert
B5XP29, FOR SURE holler how the AVS turns out! what you did to it/how it acts now. Inquiring minds want to know.
[Re: 69L78Nova]
#2150059
09/08/16 12:02 AM
09/08/16 12:02 AM
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
I ordered some #63 drill bits (.037"), as nobody local carries them. Hopefully they'll be here by the weekend. If I can't get the AVS running right, maybe I'll try the thermoquad. Thanks to everybody for the advice/suggestions
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
[Re: 69L78Nova]
#2150168
09/08/16 04:17 AM
09/08/16 04:17 AM
cudaman1969
fredericksburg,va
I ordered some #63 drill bits (.037"), as nobody local carries them. Hopefully they'll be here by the weekend. If I can't get the AVS running right, maybe I'll try the thermoquad. Thanks to everybody for the advice/suggestions One of my favorite cars. Rode around many a nite in my friends 69 RT, forest green, he bought the car right off the showroom, paid for it himself.
[Re: 69L78Nova]
#2150309
09/08/16 01:01 PM
09/08/16 01:01 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Not interested in something the "looks like" a Thermoquad.
Question is, does it SOUND like one?
[Re: 69L78Nova]
#2150374
09/08/16 02:31 PM
09/08/16 02:31 PM
fast68plymouth
So. Burlington, Vt.
I like the Edelbrock 800avs in an application like this.
[Re: 69L78Nova]
#2151454
09/10/16 02:39 AM
09/10/16 02:39 AM
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
Well, it worked! Drilling out the idle fuel jet tube to .037" did the trick. It has never idled better. Smooth as silk. Who would have thought something so simple could have done it. Thanks to everyone that offered up the great advice! Gotta love Moparts! 👍
[Re: fast68plymouth]
#2151540
09/10/16 11:09 AM
09/10/16 11:09 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I'm with Lew and John on this one...... Drill 'em out. I also agree with you guys. Does anyone know what size the economizer or the other idle feed restriction is ? I take it that it is larger then the lower idle feed restriction at the bottom of the idle tube since drilling the idle restriction at the bottom of the tube helps and makes it richer ? Ron
[Re: 69L78Nova]
#2151601
09/10/16 12:37 PM
09/10/16 12:37 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
Interesting , Awesome To Hear
By drilling them out , could you actually have cleaned them out , as in dirty or plugged ???
My 4640sa starts and idles perfect stone cold , idles cold with no choke not even touching the gas pedal , running the Mopar 284 / 484 Cam , transition off idle beyond smooth , I don't even want to try this , if not broke don't fix it ,since the many times I opened it up playing with jetting and fine tuning it
Anyways makes the Edelbrock 1407 that it replaced , man what a Headache that 1407 was , biggest POS carb I ever worked on
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: bee1971]
#2151623
09/10/16 01:35 PM
09/10/16 01:35 PM
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
Not a chance. This carb couldnt have been any cleaner. I always clean all passages out with torch tip cleaners, carb cleaner, and a blast of over 120psi of air. Not every carb needs to be modified internally, but I guess this one did. Like I said, it has never idled better or cleaner, I leaned out the primary cruise step and fattened up the secondary jets while it was apart. Plugs look good, pulls harder, and idles great.
