Re: How to block off heat riser ports-*DONE*
[Re: aarcuda]
#2159623
09/22/16 07:48 PM
09/22/16 07:48 PM
Posts: 14,491 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I would just redo the weld job on the intake manifold. I usually set the piece to block off the flow below the sealing surface and have it welded in there. That way when/if the manifold gets milled most of the weld remains untouched.
[Re: aarcuda]
#2159730
09/22/16 10:28 PM
09/22/16 10:28 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
On my LA's I just fill the crossover port about 1/2" in the intake with JBWeld. Never had a problem.
[Re: J. Hammer]
#2161944
09/26/16 12:36 PM
09/26/16 12:36 PM
Posts: 15,478 the boonies
aarcuda
the boonies
Kinda difficult to make that fit a small block I'd guess? LOL! yes, I have a small block and that valley pan wont fit
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
