Page 1 of 6 1 2 3 4 5 6
How to block off heat riser ports-*DONE* #214706
02/05/09 11:02 AM
02/05/09 11:02 AM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
on a small block?
I know on big blocks you can just get the valley pan with the port blocked off but they dont have them on small blocks.
Can I just cut a thin sheet of aluminum thats thinner than the intake gasket and stick it in the gasket opening?
Re: How to block off heat riser ports [Re: aarcuda] #214707
02/05/09 11:32 AM
02/05/09 11:32 AM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
I wouldn't trust aluminum with all that heat. Stainless might be a better choice
Re: How to block off heat riser ports [Re: aarcuda] #214708
02/05/09 12:37 PM
02/05/09 12:37 PM
Owego, NY
JBurch Offline
JBurch  Offline
Owego, NY
In the past I have used a piece of tin from from a can. Would have prefered something better, but that's what I had, it worked.
Re: How to block off heat riser ports [Re: aarcuda] #214709
02/05/09 12:49 PM
02/05/09 12:49 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
The first time I took my intake off, someone before me had pumped a ton of silicone into the holes on the heads. It did work.
Re: How to block off heat riser ports [Re: aarcuda] #214710
02/05/09 01:11 PM
02/05/09 01:11 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
I took a small ball(3/4") of aluminum foil wrapped tight. Tapped it in the heat cross over slowly until it conformed to the shape. Then used the RTV red to seal it in place.I used it together with the felpro gasket with the block off. Its been in 2 years with no problem. Sounds a little Mickey Mouse ,but it works!
Re: How to block off heat riser ports [Re: R/T1968R/T] #214711
02/05/09 01:37 PM
02/05/09 01:37 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Fel-Pro makes an intake gasket that DOES NOT have the holes cut in it for the heat riser. I used there gaskit on a 360 in a drag car and didn't have any issues with it for the two years that I raced it.
Re: How to block off heat riser ports [Re: burdar] #214712
02/05/09 01:56 PM
02/05/09 01:56 PM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
Thank you sir! I just found it and ordered it.
Its PN FEL-1213. Mancini is shipping it as I type!
Re: How to block off heat riser ports [Re: burdar] #214713
02/05/09 01:58 PM
02/05/09 01:58 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
The best block off would be to take
a large lead fishing weight and drive it into the
cross over port then surface or work down to
the intake surface. Dan Dvorak told me this
several years ago and it works.
logan426
Re: How to block off heat riser ports [Re: MLR426] #214714
02/05/09 02:04 PM
02/05/09 02:04 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
My brother buys a zinc alloy of some sort from Mondello and melts it and pours it into the opening on his oldsmobile heads. It's expensive to buy, but pretty easy to do.
He tried doing it by melting some old pistons down, but it didn't work very well. You need a tremendous amount of heat to liquify aluminum and keep it in that state long enough to pour it into the holes. It ended up all lumpy and parts would crumble off if you picked at it so he dug it back out and started over.
Re: How to block off heat riser ports [Re: Neil] #214715
02/05/09 02:30 PM
02/05/09 02:30 PM
OK
70SWGR Offline
70SWGR  Offline
OK
If your intake is aluminum why not weld them?
Re: How to block off heat riser ports [Re: Neil] #214716
02/05/09 02:44 PM
02/05/09 02:44 PM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
whats the temperature at the opening tothe exhaust port? Lead melts at 600 degrees. It would suck if the lead melted
Re: How to block off heat riser ports [Re: 70SWGR] #214717
02/05/09 02:44 PM
02/05/09 02:44 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I used those felpro gaskets and they burned through in about 3 or 4 years even of limited use. I have regular hp exhausts on my AAR.
Re: How to block off heat riser ports [Re: fastmark] #214718
02/05/09 03:02 PM
02/05/09 03:02 PM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
well thats good to know. I will probably do a combo of aluminum foil balls (aluminum melts at 1220 degrees F) and maybe a steel plate that fits inside the port so the gasket will hold up longer
Re: How to block off heat riser ports [Re: aarcuda] #214719
02/05/09 03:18 PM
02/05/09 03:18 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
It's not lead, but a zinc alloy. You can buy it from Mondello or Dick Miller Racing. They sell it just for this application. You need a cast iron pan and an acetylene torch to heat it up.
I don't know the melting point of lead right off the top of my head, but I know it melts easy with a small propane torch. Those don't get nearly as hot as a real acetylene torch gets.
Re: How to block off heat riser ports [Re: Neil] #214720
02/05/09 03:49 PM
02/05/09 03:49 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Grab some .020 or thinner steel and be done with it.
Re: How to block off heat riser ports [Re: RobX4406] #214721
02/05/09 04:18 PM
02/05/09 04:18 PM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
problem is that ive already ordered the gaskets with heat riser already blocked. if i stick that steel shim in ther, Wont it bulge out too much..
i suppose I could cut it out so theres a tiny overhang (1/8" all around). I could try it. it just that I know my heads were milled and the intake surface probably wasnt done (or wasnt milled enough) so its a real [Edited by Moparts - Keep it clean] to get the intake on as it is. I need to start certain bolts that want to cross thread because of the angle they go in at. then once i get a few started, i tighten them up and it pulls the intake down so i can get the others in. in any event, its not easy so the thinner I am on the gasket surfaces, the better off it will be bolting the intake on
Re: How to block off heat riser ports [Re: aarcuda] #214722
02/05/09 04:35 PM
02/05/09 04:35 PM
scratchnfotraction Offline
thin metal works best,I rvt it to the head,then install the gasket and intake
if its 2 thick it will/could cause an intake leak or suck oil into the port..DAMHIK
another way
I use the permotex copper and fill the heat cross over in the heads,about 2" deep,then smooth off at intake surface,let cure over night
never seen that stuff move or burn yet
been sealing old header gaskets for awhile with it also
it does not get any hotter than right there at the bowl behind the valve and the top side of the exhast port into the header flange
if it dont burn there after 2yrs,its not gonna burn
if that is not to shadetree for ya
that crap plugs up the flow of a radiator pretty good also
Re: How to block off heat riser ports [Re: aarcuda] #214723
02/05/09 04:39 PM
02/05/09 04:39 PM
I used those fel pro 1213 gaskets & some aluminum foil wadded up balls.they're not(havent yet) going to melt. those are nice gaskets.
Re: How to block off heat riser ports [Re: RapidRobert] #214724
02/05/09 05:20 PM
02/05/09 05:20 PM
NW Ohio
6pkaar Offline
6pkaar  Offline
NW Ohio
Do you put the aluminum foil balls in the passage in the head OR the manifold?
Re: How to block off heat riser ports [Re: 6pkaar] #214725
02/05/09 06:06 PM
02/05/09 06:06 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
One easy way is just use a manifold that doesn't have a crossover, like an air gap or an M1 single plane.
