Speaker Question #2141782
08/27/16 10:59 AM
08/27/16 10:59 AM
Philadelphia, PA
GTXKARL Offline OP
GTXKARL  Offline OP
Philadelphia, PA
Hello. I am upgrading my radio on my 1970 Plymouth GTX. I would like to use one of those RetroSound speakers for the front dash. What size would you recommend and how would it fit? I don't have an AC in the cars (the windows are the AC, haha). Thanks in advance. help
Working on cars teaches you patience... and every curse word imaginable.
1970 Plymouth GTX -- A true gentleman's coupe, but a serious muscle machine.
Re: Speaker Question [Re: GTXKARL] #2141849
08/27/16 01:20 PM
08/27/16 01:20 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
If you have the orig 8 ohm factory radio, call these guys. I used their hi perf 8 ohm speakers in my Challenger with the 3 speaker dash option & orig am 8 track & the sound was awesome. They also make a front center speaker housing with two smaller 8 ohm speakers.
http://turnswitch.com/speakers.htm
Re: Speaker Question [Re: GTXKARL] #2142102
08/27/16 08:14 PM
08/27/16 08:14 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
I used two of the RetroSound 3.5 inch speakers. Bought an aluminum plate with the two holes for the speakers, but you could use medium density of fiberboard (MDF) and cut out your own. See attached link where I show several pics of the install in my 71 Roadrunner.
Ron
http://www.roadrunnernest.com/forum/viewtopic.php?f=2&t=4431&hilit=RetroSound
Re: Speaker Question [Re: Ronnman] #2142323
08/28/16 10:06 AM
08/28/16 10:06 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Ron
what speakers did you use in the front? every 3 1/2 i've tried sounds like a tin box.
Re: Speaker Question [Re: GTXKARL] #2142480
08/28/16 02:35 PM
08/28/16 02:35 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
I used the RetroSound 3.5". It's a fair sounding speaker. The best would problablty be the Infinity reference speakers, but they are costly. Then, no 3.5 " speaker is going to provide bass like a 6 x 9 speaker. It basically will supply treble and midrange frequencies. There's just not much room in the opening provided in the dash of a 71 B-body. You might be able to fit ( with mods to the speaker) a 4 x 10 with the dual voice coils.
Ron
Re: Speaker Question [Re: GTXKARL] #2142534
08/28/16 04:12 PM
08/28/16 04:12 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Before recommending speakers U need to confirm what is the radio upgrade?
Many posts have said use 8 Ohm speakers.. rolleyes
But if U are upgrading to a later radio, these typically use 4 Ohm speakers so if one connects 8 Ohm speakers U will lose 50% of radio's power output...
Clarify what the radio upgrade is and we will post more options. Note that we are an MECP certified engineer and have built multiple SEMA and CES magazine show vehicles.
Just my $0.02.. wink
