Page 5 of 13 1 2 3 4 5 6 7 12 13
Re: The Quest Has Begun......605 Hemi Build, Parts Arrived! [Re: JohnRR] #2077401
05/20/16 11:24 PM
05/20/16 11:24 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Originally Posted By JohnRR
Originally Posted By Dragula
[quote=rowin4]
I guess you found out you can't build pressure from a suction port. I would plumb in the accumulator off another port. Do you have a remote oil filter?
I was told, it was a pressure supply port, but we could not get pressure from it, so the assumption its a suction port could be inferred, I guess. I have no other current way to get an AN10 line to attach to the block right now, so the accumulator is on the shelf for now.
Does the Indy block have oil pressure ports on the rear like a stock block, that would be the place to plumb ... unless the ports are supplying oil to the heads ?
Yes it does, but they are small....Nothing I would use for an AN10 line.
Re: The Quest Has Begun......605 Hemi Build, Parts Arrived! [Re: Dragula] #2098984
06/27/16 12:59 AM
06/27/16 12:59 AM
Dragula Offline OP
Dragula  Offline OP
So just an update.......At the first track outing, the car did remarkably well. Went a best of 6.32 at 108mph and the only thing I worked on was the rear suspension.
So thru the mufflers, on DOT approved 31x15 Hoosier QTP's and mono leafs with Rancho rear shocks, it went 6.32 at 108....Had a bunch of 6.40's and the tuning on the rear shocks finally netted some improvements in the launch for a bunch of runs in the 6.3's with a best 60ft of 1.38....
Still had the cowl hood on it....Vid of 6.36 run against my buddy's race car...I won!
https://www.youtube.com/watch?v=NVTE82X6ZQ8
Re: The Quest Has Begun......605 Hemi Build, Parts Arrived! [Re: Dragula] #2099084
06/27/16 04:34 AM
06/27/16 04:34 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Love the white headliner smile
Re: The Quest Has Begun......605 Hemi Build, Parts Arrived! [Re: Al_Alguire] #2100822
06/29/16 11:16 PM
06/29/16 11:16 PM
Dragula Offline OP
Dragula  Offline OP
I like keeping this thread alive so all my 605 Hemi related stuff is in one spot....So here is the finished hood, and the new side window stickers the car proudly displays....The 1250 is coming around with some tinkering and is actually a very drivable car considering the cam and lift and that big 1250 Holley setup by Thumper Carbs...
I am still trying to dial in the hood alignment. Its not the best I can get it yet, but the fenders and such were not mounted at the same time as the new hood, they were aligned to the old hood....PITA...Not to mention I pulled the diaper off after its test outing, and I burnt right thru it on one side.
Re: The Quest Has Begun......605 Hemi Build, Parts Arrived! [Re: Dragula] #2101079
06/30/16 12:46 PM
06/30/16 12:46 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Lookin good man and the scoop change will change the tune as you noticed but should come around........
Re: The Quest Has Begun......605 Hemi Build, Parts Arrived! [Re: Dragula] #2101867
07/01/16 01:50 PM
07/01/16 01:50 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Love it!!!
Re: The Quest Has Begun......605 Hemi Build, Parts Arrived! [Re: gsmopar] #2102280
07/02/16 12:31 AM
07/02/16 12:31 AM
Byron, NY
W.I.N. Racing Offline
Byron, NY
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: The Quest Has Begun......605 Hemi Build, Parts Arrived! [Re: W.I.N. Racing] #2137790
08/21/16 12:14 PM
08/21/16 12:14 PM
Dragula Offline OP
Dragula  Offline OP
Well....A little progress on the engine block this weekend. For those that don't know, I had a rod failure at the Nostalgia weekend here a couple weeks ago. It was not pretty, but it is what it is at this point. The diaper probably saved the car as almost nothing hit the track...
So I hired the best aluminum welder I know of, and we got started this weekend on it....
Re: The Quest Has Begun......605 Hemi Build, Parts Arrived! [Re: Dragula] #2137820
08/21/16 12:50 PM
08/21/16 12:50 PM
sing sing
U
unknown Offline
unknown  Offline
U
sing sing
Looking good, much easier to fix then cast iron.
Re: The Quest Has Begun......605 Hemi Build, Parts Arrived! [Re: unknown] #2137839
08/21/16 01:07 PM
08/21/16 01:07 PM
Dragula Offline OP
Dragula  Offline OP
Agree'd, but not what I had in mind for my Hemi this year that is for sure.
Re: The Quest Has Begun......605 Hemi Build, Parts Arrived! [Re: Dragula] #2137868
08/21/16 01:40 PM
08/21/16 01:40 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
It has to make you feel good that it is repairable. I'm guessing you'll forget all about it when you fire that puppy up again.
[image][/image]
Re: The Quest Has Begun......605 Hemi Build, Parts Arrived! [Re: Dragula] #2137895
08/21/16 02:09 PM
08/21/16 02:09 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Question?
Do you ned to put the main caps in and torque them down before you weld the block pieces back in so it limits the distortion from the welding?
Asking as I am looking at a used block that needs similar repairs.
Good luck with it.
Jerry
Old Geezer Racing
Re: The Quest Has Begun......605 Hemi Build, Parts Arrived! [Re: SCATPACK 1] #2137907
08/21/16 02:22 PM
08/21/16 02:22 PM
Dragula Offline OP
Dragula  Offline OP
Originally Posted By SCATPACK 1
Question?
Good luck with it.
Jerry
No, but we will be checking for it when its done. We have to heat it to around 200* so we can weld it. We have an oven in the shop that we normally cook CI blocks in to get all the junk off of before shot blasting them. So we are going to put it on super low temp and bring it up to welding temperature......Should be done next weekend if all goes well.
Re: The Quest Has Begun......605 Hemi Build, Parts Arrived! [Re: Dragula] #2137913
08/21/16 02:30 PM
08/21/16 02:30 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Good to see you`ll be back in action again.............
Re: The Quest Has Begun......605 Hemi Build, Parts Arrived! [Re: Thumperdart] #2137922
08/21/16 02:40 PM
08/21/16 02:40 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I'm so glad that your block ended up being repairable. That had to be a sick feeling in your gut.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: The Quest Has Begun......605 Hemi Build, Parts Arrived! [Re: Dragula] #2138229
08/21/16 11:19 PM
08/21/16 11:19 PM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
Looking good Drag - shot us pics of the finished repair. Kudos for getting onto it so quickly !
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: Dragula] #2138334
08/22/16 01:47 AM
08/22/16 01:47 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Glad to see it going back together. boogie
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: slantzilla] #2139435
08/23/16 05:57 PM
08/23/16 05:57 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
Was it a rod or bolt failure? What rods/bolts were you running?
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: slantzilla] #2139622
08/23/16 11:23 PM
08/23/16 11:23 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
I agree, and good luck with the rebuild.
Mark
http://marsh-racing.com/Mark%20Mahorney-Allstate.htm
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: The Quest Has Begun.......Parts Arrived! [Re: gregsdart] #2147920
09/05/16 12:39 PM
09/05/16 12:39 PM
Dragula Offline OP
Dragula  Offline OP
Well....Here's the block repair...Went very well. Wish it would not have let go, as this may get expensive depending on how the crank goes...Have to send that one out before we know which route that is going to go. After we figure out what we are going to do with the crank, then we order the rest of the parts, and then think about the oil pan...
Welded inside and out...Hired the Right guy!
