FM Bearing defect #213482
02/04/09 12:15 AM
02/04/09 12:15 AM
Southington Ct.
turbobitt Offline OP
Southington Ct.
Has anyone else seen this ? This is the second set that I got with this defect. If you look at the picture, you can see the lines running under the plating. Deep enough to feel this with your finger. Looks like tool chatter or something. Both sets of bearings had it on the same lower thrust shell.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: FM Bearing defect [Re: turbobitt] #213483
02/04/09 12:19 AM
02/04/09 12:19 AM
Attachment no worky
Re: FM Bearing defect [Re: Cab_Burge] #213484
02/04/09 12:22 AM
02/04/09 12:22 AM
Southington Ct.
Southington Ct.
Sorry, Here it is..
Re: FM Bearing defect [Re: turbobitt] #213485
02/04/09 12:29 AM
02/04/09 12:29 AM
Looks like a 3/4 groove bearing to me, is the other side the same way? If not something is really wrong, send them back if the other side is not identicle to that side
Re: FM Bearing defect [Re: Cab_Burge] #213486
02/04/09 01:27 AM
02/04/09 01:27 AM
Southington Ct.
Southington Ct.
It is a 3/4 groove and the other side doesn't have the chatter defect.
Re: FM Bearing defect [Re: turbobitt] #213487
02/04/09 03:43 AM
02/04/09 03:43 AM
Brisbane Australia
572B1 Offline
572B1  Offline
Brisbane Australia
I have federal mogul 119m 3/4 groove mains. I just checked them,and mine are smooth all the way around on uppers and lowers.No chatter marks. Rob.
Re: FM Bearing defect [Re: 572B1] #213488
02/04/09 09:19 AM
02/04/09 09:19 AM
Southington Ct.
Southington Ct.
That is the same P/N. This is the second set that I got like this. Both have been sitting in the box for about a year. If I got two sets, than there must be a lot of defective product out there. What are the chances of winning the Lotto twice.
Re: FM Bearing defect [Re: turbobitt] #213489
02/04/09 09:54 AM
02/04/09 09:54 AM
Brisbane Australia
572B1 Offline
572B1  Offline
Brisbane Australia
I have a set of 119m-10s on order through dan at performance only racing.I will get him to check mine before they leave the states. rob
Re: FM Bearing defect [Re: turbobitt] #213490
02/04/09 10:15 AM
02/04/09 10:15 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Yes I have seen that and have used them with no problems.
