How do you bend the tabs on the gas pedal bezel? #2132209
08/13/16 08:36 PM
08/13/16 08:36 PM
Pewaukee, WI
Airgrabber Offline OP
Pewaukee, WI
I have tried both a needle nose and a channel lock pliers and wrecked 2 accelerator bezels now. Someone suggested a channel lock pipe wrench too. Same thing. These repo-parts are not like the originals. I wonder if a Vice grip needle nose would work by bending 1 side down first before installing it on the pedal? What have you guys done in the past that works. Thank you.
help
Re: How do you bend the tabs on the gas pedal bezel? [Re: Airgrabber] #2132237
08/13/16 09:23 PM
08/13/16 09:23 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
help
I usually use my fingers to bend the 4 tabs over
Re: How do you bend the tabs on the gas pedal bezel? [Re: DAYCLONA] #2132248
08/13/16 09:50 PM
08/13/16 09:50 PM
if they are real brittle what about heating them up with an acet torch (grab a helper!) then bending them clos(er) to their final position?
Re: How do you bend the tabs on the gas pedal bezel? [Re: Airgrabber] #2132347
08/13/16 11:54 PM
08/13/16 11:54 PM
Pewaukee, WI
Pewaukee, WI
The Gas pedal bezel has 8 tabs about 1/8" long. There is mo way that I can bend them over with my fingers.
Re: How do you bend the tabs on the gas pedal bezel? [Re: Airgrabber] #2132349
08/13/16 11:58 PM
08/13/16 11:58 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
Try using a flat screwdriver and gently pressure the tabs while holding the other side flush against the rubber pad with your hand
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: How do you bend the tabs on the gas pedal bezel? [Re: Airgrabber] #2132354
08/14/16 12:07 AM
08/14/16 12:07 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Take what ever size channel locks that fit and wrap masking tape around the jaws so they won't scratch.
Re: How do you bend the tabs on the gas pedal bezel? [Re: Airgrabber] #2132404
08/14/16 01:11 AM
08/14/16 01:11 AM
5thAve Offline
5thAve  Offline
I've always pressed the side of a flat screwdriver into them or used pliers.
