Spring seat pressure ? #213201
02/03/09 05:56 PM
02/03/09 05:56 PM
Alberta, Can
JUST_N_TIME Offline OP
Alberta, Can
What are the downsides of having too much seat pressure with a hydraulic cam?
Is 160#s too high for seat pressure running a hydraulic cam?
thanks
Re: Spring seat pressure ? [Re: JUST_N_TIME] #213202
02/03/09 06:16 PM
02/03/09 06:16 PM
NC
440Jim Offline
440Jim  Offline
NC
I don't know how much is too much, but I have always followed the 90-120 lbs seat pressure for hydraulic lifters. The open pressure is a concern too.
Re: Spring seat pressure ? [Re: JUST_N_TIME] #213203
02/03/09 08:54 PM
02/03/09 08:54 PM
Vacherie, Louisiana
SuperStocker Offline
super gas
super gas
Vacherie, Louisiana
It depends on the type of hydraulic lifter. 160# on seat with a conventional hydraulic lifter is asking for problems.
Re: Spring seat pressure ? [Re: SuperStocker] #213204
02/03/09 10:54 PM
02/03/09 10:54 PM
Ohio
jdfpam Offline
jdfpam  Offline
Ohio
If you are looking to run that kind of spring pressure on a cast cam, you had better look into the Shubeck style puck lifters. I am a dealer for them, they are now a great product when used as designed. If you would like any more information, please call or PM me.
Jeff Day
Precision Automotive Machine
Canton, Ohio
(330)456-3045
Re: Spring seat pressure ? [Re: JUST_N_TIME] #213205
02/04/09 12:01 AM
02/04/09 12:01 AM
I have several motors with 150 to 175 lbs on the seats and 360 to 375 lbs over the nose with Comp Cams hydraulic lifters, I shift them at or above 6600 rpm at the track. Both motors work well and I have not seen any adverse effects from those pressures BTW, I do use around .012 to .015 lifter preload cold so
Re: Spring seat pressure ? [Re: Cab_Burge] #213206
02/04/09 12:19 AM
02/04/09 12:19 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Coming from Cab, thats good info and good news IMO. As is JDPAM,s info in reguards to the shafts tortional cumalitives effects of extra spring pressure on a cast shaft. mike
