Just removed the 6 point bar from my Duster.
Will be having a welder install in a 12 point cage. In the next couple of weeks.
Question is how weld install hoop and struts to the main bar and weld all the way around bars when the bar needs to be very tight to roof for adequate headroom.
Is thier a preferred method ? Holes in floor to drop hoop down for welding ?
Tilting bar forward for welding main hoop ?
Any suggestions would be appreciated, welder is highly skilled but does not have experience installing a roll cage.
