Re: Vinyl top pros and cons?
[Re: dogdays]
#2134441
08/16/16 04:28 PM
08/16/16 04:28 PM
Posts: 20,464 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
I was lucky that my current car had no rust at all under the vinyl top. Hardly any paint on the top of the roof at all - just red oxide primer overspray. Tons of glue though, and that is probably what saved it from rusting?
Be sure if you put a top on to not cut into the paint when trimming it to size. Seems obvious, but it does happen.
If that Cuda was mine I'd do a white top and white hockey stripes.
Not sure what is safe to put on them. I have had two darts with vinyl tops that were in nice shape, but dry. As soon as I started applying stuff to shine them up they split in the middle of the roof. I'd probably get ahold of Kee and ask them what to do to make them last.
Edit: You could also paint the roof a different color and put the vinyl top trim on as Mopar did offer two tone paint schemes.
Want something nobody else has? Vinyl wrap the flower pattern onto the roof and then do the hockey stripes the same way.
[Re: Kern Dog]
#2134888
08/17/16 02:10 AM
08/17/16 02:10 AM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
The factory did not paint the top on a vinyl top car. These cars spent many years outside as daily drivers. The rust is a long term problem.
If your collector car has been restored and kept indoors rust under the top will not be an issue. Are you sure about that? Seems that they spread filler on the C panel seam, primed the car and put at least a cursory coat of paint over the primer. I've had a few vinyl top cars and without fail they were painted up to the top of the pillars and sail panels with red oxide primer exposed on the top. All were 69-70 model years.
I’m listening.
[Re: an8sec70cuda]
#2137649
08/21/16 02:35 AM
08/21/16 02:35 AM
Posts: 43,099 Bend,OR USA
Cab_Burge
My first legal NHRA stocker was a 1970 Baracuda with a hemi and 4 speed, it was originally a 383 4 speed car, slime green. It was grey or silver with a black vinyl roof when I got it in 1973. I had it painted B5 blue and kept the black vinyl roof That car was a slug with the 4 speed and 9 inch slicks, 2160 lbs on the front tires and 1280 lbs on the rear tires with no driver when I finally did the front and rear weight check I took it home and never race that car again after that race , that was probally one of the smartest things I've done racing
