Re: One last hurrah
[Re: gdonovan]
#2161401
09/25/16 03:04 PM
09/25/16 03:04 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Very nice! My best run from the other night with the bottle was essentially a carbon copy to yours, luckily (?) my tech guys are fairly lax, hasn't looked under the hood this year, no comment on sub 11.50 either.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
Re: One last hurrah
[Re: fast68plymouth]
#2161404
09/25/16 03:09 PM
09/25/16 03:09 PM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
A good converter will be the biggest instant improvement to the ET.
Agreed.
"I think its got a hemi"
Re: One last hurrah
[Re: OUTLAWD]
#2161450
09/25/16 04:21 PM
09/25/16 04:21 PM
gdonovan
Oakdale CT
Very nice! My best run from the other night with the bottle was essentially a carbon copy to yours, luckily (?) my tech guys are fairly lax, hasn't looked under the hood this year, no comment on sub 11.50 either. That is pretty flipping cool! I got flagged down before I even hit the timing shack, I suspect the tower gave the safety guy a heads up that I had run faster than tech card indicated.
Re: One last hurrah
[Re: gdonovan]
#2161485
09/25/16 05:34 PM
09/25/16 05:34 PM
gdonovan
Oakdale CT
Anyone running a PTC converter? Thinking about calling John at CRT and ordering a 9.5" street/strip unit.
Maybe if I'm quick I can have the car back out before the end of the season ;-)
Re: One last hurrah
[Re: gdonovan]
#2161519
09/25/16 06:45 PM
09/25/16 06:45 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I like my PTC convertor. I just called and talked to Kenny the owner and told him what I had and he did a custom.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: One last hurrah
[Re: GTX MATT]
#2161812
09/26/16 05:23 AM
09/26/16 05:23 AM
gdonovan
Oakdale CT
Direct Connection .528 mech with 284 duration. I use to run a .590 but one of the lobes went south.
Re: One last hurrah
[Re: J. Hammer]
#2161827
09/26/16 07:40 AM
09/26/16 07:40 AM
gdonovan
Oakdale CT
Using MPH/weight 431fwhp/540fwhp. Holley states 52/52 is 150 shot Monte states closer to 100 hp Calculating from mph = 109 hp Calculating from ET = 131 hp Hmmm... Monte is the Holley HP rating calculated at 5 psi fuel pressure?
Re: One last hurrah
[Re: gdonovan]
#2162596
09/27/16 08:24 AM
09/27/16 08:24 AM
gdonovan
Oakdale CT
Dropped a line to John this morning with all the specs of the car, see what he states for a converter. A nice crisp 1.6 short time would be just what the cars needs.
Re: One last hurrah
[Re: gdonovan]
#2162847
09/27/16 03:31 PM
09/27/16 03:31 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Using MPH/weight 431fwhp/540fwhp. Holley states 52/52 is 150 shot Monte states closer to 100 hp Calculating from mph = 109 hp Calculating from ET = 131 hp Hmmm... Monte is the Holley HP rating calculated at 5 psi fuel pressure? MPH is power, ET is how you get the car down the track. But either way the advertised HP numbers are strictly based on the amount of nitrous flow. If you flow X amount of nitrous, you will make roughly this much extra power. It's not a hard and fast number and because nitrous effects different motors different ways. It adds torque, so if it loosens up your way tight converter, the car will leave harder and run quicker.........BUT, the mph is how much power it actually added. If you go 12.50 on one run and 12.30 on the next, because the car spun, but run the same mph.......did you have more power on 12.30 run? Some seem to want to debate, but MPH is power......period
Re: One last hurrah
[Re: gdonovan]
#2163928
09/28/16 09:53 PM
09/28/16 09:53 PM
gdonovan
Oakdale CT
Just checked the stall on the converter, 3100 rpm steady (not a flash) with the brakes locked in third.
It was suggested to just send the current converter out for adjustment, thoughts? Converter internal Voodoo I'm weak on.
Re: One last hurrah
[Re: gdonovan]
#2164113
09/29/16 01:43 AM
09/29/16 01:43 AM
Posts: 14,491 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
A question and a comment.....
Did you call PTC, tell them your combo and goals, and they suggested that reworking your stock 11" converter would be the hot ticket for you to be running mid/low 1.60 60' times?
I have never (nor am I aware that any of my customers) experienced $700-800 converter performance out of a $350-400(new) converter.
Re: One last hurrah
#2164161
09/29/16 05:52 AM
09/29/16 05:52 AM
gdonovan
Oakdale CT
Did you call PTC, tell them your combo and goals, and they suggested that reworking your stock 11" converter would be the hot ticket for you to be running mid/low 1.60 60' times? I'm going through a PTC distributor, who is a pretty sharp guy. I have never (nor am I aware that any of my customers) experienced $700-800 converter performance out of a $350-400(new) converter. I would be inclined to agree; I'm not sure if the distributor is trying to save me money reworking my existing unit or feels that reworking the unit is all that is required. Was going to call at lunch today to see which way he is going. A factor is that it is a street car and primarily used as such, it might be a large consideration in his thoughts.
Re: One last hurrah
[Re: Monte_Smith]
#2164172
09/29/16 07:27 AM
09/29/16 07:27 AM
gdonovan
Oakdale CT
No debate Monte, the program I use for calculating power provides both from ET and MPH. Calculated from ET assumes a consistent launch which the car was pretty consistent. FYI I take numbers generated from both with a grain of salt since there are many factors that come into play. As MPH rises so does power requirements to buck the air and bottlenecks in the vehicle's systems start to rear their ugly head too. My Reliant is a perfect example of that. I could show you a timeslip where the car is accelerating at every point on the track to the 1000 foot mark... and then it falls on its face from there on out. There is a limitation caused by the bore and stroke of the motor combined with the intake runner design. When the car comes back out it will be running a shorter stroke and custom intake to alleviate the issue. Clearly in that case HP calculated by MPH isn't going to give you a true indication of the cars potential best ET. Just something to think about...
Re: One last hurrah
[Re: gdonovan]
#2164195
09/29/16 09:05 AM
09/29/16 09:05 AM
gdonovan
Oakdale CT
Headers came in, excellent.
Re: One last hurrah
[Re: gdonovan]
#2164660
09/29/16 08:45 PM
09/29/16 08:45 PM
gdonovan
Oakdale CT
Well I'm on the fence now.
Transmission guys states since I just want "a bit more" go with a modified converter. Converter guy states "go with a 9.5" and see big results.
Anyone with a 9.5" converter care to chime in or drop me a PM, its the direction I'm inclined to go but would like some feedback.
Downside on the 9.5" is it would be 2-3 weeks at best before I'd have one in hand.
Re: One last hurrah
[Re: gdonovan]
#2164771
09/29/16 11:12 PM
09/29/16 11:12 PM
Posts: 43,096 Bend,OR USA
Cab_Burge
Downside on the 9.5" is it would be 2-3 weeks at best before I'd have one in hand. I've ran every size converter you are talking about(12.11.10,9,and 8 inch) on the street and at the track, the older B&M O69J nine inch worked really well on the street and at the track until it broke The last T/A 8 inch SS converter I put in my old Duster is still being used at the track and on the street by the new owner It was easier to drive and .2 ET quicker and 2.0 MPH faster in the 1/8 mile than the ten inch custom built street and strip converter I had built for that car off of the dyno sheets for the motor Buy the best converter you can get, do NOT compromise All the good eight race converters I know of multiply torque more at the hit of the throttle, not so much on the larger size converters
Re: One last hurrah
[Re: Cab_Burge]
#2164961
09/30/16 07:28 AM
09/30/16 07:28 AM
gdonovan
Oakdale CT
I've ran every size converter you are talking about(12.11.10,9,and 8 inch) on the street and at the track, the older B&M O69J nine inch worked really well on the street and at the track until it broke The last T/A 8 inch SS converter I put in my old Duster is still being used at the track and on the street by the new owner It was easier to drive and .2 ET quicker and 2.0 MPH faster in the 1/8 mile than the ten inch custom built street and strip converter I had built for that car off of the dyno sheets for the motor Buy the best converter you can get, do NOT compromise All the good eight race converters I know of multiply torque more at the hit of the throttle, not so much on the larger size converters What kind of manners on the street am I looking at when driving about with a 9.5" converter?
