W5 stuff #213003
02/03/09 02:11 PM
02/03/09 02:11 PM
nc
E
emarine01 Offline OP
E
nc
I just talked with a mopar perf parts guy in SC & he said Mopar Perf dosent stock valve seals for w5s anymore , My heads have that small under .500 guide dia , might be .498 or so , I cant remember , Any body have any luck finding them? or am I the only one running this guide dia.
Re: W5 stuff [Re: emarine01] #213004
02/03/09 03:51 PM
02/03/09 03:51 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Do you need SEALS or GUIDES?
I don't think MP ever sold seals, but I could be wrong.
W5's from factory use a .494" guide in a .492" hole. 3/8" ID with a .531" seal area..... so a factory W5 would just need a normal 3/8" .531" valve seal. You can get those anywhere....
The valve guides are a pain...... normally we just use a core reamer & ream the guide holes in the head to .500" & put normal .502" guides in them.
Re: W5 stuff [Re: RyanJ] #213005
02/03/09 06:32 PM
02/03/09 06:32 PM
nc
E
E
nc
thanks for the info , is there a better seal than the mopar perf white critters? seems every year when we lay the up for a few months the seals leak
Re: W5 stuff [Re: emarine01] #213006
02/03/09 06:34 PM
02/03/09 06:34 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
The white seals are Teflon. You want to use a Viton seal.... Any machine shop should have them or can get them for you.
