Which rearend lube & how to seal a Dana? #212992
02/03/09 01:58 PM
02/03/09 01:58 PM
mikemotorhead Offline OP
super street
super street
I'm changing the fluid and putting the cover back on. It seem like no matter what I do the rear starts to seap about half way thru the season. What are your secrets to keeping the fluid in the rear?
Thanks Mike
p.s. Spool with 4.10's pro gear
Re: Which rearend lube & how to seal a Dana? [Re: mikemotorhead] #212993
02/03/09 02:06 PM
02/03/09 02:06 PM
LENOX , MI
KMPX2 Offline
mopar addict
KMPX2  Offline
mopar addict
LENOX , MI
I have 2 ways that always work 1. Paper gasket with Indian Head gasket sealer (little brown bottle stuff is great) or if you use RTV. Apply a nice bead and loop around each bolt hole. Let it start to dry alitte then bolt on the cover.
Re: Which rearend lube & how to seal a Dana? [Re: KMPX2] #212994
02/03/09 02:20 PM
02/03/09 02:20 PM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
Also make sure your cover is straight and the area around the bolt holes is not deformed (raised up).
Re: Which rearend lube & how to seal a Dana? [Re: mikemotorhead] #212995
02/03/09 02:22 PM
02/03/09 02:22 PM
organ
maximum entropy Offline
Happy Birthday maximum entropy  Offline
organ
"right stuff" will seal anything, anytime. period. except fuel, of course.
Re: Which rearend lube & how to seal a Dana? [Re: maximum entropy] #212996
02/03/09 02:28 PM
02/03/09 02:28 PM
super street
super street
I use RTV but it only lasts 1/2 of the season!
Right Stuff HUH?
Mike
Re: Which rearend lube & how to seal a Dana? [Re: mikemotorhead] #212997
02/03/09 02:32 PM
02/03/09 02:32 PM
organ
organ
right stuff is AMAZING. and expensive! follow their instructions. assemble immediately. and, you can fill it with oil immediately.
Re: Which rearend lube & how to seal a Dana? [Re: maximum entropy] #212998
02/03/09 02:40 PM
02/03/09 02:40 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
i thought dodge had a TSB about synthetic gear oils and standard rtv not working well on the trucks. anyway i'm using rtv with syn and have no leaks, but did follow the recomendations of some of the posts above.
Re: Which rearend lube & how to seal a Dana? [Re: maximum entropy] #212999
02/03/09 02:41 PM
02/03/09 02:41 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
GE Silicone I.
Comes in tubes from Home Depot, Lowes, ect.
Re: Which rearend lube & how to seal a Dana? [Re: Neil] #213000
02/03/09 03:03 PM
02/03/09 03:03 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
Royal Purple 85/140 no gasket gray rtv no leaks
Re: Which rearend lube & how to seal a Dana? [Re: cudabunch] #213001
02/03/09 05:18 PM
02/03/09 05:18 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
What RTV are you using? Also is it a stamped steel cover?
We use Ultra Black RTV with the heavy Aluminum cover that has the bearing cap supports built in. Never had a leak.
As far as fluid, Mobil 1 75w/90. (4.10 w/spool)
Re: Which rearend lube & how to seal a Dana? [Re: cl440] #213002
02/03/09 06:45 PM
02/03/09 06:45 PM
Connecticut
5126brl No more Offline
Connecticut
Use Honda Bond to seal it!! Then a chisle to ever get it off!
