Re: File Fit Ring End Gap Specs on Street Motor ?
[Re: Classof70Chally]
#212890
02/03/09 12:42 PM
02/03/09 12:42 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
What kind of rings are they? (brand...) I would use the ring manufacturers spec, with some modifications..lol. I run the tops at the "4 per inch of bore" rule and round up. So 4.355" would get an .018" top ring gap. Unless the piston requires differently. Diamonds don't take anything sprecial. I also run and extra thou per inch of bore on the 2nd ring. A lot has changed in the understanding of how rings work, and the 2nd ring with a larger gap can make more power and run cleaner.
#212891
02/03/09 12:47 PM
02/03/09 12:47 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I'm getting ready to file fit the rings on my 440 street motor for my sig car and wanted some input on the ring end gap. Most of the tech articles I've read seem to want .004" per inch of bore for the top ring and .003" per inch of bore on the second ring. With a finished bore of 4.350 this works out to .018" for the top (rounded up from .0174) and .013 for the second. The pistons are forged Diamond units made from 4032 aluminum which has 15% silicone added to reduce expansion by 15% . The piston to bore clearance is .0045 as per Diamonds recommendation. The motor will be street driven with NO power adders and a max rpm of around 6,000. Any input would be appreciated. Thanks.
I tend to use the manufacturers specs but now days I open the second ring gap up a little larger than the top.... reason is, if the pressure got by the top I dont want to try and hold it in and cause ring flutter on both rings
#212896
02/03/09 02:06 PM
02/03/09 02:06 PM
Posts: 5,080 organ
maximum entropy
organ
yes. and i'm VERY surprised they did not recommend a bigger second ring gap. almost everyone does now.
#212897
02/03/09 02:13 PM
02/03/09 02:13 PM
MR_P_BODY
Okay, so if Total Seals specs show .020 for the top then maybe go .022? But they show a spec of .015 or .016 for the second then you would go .022 to .026 ???
I would set them at top ring--- .020 second ring --- .022 also I dont set them loose.... try to be accurate with your feeler gauges(vertical and square). Dont over heat the engine the first few times you fire it up
#212900
02/03/09 03:27 PM
02/03/09 03:27 PM
OK. So it looks like I will split the difference here and go with .022" for the top ring and .024" for the second ring. Is there anyone here that sees a problem with those specs ???
yes, i see a problem with it. first off, it's a street engine, secondly, it's completely N/A. follow the ring manufacturers specs for your application. round up to the nearest .001 for the gap recommended. the pistons you have, which are high silicon, not silicone, also have a built in balance groove between the top and 2nd ring. this will eliminate the need for such a wide 2nd ring gap. if it were a racing engine i would have a different recommendation.
#212901
02/03/09 03:47 PM
02/03/09 03:47 PM
Posts: 5,080 organ
maximum entropy
organ
that groove is called an accumulator groove, btw.
[Re: maximum entropy]
#212903
02/03/09 04:02 PM
02/03/09 04:02 PM
the 2nd ring will never see the same amount of heat as the top ring, especially in a street application. that combined with the accumulator/ channel/ groove, is the reason for leaving the 2nd ring a small amount tighter in the bore. (less expansion}
it's also called a pressure balance channel, a pressure balance groove and a few other things. different names from different piston manufacturers.
#212904
02/03/09 04:44 PM
02/03/09 04:44 PM
Posts: 5,080 organ
maximum entropy
organ
there are definitely numerous ways to skin that cat. the tight gaps concern me. .013 on the second is really tight. be very careful to get the gaps perfectly square ( as you always should ), and don't overheat that thing. i have a very similar build in my street strip car, and i'm at .022 top and .024 second, and have as near zero leak down as a conventional ring engine can have. i seriously doubt one could find a measurable difference in leak down between .013 and .024 on the second ring. the extra silicon, btw, makes for a much more scuff resistant piston. good choice.
