Re: 1989 b250 318 tbi need more power
[Re: sshemi]
#2126499
08/06/16 12:42 PM
08/06/16 12:42 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
You're not going to get there with TBI.
That engine needs compression and a cam to get you where you want to be. The computer won't know how to inject more fuel to make the power necessary. Essentially, a 5.2/5.9 magnum swap is a better idea.
My bro-in-law had an 89 D150 with the tbi 318 and it didn't have the nuts to pull a sprint car up a long hill. He would be down to 30-35 mph with it floored trying to make that slope.
[Re: sshemi]
#2126588
08/06/16 04:03 PM
08/06/16 04:03 PM
DaytonaTurbo
Manitoba, Canada
How about the 360 ecu and tbi?
You're just going to over fuel and throw more money away. The TBI 318 has crap compression, crap heads, crap cam, crap everything. Even a 90's magnum 318, which improved on much of this, is still going to be a dog in a 2500 van with a trailer and car.
[Re: sshemi]
#2126917
08/07/16 02:00 AM
08/07/16 02:00 AM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
The best thing you can do to make this pull your load is to change the gearing in the axle.
I have a 1987 D100 with a 318 and I plan to use it to pull my Ramcharger on a car trailer. The truck has 245/75R16 tires on it with a 8.25" rear with a tall gear. I built a Dana 60-2 for it that has 4.10 gears and will probably swap it in the fall. I also have a 1990 360 roller cam motor that will go in sometime later after I build it.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: sshemi]
#2127033
08/07/16 11:37 AM
08/07/16 11:37 AM
feets
Senior Management
Senior Management
Irving, TX
Good point on the gears. Stuffing something like a 4.10 under the van would bump the pulling power significantly assuming yours has the 3.21 or 2.93 rear.
The TBI computer will be your limiting factor. Toss all the related stuff in the recycle bin, build a decent motor, and put the A500 on pressure and vacuum switches to control OD.
[Re: sshemi]
#2127769
08/08/16 12:02 PM
08/08/16 12:02 PM
DaytonaTurbo
Manitoba, Canada
Ok. So how about shaving the heads to get more compression, doing some fancy valve job, and shangi g the cam to a comp cams no computer mod cam? You may get a little more power out of it, but once you put that load on the van, it's still going to be a dog.
[Re: sshemi]
#2128557
08/09/16 11:32 AM
08/09/16 11:32 AM
feets
Senior Management
Senior Management
Irving, TX
If you ditch the TBI you will have a whole world of options open to you. Instead of digging up a 360 you can always stroke the 318 and build some torque with it. http://www.manciniracing.com/smallblock318.htmlThis, of course, means trashing the TBI but you will have the power you need to haul your car.
[Re: sshemi]
#2128905
08/09/16 08:10 PM
08/09/16 08:10 PM
Posts: 4,205 New York
polyspheric
New York
Water injection (homemade is fine) + 5 degrees more lead, and 10 degrees more vacuum spark may add 3 mpg.
Boffin Emeritus
[Re: sshemi]
#2129377
08/10/16 12:25 PM
08/10/16 12:25 PM
feets
Senior Management
Senior Management
Irving, TX
Doing that work will help but it won't make it into a good tow vehicle. It will still be greatly underpowered.
[Re: sshemi]
#2129453
08/10/16 01:48 PM
08/10/16 01:48 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
Did the same on a 88 D250 318...removed the tbi and all the smog equipment...got headers with dual exhaust, eddy performer intake...eddy performer carb, and hei distributor...runs a ton better....
completely removed computer and rewired engine compartment.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: sshemi]
#2130221
08/11/16 12:11 PM
08/11/16 12:11 PM
Posts: 2,128 sweden
sshemi
sweden
[Re: moparborn]
#2130309
08/11/16 02:17 PM
08/11/16 02:17 PM
70AARcuda
las vegas
I used the original in tank pump,just put a return regulator on. same thing I did, 89 318 is still a LA engine, no need to change out timing chain cover plus mine has the eccentric for the manual fuel pump.
Tony
[Re: Mr.Yuck]
#2130365
08/11/16 03:37 PM
08/11/16 03:37 PM
feets
Senior Management
Senior Management
Irving, TX
You can't tow with the OD on, or you shouldn't. Load of crap. My 92 has towed through 30 states in OD, deserts to mountains. 292,000 miles and counting. Keep it cool and you'll be fine.
[Re: sshemi]
#2130445
08/11/16 05:39 PM
08/11/16 05:39 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
This sounds a lot like one of those situations where the choice is either; do it right(remove the tbi and all smog stuff, upgrade induction & exhaust), or.......do it over(because you thought you could get "there" with the tbi and smog stuff in place).
IMO any efforts revolving around retaining any of the factory tbi/smog related equipment will end up providing disappointing/unsatisfactory results.
Years ago we replaced a 318-2bbl with a re-ringed 360 in a 77 B200 van with a performer, 600vs Holley, comp he268 cam, recurved dist and headers...... And it was a pretty darn good tow vehicle.
[Re: feets]
#2130906
08/12/16 09:27 AM
08/12/16 09:27 AM
Challenger 1
Cincinnati, Ohio
You can't tow with the OD on, or you shouldn't. Load of crap. My 92 has towed through 30 states in OD, deserts to mountains. 292,000 miles and counting. Keep it cool and you'll be fine. This is a load of crap, the OP has a 318 and should not tow in OD. He don't have a diesel engine. Why even post that feets? Proud of your diesel? To the OP, I know your in Sweden...but I would not even try to tow a car with a 318 unless it's flat and a short distance.
[Re: Challenger 1]
#2130946
08/12/16 11:04 AM
08/12/16 11:04 AM
feets
Senior Management
Senior Management
Irving, TX
You can't tow with the OD on, or you shouldn't. Load of crap. My 92 has towed through 30 states in OD, deserts to mountains. 292,000 miles and counting. Keep it cool and you'll be fine. This is a load of crap, the OP has a 318 and should not tow in OD. He don't have a diesel engine. Why even post that feets? Proud of your diesel? To the OP, I know your in Sweden...but I would not even try to tow a car with a 318 unless it's flat and a short distance. If he is flat and level then OD won't hurt with a moderate load. As soon as he looks at the mountains then that 318 is going to need a lower gear. If he manages to build a little torque and the engine can handle OD without a struggle then he will be fine. There is no problem towing in OD if the engine can provide enough torque to get the job done. We all know that job varies with terrain and load. In his application, the transmission will kick out of OD when necessary. The no-towing-in-OD nonsense goes way beyond this thread. It even pops up in the diesel forums from time to time.
