What kind of MPG increase did you get from adding OD?
#2125647
08/05/16 12:47 PM
08/05/16 12:47 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I'm looking at dropping my 518 in the Imp and wondered what kind of mpg increase you guys have seen.
The primary concern is to drop the engine rpm because I've become accustomed to the lower engine speeds in newer vehicles. Any mpg increase would be a bonus.
My old beast tips the scales at 5100 lbs empty and runs a 29" tire on a 3.23 rear gear. The 518 would drop the rpm nicely and make for a better driving experience. The 440 should have ample torque to pull the car at the new rpm.
I've had the transmission and Ultrabell sitting around for the better part of 10 years. Might as well do something with them.
Re: What kind of MPG increase did you get from adding OD?
[Re: feets]
#2126059
08/05/16 08:32 PM
08/05/16 08:32 PM
Posts: 5,788 Hamilton, Ontario Canada
Magnum
I had no change but I did it backwards. Went from OD to no Od.
87 Ram D100 reg cab shortie. Swapped in a 5.9L Magnum and a 518. With 3.55 gear and a 28" tire.
I did not drive for mileage. I did much of my driving at a comfortable 120km/hr.
I lost overdrive but continued to drive the truck in 3rd gear. Except now 120 km/hr was too much rpm so I cruised the right lane at 105 which was a little high in the rpm but with the reduced speed I was still getting 18-19mpg.
After losing all confidence in the 518, I swapped in a NV3500 5 speed. Then I was finally had a mileage improvement.
[Re: dezduster]
#2126081
08/05/16 09:11 PM
08/05/16 09:11 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Milage increase I don't know. However in my 422 ci duster 3500#with manual 5 speed od it would get up to 22 23 mpg on the highyway at 70 75 mph. This is with 34 ° maechanical and 12° vacuum for total of 46° Total timing. This all being very conscious of milage! But even when driving spirited and careful of the law 18 19mpg was the norm. Gears are same as yours and tires are very close 275 60 15 BFG drag T/As. Rpms at 70 is 1700 in OD I can't give any prior results, as I stuff an OD into the build from the start, but my Daytona 440/6 pack with a Keisler TKO 600 5spd .064 OD, 4:10 Dana 60, 27" tires, will do 20-22 MPG highway on long cross country cruises at 70-75 MPH, on the street where I have a hard time keeping my foot out of the throttle, it'll suck it down to 8-10 MPG On the HEMI cars with a Keisler TKO 5 spd .64 OD, 3:54 and 4:10 rear gears, avg highway at 70-80 MPH cruising would be 16-18 MPG, again on the street blasting it, mileage could get sucked down to 5-8 MPG Played around in the past with various OD's in the .80- .70 range, results were often minimal for the effort, you really need to step into the .64-.50 range for the cost of adding an OD to "pay off"
[Re: DAYCLONA]
#2126278
08/06/16 01:09 AM
08/06/16 01:09 AM
Posts: 1,653 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Played around in the past with various OD's in the .80- .70 range, results were often minimal for the effort, you really need to step into the .64-.50 range for the cost of adding an OD to "pay off" Exactly. I have a Tremec 6-speed in a 2005 GTO, 400 hp, 3.90 rear, 25" dia tires. Sixth gear 0.50:1 is super - runs about 1800 rpm at highway speeds. But 5th gear 0.75:1 pretty much never gets used - it's a waste, not enough reduction. You really need the 0.50:1.
[Re: feets]
#2126279
08/06/16 01:12 AM
08/06/16 01:12 AM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
I've had the transmission and Ultrabell sitting around for the better part of 10 years. Might as well do something with them. If he doesn't see this thread, ask Stu...he has an OD (4L60E I think) in his Road Runner...and it gets driven a bunch of course..
[Re: feets]
#2126332
08/06/16 03:25 AM
08/06/16 03:25 AM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
I can't speak for mileage improvement, but I get 15 average in my 68 Charger 512cid,a518 w/lock up & 3.23 gear 28" tire.
[Re: feets]
#2126370
08/06/16 08:50 AM
08/06/16 08:50 AM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
2-bbl 318 / 904 & 7-1/4" 3.23 rear axle. lousy, neglected engine tune / very lean @ highway speeds / worn timing chain; 6-7mpg daily / 17mpg highway
4-bbl 318 / A518 & 8-3/4" 3.55 rear axle. AFR tuned engine / new timingchain / recurved distributor / better ignition ; 11-12mpg daily / 15mpg highway
65mph = 2200 rpm @ 20" engine vacuum A518 = OD only, no lockup Fuel = LPG
IMO, the heavier internals and friction of the A518, and the absense of convertor lockup and lack of cr and strong torque in the engine, dampened my highway mileage, compared to the 904 at least.
But, over the years the car has become much more fun to drive with the 4-speed auto.
At one time I had a 518 with OD and LU installed, which was even more fun, where the Lockup pretty much felt as a short 5th gear.
[Re: Jwilli500]
#2126446
08/06/16 11:44 AM
08/06/16 11:44 AM
feets
Senior Management
Senior Management
Irving, TX
I've wondered the same thing, so I'll be watching this one. Are you going with a lockup or non-lockup converter? My transmission is set up for a lock up converter.
[Re: moparx]
#2126493
08/06/16 12:34 PM
08/06/16 12:34 PM
feets
Senior Management
Senior Management
Irving, TX
feets, what carb are you using ? have you tailored your distributor curve, including vacuum advance, for mileage now, or will you be doing that once you get the o.d. installed ? are you going to something deeper than 3.23 gears to get the mass rolling easier, then using the o.d. to lower the highway rpm's to acceptable levels ? Right now the engine is in pieces. I plan on dropping a FiTech system on the car and setting the distributor for best torque/mpg. A proper Imperial is not a performance car.
[Re: feets]
#2126555
08/06/16 02:33 PM
08/06/16 02:33 PM
Posts: 704 USA
rftroy
USA
I have done this twice.
First was with a 69 Barracuda fastback. 318 with 360 1.88 heads; hyd cam w/specs midway between stock 318 and 340 cams. 3.23 axle. With standard 4 speed: 17-18 mpg highway With OD4: 24 mpg highway.
Second was 69 Barracuda conv. Slant 6, stock cam, Holley Economaster 1920 1 bbl. 2.76 axle With standard 4 speed: 19-20 mpg highway With OD4: 27.5-29 mpg highway.
Now have 2.94 axle (2.76 was just too low with OD). Haven't done a long range highway test yet, but around town stayed about the same at 22-23 mpg.
Robert
AAR 4-speed 3.91, Tor-Red; 70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy; 68 Formula S conv 383 4-speed 3.23, Electric Blue; 69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue; 78 Lil' Red Truck, Red; 70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
[Re: feets]
#2126609
08/06/16 04:33 PM
08/06/16 04:33 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
I am also amazed... my slightly warmed-over '70 Valiant (stock 383 rebuild, .484 purple shaft, 750 vac sec, dual-plane, A833, 3.23 rear) got about 15 mpg on the highway at 65 mph, around 12 mpg mixed city/hwy and my lowest tank was 8.3 mpg since it was all going to the store for a quart of milk 1/4 mile away And my '76 Valiant with stock /6 and OD A-833 (don't know the rear) would get about 23-24 mpg at a steady highway cruise. Maybe they're talking Imperial gallons?
