Crank case evac on street/strip car. Help me out please
#212046
02/02/09 05:04 PM
02/02/09 05:04 PM
Posts: 1,523 Oakley CA
69charger440_6pa
Oakley CA
Hey,
So I have been wondering, what is the best way to vent the crank case on a street strip car? I have a solid cammed 493 street/strip engine. Right now I am running a breather on one side and a pcv on the other. Are there better ways to do it? Dual breathers? Crank case evac using the headers? Vacume pump?
Thanks alot
1969 Charger R/T under construction 2014 Ram 3500 Cummins 2006 Corvette Z06 2015 Corvette Z06 2014 BMW M5
Re: Crank case evac on street/strip car. Help me out please
[Re: 69charger440_6pa]
#212048
02/02/09 05:28 PM
02/02/09 05:28 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You would be better off to use a vac pump on the street... with a exhaust system it would have to be a VERY low restriction to allow a header vac to work
[Re: moparniac]
#212051
02/02/09 06:08 PM
02/02/09 06:08 PM
MR_P_BODY
i am planning on running a evac system as i had the tubes welded into my 2" tti's already.. I plan on going 3.5" exhaust with dynomax bullets..
I dont recall what the restriction is on all of the assorted muffs but the lower the restriction the better the evac will work. A evac will pull about 5" hg max and for every in hg that your exhaust has it will lower the evac value
[Re: MR_P_BODY]
#212052
02/02/09 06:15 PM
02/02/09 06:15 PM
69charger440_6pa
Oakley CA
Does anyone make brakets for the vacuume pump that will work with Alt. and power sterring?
#212053
02/02/09 06:25 PM
02/02/09 06:25 PM
MR_P_BODY
That I do not know
[Re: MR_P_BODY]
#212054
02/02/09 07:04 PM
02/02/09 07:04 PM
Posts: 6,295 U.S.
moparniac
U.S.
I was having problems with vc gaskets pushing/splitting..... I was running a PCV and breather then.... dont know how much that mattered though... i hope the header evac helps my new engine setup.. how much does the vac pump pull... how much HP do you get out of the header evac vs the vac pump...
Mopar Performance
[Re: moparniac]
#212055
02/02/09 07:08 PM
02/02/09 07:08 PM
69charger440_6pa
Oakley CA
its recomended to pull 12"-15" of vacuume with the pump. It can pull more but you shouldnt with a wet sump. The header evac will only pull about 5". Power gains..... not to sure about the header evac, but the vacuume pump can pick you up some serious power. I have heard of 40+HP gains
#212058
02/02/09 07:30 PM
02/02/09 07:30 PM
Posts: 6,295 U.S.
moparniac
U.S.
Ill just get a monte smith N2O setup for that much..... yowza.....
Mopar Performance
#212059
02/02/09 07:54 PM
02/02/09 07:54 PM
Posts: 780 Woodinville, WA
Viol8r
Woodinville, WA
2" tti's w/3" tti x-pipe system and ultra flow mufflers.
I have the same exhaust set-up and have the evac kit sitting on the shelf, but I am very scared to try it!
[Re: Viol8r]
#212060
02/02/09 08:08 PM
02/02/09 08:08 PM
MR_P_BODY
All I can say is try it, if it fails cap off the nipple in the headers with a pipe cap
[Re: MR_P_BODY]
#212062
02/02/09 08:26 PM
02/02/09 08:26 PM
Posts: 9,116 Falconer, NY
KatFysh
Falconer, NY
I ran a Moroso evac on my Cuda with the blower. I had 2" Super Comps and 3" exhaust that exited right in front of the rear wheels and used the Bullets. The evac didn't work for me. Among other internal problems, I had valve cover and oil pan gasket leaks..I haven't figured out what I want to do with the Dak. It has 2" fenderwell headers,3" exhaust pipe and Bullets. Exits in front of the rear tires.. Kinda coincidental here.. The gaskets are seeping a little. I may pull the engine and install new gaskets before the tracks open..
When you decide to quit, THAT is the moment when you would've succeeded..
[Re: KatFysh]
#212063
02/02/09 08:42 PM
02/02/09 08:42 PM
MR_P_BODY
Put a vac/pressure combo gauge on the engine. If you are making pressure you either give it more venting (breathers) or put a vac pump on it.... of course this is if the engine isnt messes up inside like broken rings
Wedge If you pull the breather off the valve cover and rev it up a few revs you should feel it on your hand (sucking), if its not working you will feel it blowing on your hand(this is the part with the hose on it) also if its broken/failed the air will be hot(exhaust)
#212064
02/02/09 09:27 PM
02/02/09 09:27 PM
Posts: 1,646 Ontario,Canada
firefighter3931
Ontario,Canada
So I have been wondering, what is the best way to vent the crank case on a street strip car? Thanks alot
My setup ; raised breathers with baffled valvecovers and baffled tubes.
Ron
[Re: firefighter3931]
#212065
02/02/09 09:35 PM
02/02/09 09:35 PM
Posts: 6,295 U.S.
moparniac
U.S.
whats the point of a PCV then if the header evac dont work....
Mopar Performance
[Re: MR_P_BODY]
#212069
02/02/09 10:07 PM
02/02/09 10:07 PM
Posts: 6,295 U.S.
moparniac
U.S.
I dont have any type of hookup on the back of the valve covers... what about the back of the intake manifold?
edit. hooking it up to the VC gives out a pressure reading instead of vac reading...
Mopar Performance
[Re: Bill MeLater]
#212075
02/03/09 05:12 PM
02/03/09 05:12 PM
MR_P_BODY
I've always wondered what the differnce is between a pcv valve and a huge vacuum leak...
It has a controlled orfice which you over come when setting the carb
[Re: moparniac]
#212077
02/03/09 05:15 PM
02/03/09 05:15 PM
MR_P_BODY
gotch ya p..... but how did you hook up to the VC.... weld a fitting onto it or something....
I use a cast cover and I drilled and taped it for 1/8" pipe
[Re: moparniac]
#212078
02/03/09 05:24 PM
02/03/09 05:24 PM
MR_P_BODY
the one guya above just runs 2 breathers...
Understand something..... he will NEVER create a vac in the crank case, the most that he can do is get to 0 pressure. The purpose of a vac source is create a vac to help seal the rings
[Re: emarine01]
#212081
02/03/09 07:59 PM
02/03/09 07:59 PM
MR_P_BODY
I was following post so I hooked up a vacuum gauge to my sb running a header evac & found 1/2" HG total vac , went strait to header with gauge and had 2" total at 4500 rpm ,how much vacuum is needed to have any gain?
If you are reading any vac on the engine you are getting a gain...anything - of 0 is a gain
[Re: MR_P_BODY]
#212083
02/03/09 08:47 PM
02/03/09 08:47 PM
firefighter3931
Ontario,Canada
Agreed Mr.P, there is zero vacuum with a dual breather setup. How much vacuum does the typical engine have at WOT ?
PCV is nothing more than a controlled vacuum leak. I'm not a fan of introducing oil mist into the induction system.
Ron
[Re: moparniac]
#212084
02/03/09 08:56 PM
02/03/09 08:56 PM
firefighter3931
Ontario,Canada
so this wont hurt anything really just doesnt creat a vacuum... but I like i said before i read a pcv can be bad running back into the intake and cause plug misfire or something...
The dual breather system will allow the crankcase to ventilate itself. What do you think works better ; forcing all the crank case pressure through a 3/8in hose or letting it escape through a pair of 1.5in tubes w/breathers.
The bottom vent breathers can create a mess so that's why mine are raised on the VC....to allow for drainback.
Different strokes for different folks.
Ron
#212085
02/03/09 09:29 PM
02/03/09 09:29 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
Hey,
Thanks alot
I did it with my 496 Charger using Ultraflow mufflers and kept the exhaust pipe as straight as possible (exhaust dumped at the axle). worked great. If you put your finger over the hoses you could feel the suction.
#212086
02/03/09 09:50 PM
02/03/09 09:50 PM
Posts: 7,664 IN
ahy
IN
Hey,
Thanks alot
Another perspective. If you are using a standard ring pack - not low tension - and parts are machined correctly there shouldn't be a lot of blow by on a street strip engine. An evac system or vacuum pump isn't really needed and wouldn't help much with a typical engine. On a race engine with low tension rings it could help a lot.
The benefit of the PCV valve + breather is constant changing of the air. The PCV sucks some out and the breather lets some in under light load. This helps remove moisture and other bad stuff. Under heavy load, blowby can still exit the breather. Unless you are having a particular problem with your setup I'd just run it. That's what I'm using on a 496 without problem.
Two breathers would work OK also but you don't get the benefit of circulating fresh air through the crankcase.
[Re: BEEQUIK]
#212089
02/03/09 10:26 PM
02/03/09 10:26 PM
MR_P_BODY
this may not help anyone but let me tell you what happened to me and maybe someone will be able to tell me what happened. I had a moroso crank case / header evacuation setup on my 68 GTX.Car ran mid- high 11's and we went to a track for a muffler race. I had an exhaust system put on the car 2-1/2 " with flowmasters.Man it sounded good and when I made a pass it was a SECOND slower,and it blew the intake valley pan up like some stovetop popcorn,all bulged up and blew out the valve cover gaskets!! Unhooked the exhaust and back to 11.70--
Very simple, your 2 1/2" with Flowmasters had more back pressure than 5"hg, once you got on it it went above 5"hg and the back pressure burnt out the check valves and pressurized the crank case
[Re: BEEQUIK]
#212090
02/03/09 10:33 PM
02/03/09 10:33 PM
Posts: 8,165 Left Coast
BobR
Left Coast
Baffled mufflers like Flowmasters DO NOT WORK on evac systems. To get any real power gain you need to use a low tension oil ring and a mechanical vacuum pump that pulls 15" or more vacuum. This much vacuum also helps seal the whole ring pack.
