Tools to remove snap ring on 727 clutch drum
#2116497
07/24/16 05:06 AM
07/24/16 05:06 AM
Posts: 145 Chicagoland 'Burbs
SlickRS23
Chicagoland 'Burbs
Was wondering if anybody here has ever used either of these tools to remove and install the snap ring on the front drum in a 727 trans. With trans shops charging $15 to $20 just to remove or install, and having to leave it with them 'til the next day, these kind of look like they might work. I tried C-Clamps and all I ever got was a bent retainer. Any thoughts or advice would be appreciated. Thanks, Jeff tool #1 Tool#2
Re: Tools to remove snap ring on 727 clutch drum
[Re: SlickRS23]
#2116512
07/24/16 09:37 AM
07/24/16 09:37 AM
Posts: 1,188 imperial mo.
stickman
imperial mo.
Both look like they would work fine.
YOU CAN`T RUN WITH THE BIG DOGS IF YOU NEVER LEAVE THE PORCH.
EB5 70 U Code RT/SE Shaker Challenger
[Re: SlickRS23]
#2116598
07/24/16 12:48 PM
07/24/16 12:48 PM
Posts: 2,065 CA
crackedback
CA
[Re: SlickRS23]
#2116653
07/24/16 02:46 PM
07/24/16 02:46 PM
Posts: 25,618 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Here's the home made tool I've been using for 40+ years.
[Re: SlickRS23]
#2116842
07/24/16 09:09 PM
07/24/16 09:09 PM
Posts: 74,907 U.S.S.A.
JohnRR
U.S.S.A.
Was wondering if anybody here has ever used either of these tools to remove and install the snap ring on the front drum in a 727 trans. With trans shops charging $15 to $20 just to remove or install, and having to leave it with them 'til the next day, these kind of look like they might work. I tried C-Clamps and all I ever got was a bent retainer. Any thoughts or advice would be appreciated. Thanks, Jeff tool #1 Tool#2 Either one will work, I would go with number 2 . I have the factory miller tool, but I like John K's rendition.
[Re: SlickRS23]
#2116860
07/24/16 09:47 PM
07/24/16 09:47 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I don't remember what I used on my last 727 build, but it was not tool listed here I can say that, except maybe a C clamp. But that was back in 94, so my memory is not there.
[Re: SlickRS23]
#2116931
07/24/16 11:49 PM
07/24/16 11:49 PM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
I always use c-clamps on all 904s and 727s I build. I've NEVER had a bent retainer
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
[Re: SlickRS23]
#2117218
07/25/16 12:28 PM
07/25/16 12:28 PM
JohnRR
U.S.S.A.
I was doing a powerglide once and found a PVC coupling that was the right diameter and notched it so I could get to the snap ring and used it in a press , but a big c lamp would have also worked.
[Re: SlickRS23]
#2117308
07/25/16 02:19 PM
07/25/16 02:19 PM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
Easiest/fastest to use is the one like hemi71x shows - I bought one like that, along with a foot operated one many years ago when a local shop closed. Also got a small box of assorted ones like the O/P posted as tool#1.
Google T-0158-SP and you will find several companies that sell the one that hemi71x shows, starting at about $135 on e-bay. Google T-0171 for the foot press I mentioned - they seem to start about $400.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: 62maxwgn]
#2117378
07/25/16 03:43 PM
07/25/16 03:43 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
Was fortunate to acquire the original Miller tool years ago. Got one of those off ebay 12 yrs ago...for 50 bucks.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 62maxwgn]
#2117382
07/25/16 03:47 PM
07/25/16 03:47 PM
JohnRR
U.S.S.A.
Was fortunate to acquire the original Miller tool years ago. I have that tool, I bought it directly from Miller around 2002, it is also used to press the rear sprag outer race into the case.
