Re: blown 392 willys coupe
[Re: BigBird]
#2220660
12/25/16 02:44 PM
12/25/16 02:44 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
The box? what's that? Honestly, whens the last time you had a flat tire? The car probably has a coil over shock rear suspension so you would only have to remove to nuts to drop the rear to remove the tires. If you did have a flat while going down the road you'd be calling a wrecker as there it no place big enough to carry a spare that size.
[Re: rowin4]
#2220680
12/25/16 03:24 PM
12/25/16 03:24 PM
Posts: 7,506 Az
Crizila
Az
Like all automotive projects similar to what we do, you need to have a plan going in (long before you start) - and the plan should include where you live and how far you have to drive to do the things you want to do with your project such as shows, racing, fun trips, etc. This car, obviously, is not going to be something that you would want to drive very far from home. If you want to participate in stuff that is over 100 miles from home base, and be able to drive there and back ( in any weather ), Your car is going to have to be equipped with more than a cell phone. And no matter how much you try to make your car road worthy, a trailer back is almost always mandatory.
Fastest 300
[Re: Mopar Ron]
#2220701
12/25/16 04:09 PM
12/25/16 04:09 PM
Posts: 25,729 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Speaking of Willys (what's the plural of Willys?), I'm helping a friend with the finishing touches on his '33 Coupe...490 inch B block, Torqueflite, Fab Nine rear end
[Re: John_Kunkel]
#2220742
12/25/16 05:09 PM
12/25/16 05:09 PM
Posts: 452 Monrovia, So-Cal, USA
racerhog
That would be a major pita to change the rear wheels on. Yeah, figure on putting it on a lift and dropping the rear axle. Could be worse, try pulling the wheels off the studs on my '50 Olds. Summer>>>>> Good stuff rite their !!!!
Bob(Cowboy)Hogan Monrovia So-Cal
[Re: Crizila]
#2220799
12/25/16 07:31 PM
12/25/16 07:31 PM
Posts: 19,310 north of coder
moparx
Like all automotive projects similar to what we do, you need to have a plan going in (long before you start) - and the plan should include where you live and how far you have to drive to do the things you want to do with your project such as shows, racing, fun trips, etc. This car, obviously, is not going to be something that you would want to drive very far from home. If you want to participate in stuff that is over 100 miles from home base, and be able to drive there and back ( in any weather ), Your car is going to have to be equipped with more than a cell phone. And no matter how much you try to make your car road worthy, a trailer back is almost always mandatory. absolutely correct. at my age and condition, i have a somewhat complete contingency plan thought out. what's funny is, the car [my 33 dodge humpback panel truck] is nowhere near complete. it will be a real pain to drive more than around 100 miles, so i either need many stops, or trailer it to where the destination will be. with that said, i am trying to keep my vision of 40+ years ago alive, and i hope to be able to complete this vision to a somewhat driveable state before i cash in. if my life changes even a little bit in the next year, i hope to be able to continue on this quest, and hope to be able to share a pic or two on the progress.
[Re: moparx]
#2220825
12/25/16 08:32 PM
12/25/16 08:32 PM
Posts: 7,506 Az
Crizila
Az
Like all automotive projects similar to what we do, you need to have a plan going in (long before you start) - and the plan should include where you live and how far you have to drive to do the things you want to do with your project such as shows, racing, fun trips, etc. This car, obviously, is not going to be something that you would want to drive very far from home. If you want to participate in stuff that is over 100 miles from home base, and be able to drive there and back ( in any weather ), Your car is going to have to be equipped with more than a cell phone. And no matter how much you try to make your car road worthy, a trailer back-up is almost always mandatory. absolutely correct. at my age and condition, i have a somewhat complete contingency plan thought out. what's funny is, the car [my 33 dodge humpback panel truck] is nowhere near complete. it will be a real pain to drive more than around 100 miles, so i either need many stops, or trailer it to where the destination will be. with that said, i am trying to keep my vision of 40+ years ago alive, and i hope to be able to complete this vision to a somewhat driveable state before i cash in. if my life changes even a little bit in the next year, i hope to be able to continue on this quest, and hope to be able to share a pic or two on the progress.
Fastest 300
[Re: moparx]
#2220885
12/25/16 11:14 PM
12/25/16 11:14 PM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
Like all automotive projects similar to what we do, you need to have a plan going in (long before you start) - and the plan should include where you live and how far you have to drive to do the things you want to do with your project such as shows, racing, fun trips, etc. This car, obviously, is not going to be something that you would want to drive very far from home. If you want to participate in stuff that is over 100 miles from home base, and be able to drive there and back ( in any weather ), Your car is going to have to be equipped with more than a cell phone. And no matter how much you try to make your car road worthy, a trailer back is almost always mandatory. absolutely correct. at my age and condition, i have a somewhat complete contingency plan thought out. what's funny is, the car [my 33 dodge humpback panel truck] is nowhere near complete. it will be a real pain to drive more than around 100 miles, so i either need many stops, or trailer it to where the destination will be. with that said, i am trying to keep my vision of 40+ years ago alive, and i hope to be able to complete this vision to a somewhat driveable state before i cash in. if my life changes even a little bit in the next year, i hope to be able to continue on this quest, and hope to be able to share a pic or two on the progress. I would love to see your humpback, can you post some pics of it?
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
[Re: moparx]
#2221149
12/26/16 03:38 PM
12/26/16 03:38 PM
Posts: 7,506 Az
Crizila
Az
Like all automotive projects similar to what we do, you need to have a plan going in (long before you start) - and the plan should include where you live and how far you have to drive to do the things you want to do with your project such as shows, racing, fun trips, etc. This car, obviously, is not going to be something that you would want to drive very far from home. If you want to participate in stuff that is over 100 miles from home base, and be able to drive there and back ( in any weather ), Your car is going to have to be equipped with more than a cell phone. And no matter how much you try to make your car road worthy, a trailer back is almost always mandatory. absolutely correct. at my age and condition, i have a somewhat complete contingency plan thought out. what's funny is, the car [my 33 dodge humpback panel truck] is nowhere near complete. it will be a real pain to drive more than around 100 miles, so i either need many stops, or trailer it to where the destination will be. with that said, i am trying to keep my vision of 40+ years ago alive, and i hope to be able to complete this vision to a somewhat driveable state before i cash in. if my life changes even a little bit in the next year, i hope to be able to continue on this quest, and hope to be able to share a pic or two on the progress. Sticking with our original plan for my 33, I wanted to carry provisions to fix a flat on the road if necessary. I carry a small bottle jack, lug wrench, inflation bottle with sealer in it, in a little compartment in mt trunk.
Fastest 300
[Re: Mopar Ron]
#2221186
12/26/16 04:46 PM
12/26/16 04:46 PM
Posts: 3,920 Richmond, Indiana
19swinger70
Richmond, Indiana
I have a AAA membership. Most of my cruising is within a 100 mile radius of my house. That's my contingency plan for not carrying a spare.
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
[Re: Mopar Ron]
#2221383
12/26/16 11:14 PM
12/26/16 11:14 PM
Posts: 10,527 Freeport IL USA
poorboy
Freeport IL USA
I've put well over 100,000 miles on hot rods over the years, and have not had a flat tire, in fact, most of those miles were without even having a spare tire, but even then, I don't have vehicles I couldn't change a tire on if I was sitting on the side of the road. I can just see getting a rare flat on a car like the Willys in some hoe dunk little town and expecting some old guy in a small garage to drop the rear end because I had a flat, but then again, you will be waiting for a tire to be shipped in from someplace anyway. So I guess it really doesn't matter.
I suppose the difference is that I build my cars to drive. Function carries a lot more priority the form does to me. Gene
[Re: poorboy]
#2221436
12/27/16 12:45 AM
12/27/16 12:45 AM
Posts: 7,506 Az
Crizila
Az
I suppose the difference is that I build my cars to drive. Function carries a lot more priority the form does to me. Gene Hope you didn't jinx yourself with that first sentence. Your way over due!
Fastest 300
[Re: Crizila]
#2221924
12/27/16 11:49 PM
12/27/16 11:49 PM
poorboy
Freeport IL USA
Crizilla, A few years ago, we had a tire go down on my wife's PT, but we were just a few blocks from a tire store and the tires had almost 60K on them, we bought new tires. We also had a flat on the PT last summer, but were a few blocks from Walmart with a tire center. It was nearly time for new tires again. We replaced them last month. Seems to be a repeating issue, old tires on the PT! LOL!
If the Dakota gets a flat (the tires on it are about 6 years old, but look almost new great thread, no cracks or signs of dry rot), I might have to get a new truck, nearly any excuse will work...
The tires on the coupe were new in May, but we did become members of AAA this last spring, I'm getting too old to gamble as much as I used to. Gene
[Re: poorboy]
#2222374
12/28/16 07:45 PM
12/28/16 07:45 PM
Posts: 7,506 Az
Crizila
Az
The tires on the coupe were new in May, but we did become members of AAA this last spring, I'm getting too old to gamble as much as I used to. Gene We are a little isolated where we live. Just about any direction out of our town = 70 - 80 miles to civilization again. Guess I'm just a little paranoid.
Fastest 300
